7340 new avm firmware 99.05.05 available/not used by freetz
Michael999
24 Dez 2008
Currently Freetz uses avm firmware version 99.04.90 for the 7340. Could/will Freetz be made compatible with the new 7340 firmware (because right now it obviously isn't)?
Thank you for the reminder. I don't get news for the international firmwares.
Regards
Oliver
Please give it a try. But don't forget to get a recover image before it has come too late.
Regards
Oliver
$ svn log -r 7755:7759
r7755 | oliver | 2011-10-08 18:39:59 +0200 (Sa, 08. Okt 2011) | 1 Zeile
* 7340: Prepare for version bump, delete old patches
r7756 | oliver | 2011-10-08 18:40:01 +0200 (Sa, 08. Okt 2011) | 1 Zeile
r7757 | oliver | 2011-10-08 18:54:47 +0200 (Sa, 08. Okt 2011) | 1 Zeile
* 7340: Bump version to 05.05 (step 2)
r7758 | oliver | 2011-10-08 18:58:35 +0200 (Sa, 08. Okt 2011) | 2 Zeilen
* 7340: Bump version to 05.05 (final step)
r7759 | oliver | 2011-10-08 18:58:36 +0200 (Sa, 08. Okt 2011) | 2 Zeilen
I had to recover the box. My Freetz setup works fine as long as I don't use "replace kernel". If I do, the power/DSL led just keeps blinking indefinitely and the AVM web-interface is unreachable.
Thank you, olistudent.
The 7270 has an update as well.....
I needed to recover a Fritzbox recently and lost all the settings because the "upgrade" to Freetz was seen as a downgrade...
Okay. Then I will disable replace kernel for 7340 05.05.
Regards
Oliver
This is perhaps a little bit off-topic, but these things only happened after I changed from 04.90 to 05.05. The only things not working for me now are 1) starting subversion and 2) logging in with vsftpd/dropbear sftp. Logging in via shell gets me:
-sh: /etc/init.d/rc.conf: line 4: can't create /var/env: Permission denied
rm: can't remove '/var/htmltext.db': Permission denied
ln: /var/htmltext.db: File exists
rm: can't remove '/var/TZ': Permission denied
ln: /var/TZ: File exists
test@fritz:/$ l
drwxrwxrwx   15 root     root           207 Oct 11 21:23 .
drwxrwxrwx   15 root     root           207 Oct 11 21:23 ..
drwxr-xr-x    2 root     root          1268 Oct 11 21:23 bin
drwxr-xr-x    2 root     root             3 Sep 19 16:15 data
drwxr-xr-x    8 root     root          3340 Jan  1  1970 dev
drwxr-xr-x   57 root     root          2015 Oct 11 21:23 etc
lrwxrwxrwx    1 root     root            12 Oct 11 21:22 home -> var/mod/home
drwxr-xr-x    4 root     root          5118 Oct 11 21:23 lib
drwxr-xr-x    2 root     root             3 Sep 19 16:15 mnt
lrwxrwxrwx    1 root     root             7 Oct 11 21:22 mod -> var/mod
lrwxrwxrwx    1 root     root            19 Oct 11 21:22 nohup.out -> ./var/tmp/nohup.out
drwxr-xr-x    2 root     root             3 Oct 11 21:22 opt
dr-xr-xr-x  108 root     root             0 Jan  1  1970 proc
drwxr-xr-x    2 root     root             3 Sep 19 16:15 root
drwxr-xr-x    2 root     root           907 Oct 11 21:23 sbin
drwxr-xr-x   11 root     root             0 Jan  1  1970 sys
lrwxrwxrwx    1 root     root             7 Oct 11 21:22 tmp -> var/tmp
drwxr-xr-x   13 root     root           159 Oct 11 21:23 usr
drwxr-xr-x   17 root     root          1180 Oct 11 21:59 var
-rw-r--r--    1 root     root         37376 Oct 11 21:23 var.tar
test@fritz:/$ mkdir test
mkdir: can't create directory 'test': Read-only file system
and I get thrown in / instead of the home directory.
Homedir:
root@fritz:/var/mod/root# ls -ld /var/media/ftp/uStor06/ftp/test
drwxrwxrwx    2 test     test          4096 Oct 11 22:44 /var/media/ftp/uStor06/ftp/test
It's not a big thing though, I can always go back to 04.90 if I really want to get those things working again.
Subversion not starting:
start-stop-daemon: can't execute '/usr/bin/svnserve': Permission denied
Starting subversion ... failed.
root@fritz:/var/mod/root# l /usr/bin/svnserve
lrwxrwxrwx    1 root     root            30 Oct 11 21:23 /usr/bin/svnserve -> /mod/external/usr/bin/svnserve
root@fritz:/var/mod/root# l /mod/external/usr/bin/svnserve
-rwxr-xr-x    1 root     root       2324412 Oct 10 17:04 /mod/external/usr/bin/svnserve
This doesn't have to do anything with the new firmware. The user test does work like root for you with 04.90? I don't think so!?
