ext3 funktioniert nicht mehr
coolphoenix
21 Jul 2005
also irgendwie hab ich anscheinend grad große probleme mit freetz...
will ich einen usb-stick mit ext3 mounten, krieg ich unter /dev/debug:
ext3: Unknown symbol journal_revoke
ext3: Unknown symbol journal_lock_updates
ext3: Unknown symbol journal_start_commit
ext3: Unknown symbol journal_flush
ext3: Unknown symbol journal_load
ext3: Unknown symbol mb_cache_destroy
ext3: Unknown symbol journal_try_to_free_buffers
ext3: Unknown symbol journal_update_format
ext3: Unknown symbol journal_get_write_access
ext3: Unknown symbol journal_get_undo_access
ext3: Unknown symbol mb_cache_entry_find_first
ext3: Unknown symbol journal_get_create_access
ext3: Unknown symbol journal_destroy
ext3: Unknown symbol journal_clear_err
ext3: Unknown symbol journal_stop
ext3: Unknown symbol mb_cache_entry_alloc
ext3: Unknown symbol mb_cache_entry_release
ext3: Unknown symbol mb_cache_entry_get
ext3: Unknown symbol journal_init_inode
ext3: Unknown symbol log_wait_commit
ext3: Unknown symbol journal_release_buffer
ext3: Unknown symbol journal_check_available_features
ext3: Unknown symbol journal_abort
ext3: Unknown symbol journal_restart
ext3: Unknown symbol mb_cache_entry_find_next
/var/mod/root # lsmod
Module                  Size  Used by    Tainted: P
nls_cp437               5308  0
nls_iso8859_1           3646  0
kdsldmod              882220  2
musb_hdrc              35988  0
usbcore               126044  2 musb_hdrc
dsl_ur8               167825  0
Piglet_noemif          21607  0
/var/mod/root # modprobe ext3
insmod: cannot insert '/lib/modules/2.6.19.2/kernel/fs/ext3/ext3.ko': Success
modprobe: failed to load module ext3
und keine veränderung, problem bleibt.
# Automatically generated make config: don't edit
FREETZ_HAVE_DOT_CONFIG=y
# General --------------------------------
FREETZ_AVM_VERSION_7270=y
# FREETZ_TYPE_300IP_AS_FON is not set
# FREETZ_TYPE_2170 is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_FON_5010 is not set
# FREETZ_TYPE_FON_5050 is not set
# FREETZ_TYPE_FON_5140 is not set
# FREETZ_TYPE_FON_WLAN is not set
# FREETZ_TYPE_FON_WLAN_7050 is not set
# FREETZ_TYPE_FON_WLAN_7113 is not set
# FREETZ_TYPE_FON_WLAN_7140 is not set
# FREETZ_TYPE_FON_WLAN_7141 is not set
# FREETZ_TYPE_FON_7150 is not set
# FREETZ_TYPE_FON_WLAN_7170 is not set
FREETZ_TYPE_FON_WLAN_7270=y
# FREETZ_TYPE_WLAN_3020 is not set
# FREETZ_TYPE_WLAN_3030 is not set
# FREETZ_TYPE_WLAN_3130 is not set
# FREETZ_TYPE_WLAN_3131 is not set
# FREETZ_TYPE_WLAN_3170 is not set
# FREETZ_TYPE_SPEEDPORT_W501V is not set
# FREETZ_TYPE_SPEEDPORT_W701V is not set
# FREETZ_TYPE_SPEEDPORT_W900V is not set
# FREETZ_TYPE_CUSTOM is not set
# FREETZ_KERNEL_VERSION_2_6_13_1 is not set
FREETZ_KERNEL_VERSION_2_6_19_2=y
FREETZ_KERNEL_VERSION="2.6.19.2"
# FREETZ_TYPE_LABOR is not set
FREETZ_AVM_VERSION_STRING="7270"
FREETZ_TYPE_LANG_DE=y
# FREETZ_TYPE_LANG_A_CH is not set
# FREETZ_TYPE_LANG_EN is not set
FREETZ_TYPE_LANG_STRING="de"
FREETZ_TYPE_STRING="7270"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_SHOW_ADVANCED=y
FREETZ_TARGET_REF="8mb_26"
FREETZ_KERNEL_REF="8mb_26"
FREETZ_KERNEL_LAYOUT="ur8"
FREETZ_KERNEL_MTD_SIZE=119
FREETZ_HAS_PHONE=y
FREETZ_HAS_WLAN=y
# FREETZ_HAS_USB_CLIENT is not set
FREETZ_HAS_USB_HOST=y
# Branding
FREETZ_BRANDING_1und1=y
FREETZ_BRANDING_avm=y
# Mod ------------------------------------
FREETZ_LANG_DE=y
# FREETZ_LANG_EN is not set
FREETZ_LANG_STRING="de"