Regards
Oliver
It's just that a few weeks ago I could log in fine, but it's clearly something else then. Thanks for clearing that up.
I would wonder if these messages
do not always appear when login with a user different from root.
Regards
Oliver
You're right, they do.
syslog fritzbox 7340
Regards
Oliver
I have flashed the fritzbox 7340 with Freetz trunk 7793 with replace kernel on.
First I disconnect the dsl cable. Second I connect with the fritzbox and start logging with syslog.
Third I connect the dsl cable again and see the kernel panicking.
I want to be able to choose 'replace kernel', so I can add 'pptp' to Freetz.
Syslog:
<13>Jan 1 01:02:16 kernel: klogd started: BusyBox v1.19.2 (2011-10-10 14:36:42 CEST)
192.168.178.1 14/10 15:14:33.516
<12>Jan 1 01:04:11 kernel: VDSL AP and VDSL PHY clocks are enabled
192.168.178.1 14/10 15:16:28.134
<12>Jan 1 01:04:11 kernel: Slave Mem Alloc: Req size 32 Ptr2Block 0x191f00a0
192.168.178.1 14/10 15:16:28.136
<12>Jan 1 01:04:11 kernel: Slave Mem Alloc: Req size 96 Ptr2Block 0x191f00c0
192.168.178.1 14/10 15:16:28.137
<12>Jan 1 01:04:11 kernel: Slave Mem Alloc: Req size 128 Ptr2Block 0x191f0120
192.168.178.1 14/10 15:16:28.138
<12>Jan 1 01:04:11 kernel: Slave Mem Alloc: Req size 192 Ptr2Block 0x191f01a0
192.168.178.1 14/10 15:16:28.139
<12>Jan 1 01:04:11 kernel: Slave Mem Alloc: Req size 256 Ptr2Block 0x191f0260
<12>Jan 1 01:04:11 kernel: Calling vdslAtmCellHeaderRAMReset()....
192.168.178.1 14/10 15:16:28.154
<12>Jan 1 01:04:11 kernel: ATM Driver Initialized SUCCESSFULLY...
192.168.178.1 14/10 15:16:28.158
<15>Jan 1 01:04:27 kernel: vcc_release(0,0) done.<7>vcc_release(0,0) done.<7>vcc_release(0,0) done.<7><7>vcc_connect(0,34) done.<7><6>kdsld_token_thread: start
192.168.178.1 14/10 15:16:44.228
<14>Jan 1 01:04:27 kernel: sch_llq: Sep 8 2011 15:32:44
192.168.178.1 14/10 15:16:44.260
<14>Jan 1 01:04:28 kernel: /proc/tffs: info request: success
192.168.178.1 14/10 15:16:44.855
<13>Jan 1 01:04:28 ONLINECHANGED[4035]: [online] approved
192.168.178.1 14/10 15:16:45.275
<13>Jan 1 01:04:28 ONLINECHANGED[4035]: [online] executing /etc/onlinechanged/00-get_ip
192.168.178.1 14/10 15:16:45.290
<13>Jan 1 01:04:28 ONLINECHANGED[4035]: [online] executing /etc/onlinechanged/chrony
192.168.178.1 14/10 15:16:45.325
<13>Jan 1 01:04:28 ONLINECHANGED[4035]: [online] * modprobe: module rtc_dev not found in modules.dep
192.168.178.1 14/10 15:16:45.557
<13>Jan 1 01:04:28 ONLINECHANGED[4035]: [online] * modprobe: module rtc_lib not found in modules.dep
192.168.178.1 14/10 15:16:45.652
<13>Jan 1 01:04:29 ONLINECHANGED[4035]: [online] * rm: can't remove '/var/flash/chrony.drift': No such file or directory
192.168.178.1 14/10 15:16:45.857
<13>Jan 1 01:04:29 ONLINECHANGED[4035]: [online] * rm: can't remove '/var/flash/chrony.rtc': No such file or directory
192.168.178.1 14/10 15:16:45.858
<14>Oct 14 15:16:36 chronyd[4077]: chronyd version 1.25-pre1 starting
192.168.178.1 14/10 15:16:46.267
<11>Oct 14 15:16:36 telefon[1600]: set initial telefon time from linux time to 15:16:36 14.10 2011!
192.168.178.1 14/10 15:16:46.562
<14>Oct 14 15:16:36 chronyd[4077]: Initial txc.tick=10000 txc.freq=0 (0.00000000) txc.offset=0 => hz=100 shift_hz=7
192.168.178.1 14/10 15:16:46.886
<14>Oct 14 15:16:36 chronyd[4077]: set_config_hz=0 hz=100 shift_hz=7 basic_freq_scale=1.28000000 nominal_tick=10000 slew_delta_tick=833 max_tick_bias=1000
192.168.178.1 14/10 15:16:46.888
<14>Oct 14 15:16:36 chronyd[4077]: Linux kernel major=2 minor=6 patch=28
192.168.178.1 14/10 15:16:46.890
<14>Oct 14 15:16:36 chronyd[4077]: calculated_freq_scale=1.00000000 freq_scale=1.00000000
192.168.178.1 14/10 15:16:46.892
<9>Oct 14 15:16:36 kernel: CPU 0 Unable to handle kernel paging request at virtual address fffffff4, epc == c1a38e78, ra == 8008d3a4
192.168.178.1 14/10 15:16:46.893
<12>Oct 14 15:16:36 kernel: Oops[#1]:
192.168.178.1 14/10 15:16:46.895
<12>Oct 14 15:16:36 kernel: Cpu 0
192.168.178.1 14/10 15:16:46.896
<12>Oct 14 15:16:36 kernel: $ 0 : 00000000 7fba3a2c c1a38e60 00000001
192.168.178.1 14/10 15:16:46.898
<12>Oct 14 15:16:36 kernel: $ 4 : 87a44b84 86aece60 87976154 86aece60
192.168.178.1 14/10 15:16:46.899
<12>Oct 14 15:16:36 kernel: $ 8 : 00000030 00020f54 8008864c fffffff8
192.168.178.1 14/10 15:16:46.901
<12>Oct 14 15:16:36 kernel: $12 : 00000001 00440b00 00000260 004280bc
192.168.178.1 14/10 15:16:46.903
<12>Oct 14 15:16:36 kernel: $16 : 00000004 fffffeb0 87976154 00000000
192.168.178.1 14/10 15:16:46.904
<12>Oct 14 15:16:36 kernel: $20 : 00000000 00000000 00000000 7fba498c
192.168.178.1 14/10 15:16:46.908
<12>Oct 14 15:16:36 kernel: $24 : 000001b0 00000000
192.168.178.1 14/10 15:16:46.909
<12>Oct 14 15:16:36 kernel: $28 : 85414000 85417d98 0042be84 8008d3a4
192.168.178.1 14/10 15:16:46.911
<12>Oct 14 15:16:36 kernel: Code: afb00014 8c9000f0 2611feac <8e240144> 2610003c 24020001 c2060000 00c21825 e2030000
192.168.178.1 14/10 15:16:46.913
<8>Oct 14 15:16:36 kernel: Fatal exception: panic in 5 seconds
192.168.178.1 14/10 15:16:46.914
<13>Oct 14 15:16:37 ONLINECHANGED[4035]: [online] executing /etc/onlinechanged/send_crashreport
192.168.178.1 14/10 15:16:47.547
<13>Oct 14 15:16:38 ONLINECHANGED[4035]: [online] executing /etc/onlinechanged/webdav_net
192.168.178.1 14/10 15:16:48.535
<13>Oct 14 15:16:39 ONLINECHANGED[4035]: [online] finished
192.168.178.1 14/10 15:16:49.967
<12>Oct 14 15:16:41 kernel: Call Trace:
192.168.178.1 14/10 15:16:51.849
<12>Oct 14 15:16:41 kernel: [<802c7b04>] dump_stack+0x8/0x34
192.168.178.1 14/10 15:16:51.850
<12>Oct 14 15:16:41 kernel: [<802c7b6c>] panic+0x3c/0x1e8
192.168.178.1 14/10 15:16:51.851
<12>Oct 14 15:16:41 kernel: [<8001b668>] die+0xd4/0xdc
192.168.178.1 14/10 15:16:51.852
<12>Oct 14 15:16:41 kernel: [<8001f59c>] do_page_fault+0x2dc/0x4e0
192.168.178.1 14/10 15:16:51.853
<12>Oct 14 15:16:41 kernel: [<80015500>] ret_from_exception+0x0/0xc
192.168.178.1 14/10 15:16:51.854
<12>Oct 14 15:16:41 kernel: [<c1a38e78>] rtc_read_alarm+0x3b8/0x490 [rtc_core]
<8>Oct 14 15:16:41 kernel: Kernel panic - not syncing: Fatal exception
192.168.178.1 14/10 15:16:51.855
<12>Oct 14 15:16:41 kernel: WARNING: use tffs in panic mode (minor 96)
192.168.178.1 14/10 15:16:51.856
Ah, I see. Please select "remove chronyd" patch and build a new image.
Regards
Oliver
Regards
Oliver
No kernel panic anymore with ´remove chronyd´ patch.