# Patches
# FREETZ_REMOVE_HELP is not set
# FREETZ_REMOVE_ASSISTANT is not set
# FREETZ_PATCH_ENUM is not set
# FREETZ_PATCH_SIGNED is not set
FREETZ_PATCH_USBSTORAGE=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
# FREETZ_AUTOMOUNT_NTFS is not set
FREETZ_AUTOMOUNT_EXT3=y
# FREETZ_PATCH_GETCONS is not set
# FREETZ_REMOVE_UPNP is not set
# FREETZ_REMOVE_USERMAN is not set
# FREETZ_REMOVE_FTPD is not set
# FREETZ_REMOVE_MEDIASRV is not set
# FREETZ_REMOVE_SMBD is not set
# FREETZ_REMOVE_AVM_VPN is not set
# FREETZ_REMOVE_DSLD is not set
# FREETZ_REMOVE_CAPIOVERTCP is not set
# FREETZ_REMOVE_VOIP_ISDN is not set
# FREETZ_REMOVE_ANNEX_A_FIRMWARE is not set
# FREETZ_REMOVE_ANNEX_B_FIRMWARE is not set
# Package selection
# Standard packages
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BRIDGE_UTILS is not set
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
# FREETZ_PACKAGE_CIFSMOUNT is not set
# FREETZ_PACKAGE_CPMACCFG is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DNSMASQ is not set
# FREETZ_PACKAGE_DROPBEAR is not set
# FREETZ_PACKAGE_DTMFBOX is not set
# FREETZ_PACKAGE_ESPEAK is not set
# FREETZ_PACKAGE_FUSE is not set
# FREETZ_PACKAGE_INADYN is not set
# FREETZ_PACKAGE_INETD is not set
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MINI_FO is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NETSNMP is not set
# FREETZ_PACKAGE_NTFS is not set
# FREETZ_PACKAGE_OPENNTPD is not set
# FREETZ_PACKAGE_OPENVPN is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_PRIVOXY is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_SAMBA is not set
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TOR is not set
# FREETZ_PACKAGE_VPNC is not set
# FREETZ_PACKAGE_VSFTPD is not set
# Web interface
# FREETZ_PACKAGE_AVM_FIREWALL is not set
# FREETZ_PACKAGE_DOWNLOADER is not set
# FREETZ_PACKAGE_RRDSTATS is not set
# FREETZ_PACKAGE_SPINDOWN_CGI is not set
# FREETZ_PACKAGE_SYSLOGD_CGI is not set
# FREETZ_PACKAGE_VIRTUALIP_CGI is not set
# FREETZ_PACKAGE_WOL_CGI is not set
# Debug helpers
# FREETZ_PACKAGE_LDD is not set
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_LTRACE is not set
# Testing
# FREETZ_GROUP_APACHE_PHP is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# FREETZ_PACKAGE_EMPTY is not set
FREETZ_PACKAGE_FSTYP=y
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RRDTOOL is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TRANSMISSION is not set
# FREETZ_PACKAGE_USBIP is not set
# FREETZ_PACKAGE_USBROOT is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_WGET is not set
# FREETZ_PACKAGE_XRELAYD is not set
# Unstable--------------------------------
# FREETZ_PACKAGE_COLLECTD is not set
# FREETZ_PACKAGE_IPTABLES is not set
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_MODCGI=y
# Advanced options
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_SITE="ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7270/firmware/deutsch"
FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7270.54.04.57.image"
# Freetz package download sites
FREETZ_MOD_DL_NUM_SITES="5"
# Download site #1 - default: http://freetz.3dfxatwork.de
FREETZ_MOD_DL_SITE_1="http://freetz.3dfxatwork.de"
# Download site #2 - default: http://freetz.wirsind.info
FREETZ_MOD_DL_SITE_2="http://freetz.wirsind.info"
# Download site #3 - default: http://freetz.magenbrot.net
FREETZ_MOD_DL_SITE_3="http://freetz.magenbrot.net"
# Download site #4 - default: empty (reserved for later use)
FREETZ_MOD_DL_SITE_4=""
# Download site #5 - user-defined
FREETZ_MOD_DL_SITE_5=""
FREETZ_VERBOSITY_LEVEL=2
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_AUTORUN_AUTOEND=y
FREETZ_DEVELOPER_VERSION_STRING=y
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
# FREETZ_SQUASHFS_BLOCKSIZE_16384 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_32768 is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
# FREETZ_SQUASHFS_BLOCKSIZE_131072 is not set
# BusyBox options
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_DIFF is not set
# FREETZ_BUSYBOX_INETD is not set
# FREETZ_BUSYBOX_PATCH is not set
# FREETZ_BUSYBOX_START_STOP_DAEMON is not set
FREETZ_BUSYBOX_WGET=y
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_NICE is not set
# FREETZ_BUSYBOX_LS_COLOR is not set
# FREETZ_BUSYBOX_FASTPROC is not set
# FREETZ_BUSYBOX_KEYS is not set
# Kernel modules
# crypto
# FREETZ_MODULE_crypto_algapi is not set
# FREETZ_MODULE_aes is not set
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_blkcipher is not set
# FREETZ_MODULE_cbc is not set
# FREETZ_MODULE_cryptomgr is not set
# FREETZ_MODULE_sha1 is not set
# FREETZ_MODULE_sha256 is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_async is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_ppp_generic is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_slhc is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_hci_usb is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# fs
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
FREETZ_MODULE_ext3=y
# FREETZ_MODULE_ext2 is not set
# FREETZ_MODULE_fuse is not set
FREETZ_MODULE_jbd=y
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_ntfs is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_smbfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_msdods is not set
# FREETZ_MODULE_jffs2 is not set
FREETZ_MODULE_mbcache=y
# lib
# FREETZ_MODULE_crc_ccitt is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_l2cap is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
# Shared libraries
# FREETZ_STRIP_LIBRARIES is not set
# Libraries -------------------------------
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libxyssl is not set
# FREETZ_LIB_libcrypto is not set
# FREETZ_LIB_libssl is not set
# Data compression
# FREETZ_LIB_liblzo2 is not set
# FREETZ_LIB_libz is not set
# Graphics & fonts
# FREETZ_LIB_libfreetype is not set
# FREETZ_LIB_libart_lgpl_2 is not set
# FREETZ_LIB_libjpeg is not set
# FREETZ_LIB_libpng12 is not set
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_libpthread=y
# FREETZ_LIB_libresolv is not set
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
# FREETZ_LIB_libutil is not set
# FREETZ_LIB_libuClibcxx is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libglib is not set
# GLib2
# FREETZ_LIB_libglib2 is not set
# FREETZ_LIB_libgobject2 is not set
# FREETZ_LIB_libgmodule2 is not set
# FREETZ_LIB_libgthread2 is not set
# ncurses
# FREETZ_LIB_libncurses is not set
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
# FREETZ_LIB_libterminfo is not set
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# FREETZ_LIB_libcapi20 is not set
# FREETZ_LIB_libcurl is not set
# FREETZ_LIB_libevent is not set
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libpcap is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# FREETZ_LIB_libusb is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libintl is not set
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libftdi is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libdevmapper is not set
# Compiler options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_TARGET_CFLAGS="-Os -pipe -march=4kc -Wa,--trap"
FREETZ_JLEVEL=2
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
FREETZ_TARGET_GCC_VERSION="4.2.1"
FREETZ_TARGET_UCLIBC_VERSION="0.9.28"
FREETZ_TARGET_BINUTILS_VERSION="2.17.50.0.17"
FREETZ_TARGET_UCLIBC_REF="mod_26"
# FREETZ_STATIC_TOOLCHAIN is not set
FREETZ_TARGET_GXX=y
# FREETZ_TARGET_CCACHE is not set
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
FREETZ_KERNEL_GCC_VERSION="3.4.6"
FREETZ_KERNEL_BINUTILS_VERSION="2.17.50.0.17"
# GNU debugger (gdb)
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_GDB_SERVER is not set
# FREETZ_PACKAGE_GDB_HOST is not set
ext3 geht glaube ich nur, wenn man mit einem replaced Kernel arbeitet. Dieser aber funktioniert erst wieder, nachdem AVM die neuen Sourcne mal online gestellt hat.
Hi !
nls_cp437               5308  0
kdsldmod              882220  2
musb_hdrc              35988  0
dsl_ur8               167825  0
[code][...]
FREETZ_MODULE_jbd=y
Irgendwie fehlen, wohl die Module jbd und mbcache. Schau mal nach
ob die irgendwo unter /lib/modules/`uname -r`/ im Image existieren?
Bzw. ob die Module-Dependencie-Files in /lib/modules/`uname -r` auch die nötigen Referenzen für ext3, mbcache und jbd enthalten.
Ansonsten bau mal ein Freetzt komplett neu.
cya
also es ging definitiv bis gestern mittag noch. dann habe ich ein svn up gemacht und ein neues image geflasht. seitdem habe ich diese komischen errors (beim kompilieren, siehe anderer thread, und nun auch ext3).
ich habe grad eine alte revision (2222, die hatte ich vorgestern drauf und die lief definitiv korrekt) ausgecheckt (komplett neuer freetz-ordern, selbst alle files wurden nochmal neu dled), nun kommen auch dort kompilierfehler.
ich glaube langsam, es liegt irgendwie an meinem system...
aber nun hat folgendes auf der box das problem gelöst:
for mod in `find /lib/modules/2.6.19.2/ | grep .ko`; do insmod $mod; done
/var/media/ftp # lsmod
vfat                   11303  0
nls_iso8859_15          4206  0
nls_cp850               4471  0
jffs2                 115457  0
isofs                  25444  0
fat                    53524  1 vfat
userman                32607  0
usb_storage            36333  1
usbauth                 7913  0
usblp                  14073  0
sg                     30541  0
sd_mod                 17441  2
scsi_mod               93977  3 usb_storage,sg,sd_mod
wlan_xauth              1182  0
wlan_wep                6711  0
wlan_tkip              14118  0
wlan_scan_sta          14855  0
wlan_scan_ap           11095  0
wlan_ccmp               9491  0
wlan_acl                4478  0
wlan                  247857  7 wlan_xauth,wlan_wep,wlan_tkip,wlan_scan_sta,wlan_scan_ap,wlan_ccmp,wlan_acl
avm_ath_extensions     28085  1 wlan
atrcm                1059825  0
ath_dfs                24350  0
isdn_fbox_fon5        764452  0
capi_codec             93998  0
pcmlink               156569  2 isdn_fbox_fon5,capi_codec
ext2                   58264  0
ext3                  129547  1
mbcache                 7075  2 ext2,ext3
jbd                    57657  1 ext3
nls_cp437               5308  0
kdsldmod              882220  3 userman
musb_hdrc              35988  0
usbcore               126044  5 usb_storage,usbauth,usblp,musb_hdrc
dsl_ur8               167825  0
irgendwas stimmt mit dem module-loading anscheinen nicht. ich bin etwas verwirrt...
meine modules.dep:
/lib/modules/2.6.19.2/kernel/drivers/char/ubik2/pcmlink.ko:
/lib/modules/2.6.19.2/kernel/fs/mbcache.ko:
/lib/modules/2.6.19.2/kernel/fs/nls/nls_cp437.ko:
/lib/modules/2.6.19.2/kernel/fs/isofs/isofs.ko:
/lib/modules/2.6.19.2/kernel/fs/nls/nls_cp850.ko:
/lib/modules/2.6.19.2/kernel/drivers/net/wireless/ath_hal.ko:
/lib/modules/2.6.19.2/kernel/fs/nls/nls_iso8859-1.ko:
/lib/modules/2.6.19.2/kernel/fs/jbd/jbd.ko:
/lib/modules/2.6.19.2/kernel/drivers/net/wireless/wlan_tkip.ko:
/lib/modules/2.6.19.2/kernel/drivers/net/wireless/wlan.ko:
/lib/modules/2.6.19.2/kernel/drivers/isdn/avm_dect/avm_dect.ko:
/lib/modules/2.6.19.2/kernel/fs/vfat/vfat.ko:
/lib/modules/2.6.19.2/kernel/drivers/net/wireless/ath_dfs.ko:
/lib/modules/2.6.19.2/kernel/drivers/usb/class/usblp.ko:
/lib/modules/2.6.19.2/kernel/drivers/net/wireless/ath_rate_atheros.ko:
/lib/modules/2.6.19.2/kernel/drivers/char/dect_io/dect_io.ko:
/lib/modules/2.6.19.2/kernel/drivers/userman/userman_mod.ko:
/lib/modules/2.6.19.2/kernel/fs/ext2/ext2.ko:
/lib/modules/2.6.19.2/kernel/drivers/scsi/sg.ko:
/lib/modules/2.6.19.2/kernel/drivers/usb/misc/usbauth/usbauth.ko:
/lib/modules/2.6.19.2/kernel/drivers/scsi/sd_mod.ko:
/lib/modules/2.6.19.2/kernel/drivers/dsld/kdsldmod.ko:
/lib/modules/2.6.19.2/kernel/drivers/net/wireless/wlan_scan_sta.ko:
/lib/modules/2.6.19.2/kernel/fs/nls/nls_iso8859-15.ko:
/lib/modules/2.6.19.2/kernel/drivers/net/wireless/wlan_ccmp.ko:
/lib/modules/2.6.19.2/kernel/drivers/dsl/dsl_ur8.ko:
/lib/modules/2.6.19.2/kernel/drivers/net/wireless/wlan_wep.ko:
/lib/modules/2.6.19.2/kernel/fs/fat/fat.ko:
/lib/modules/2.6.19.2/kernel/fs/jffs2/jffs2.ko:
/lib/modules/2.6.19.2/kernel/drivers/isdn/capi_codec/capi_codec.ko:
/lib/modules/2.6.19.2/kernel/drivers/net/wireless/atrcm.ko:
/lib/modules/2.6.19.2/kernel/drivers/isdn/isdn_fon5/zzz/isdn_fbox_fon5.ko:
/lib/modules/2.6.19.2/kernel/drivers/scsi/scsi_mod.ko:
/lib/modules/2.6.19.2/kernel/drivers/usb/musb/musb_hdrc.ko:
/lib/modules/2.6.19.2/kernel/drivers/net/wireless/wlan_xauth.ko:
/lib/modules/2.6.19.2/kernel/drivers/char/Piglet_noemif/Piglet_noemif.ko:
/lib/modules/2.6.19.2/kernel/drivers/net/wireless/ath_pci.ko:
/lib/modules/2.6.19.2/kernel/drivers/net/wireless/wlan_scan_ap.ko:
/lib/modules/2.6.19.2/kernel/drivers/net/wireless/wlan_acl.ko:
/lib/modules/2.6.19.2/kernel/drivers/net/wireless/avm_ath_extensions.ko:
/lib/modules/2.6.19.2/kernel/fs/ext3/ext3.ko:
/lib/modules/2.6.19.2/kernel/drivers/usb/core/usbcore.ko:
/lib/modules/2.6.19.2/kernel/drivers/usb/storage/usb-storage.ko:
das habe ich getan.
Also, bei mir arbeitet ext3 wunderbar. Auch ohne "replace kernel". :gruebel:
meine modules.dep:
Also in den Zeilen deiner modules.dep fuer ext2 fehlt ein Verweis auf mbcache.ko,
und für ext3 ein verweis auf jbd.ko.
Warum das so ist weis ich nicht.
Ich empfehle, ein frisches svn co,
dahinein dann die .config, die busybox-config und die kernel-config kopieren und nochmal durchlaufen lassen.
(Es gib, glaub ich auch einen "make <foo>" kommando was dies in einem bereits benutzten Freetz-Svn-Baum macht ohne ein erneutes Checkout, aber das kommando ist mir gerade entfallen).
cya
@schmatke
Bist du sicher? Leg mal bitte ein Verzeichnis im ext3 an und poste ein "ls -l". Eigentlich sollten da komische Zahlen kommen.
MfG Oliver
@schmatke
MfG Oliver
bei mir funktioniert(e) ext3 definitiv auch ohne replace_kernel (das es für die 7270 nicht gibt). nun halt mit dem manuellen insmod, was aber bis vorgestern auch noch automatisch ging...
@olistudent
Jetzt bin ich extra wegen Dir unter den Tisch gestiegen, um Dir das Gegenteil zu beweisen.
Und was kommt raus: Du hast wieder Recht! :groesste:
Ich habe wohl irgendwann dass Teil mit fat32 formatiert (:gruebel:), warum auch immer. Da bau ich die ganze Zeit mit ext3-Modulen und verschwende wertvollen Platz. :mad:
Sorry, für meinen sinnlosen Kommentar!!!
Ich muss weg!
Mal ne Verständnis frage, da mir auch neu ist, dass ext3 nur mit replace-kernel geht(, aber ich muss sagen,dass ich damit kaum erfahrung gemacht hab, da ich ext3 gerade nicht verwende:
Wenn ext3 nur mit replace_kernel funtz, warum kann man dann "Automount ext3" auswählen ohne replace_Kernel, welches dann das ext3 auswählt?
Wie sieht das mit ntfs aus?
Das ist nur im Moment so, weil AVM da was am Kernel geändert hat.
MfG Oliver
ok, danke für die antwort,
hab ich doch richtig gedacht, dass es eigentlich geht, aber jetzt an den fehlenden Headern liegt, dass es nciht geht, da die module so nciht passen.
Ok danke :)
also bei mir geht ext3 gerade. mit der letzen offiziellen fw. nur das automatische module-loading für ext3 geht nicht, weil meine modules.dep keine abhängigkeiten anzeigt. warum auch immer.
bei mir läuft ext3. leider aber total langsam. bei ext2 schaff ich beim schreiben ca. 800 kb/s bei ext3 aber nur 120 kb/s. ist das normal ?
Da ext3 aus ext2+journaling besteht ist es normal, dass es langsamer ist. Sicherheit hat ihren Preis :-)
Aber so viel langsamer sollte das doch nicht sein!?
MfG Oliver
Also schreibend hab ich an der 7170 auf einen USB-Stick 80KB/s auf ext3 und 180KB/s auf vfat (ganz grob gemessen mit "date;dd if=/dev/zero of=temp count=1024 bs=1024;date"). Es hängt auch davon ab was die Box sonst noch so treibt. Mir sind schnelle Downloads (30 MBit) und VoIP da negativ aufgefallen.
Callendaar