Syslog:
<15>Jan 1 01:01:15 kernel: vcc_release(0,0) done.<7>vcc_release(0,0) done.<7>vcc_release(0,0) done.<7><7>vcc_connect(0,34) done.<7><6>kdsld_token_thread: start
192.168.178.1 14/10 22:21:26.753
<14>Jan 1 01:01:15 kernel: sch_llq: Sep 8 2011 15:32:44
192.168.178.1 14/10 22:21:26.991
<14>Jan 1 01:01:18 kernel: /proc/tffs: info request: success
192.168.178.1 14/10 22:21:29.624
<13>Jan 1 01:01:18 ONLINECHANGED[2945]: [online] approved
192.168.178.1 14/10 22:21:29.764
<13>Jan 1 01:01:18 ONLINECHANGED[2945]: [online] executing /etc/onlinechanged/00-get_ip
192.168.178.1 14/10 22:21:29.817
<13>Jan 1 01:01:18 ONLINECHANGED[2945]: [online] executing /etc/onlinechanged/send_crashreport
192.168.178.1 14/10 22:21:29.866
<13>Jan 1 01:01:19 ONLINECHANGED[2945]: [online] executing /etc/onlinechanged/webdav_net
192.168.178.1 14/10 22:21:30.958
<11>Oct 14 22:21:21 telefon[1605]: set initial telefon time from linux time to 22:21:21 14.10 2011!
192.168.178.1 14/10 22:21:31.641
<14>Oct 14 22:21:21 hostapd: ath0: STA *secret* WPA: group key handshake completed (RSN)
192.168.178.1 14/10 22:21:31.801
<13>Oct 14 22:21:22 ONLINECHANGED[2945]: [online] finished
192.168.178.1 14/10 22:21:32.392
Thank you.
Now I try to utilize pptp. I have servername, username and password. (works in Windows 7)
this fails with the following lines in Freetz:
Starting pptp:
modprobe: module sha1_generic not found in modules.dep
modprobe: module ppp_generic not found in modules.dep
modprobe: module ppp_async not found in modules.dep
Starting pptp ... failed.
The checkboxes of these three modules are checked (by default): Advanced Options - Kernel Modules under crypto and drivers.
Syslog:
<29>Oct 14 22:32:01 pppd[3977]: pppd 2.4.5 started by root, uid 0
192.168.178.1 14/10 22:32:09.339
<13>Oct 14 22:32:01 pptp[3979]: anon log[main:pptp.c:314]: The synchronous pptp option is NOT activated
192.168.178.1 14/10 22:32:09.345
<30>Oct 14 22:32:01 pppd[3977]: Using interface ppp0
192.168.178.1 14/10 22:32:09.382
<29>Oct 14 22:32:01 pppd[3977]: Connect: ppp0 <--> /dev/pts/0
192.168.178.1 14/10 22:32:09.383
<13>Oct 14 22:32:01 pptp[3986]: anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 1 'Start-Control-Connection-Request'
192.168.178.1 14/10 22:32:09.445
<13>Oct 14 22:32:01 pptp[3986]: anon log[ctrlp_disp:pptp_ctrl.c:739]: Received Start Control Connection Reply
192.168.178.1 14/10 22:32:09.496
<13>Oct 14 22:32:01 pptp[3986]: anon log[ctrlp_disp:pptp_ctrl.c:773]: Client connection established.
192.168.178.1 14/10 22:32:09.498
<13>Oct 14 22:32:02 pptp[3986]: anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 7 'Outgoing-Call-Request'
192.168.178.1 14/10 22:32:10.447
<13>Oct 14 22:32:02 pptp[3986]: anon log[ctrlp_disp:pptp_ctrl.c:858]: Received Outgoing Call Reply.
192.168.178.1 14/10 22:32:10.502
<13>Oct 14 22:32:02 pptp[3986]: anon log[ctrlp_disp:pptp_ctrl.c:897]: Outgoing call established (call ID 0, peer's call ID 34304).
192.168.178.1 14/10 22:32:10.504
<27>Oct 14 22:32:03 pppd[3977]: MPPE required, but MS-CHAP[v2] auth not performed.
192.168.178.1 14/10 22:32:11.105
<29>Oct 14 22:32:03 pppd[3977]: Connection terminated.
192.168.178.1 14/10 22:32:11.214
<12>Oct 14 22:32:03 pptp[3979]: anon warn[decaps_hdlc:pptp_gre.c:204]: short read (-1): Input/output error
192.168.178.1 14/10 22:32:11.239
<12>Oct 14 22:32:03 pptp[3979]: anon warn[decaps_hdlc:pptp_gre.c:216]: pppd may have shutdown, see pppd log
<30>Oct 14 22:32:03 pppd[3977]: Exit.
192.168.178.1 14/10 22:32:11.240
<13>Oct 14 22:32:03 pptp[3986]: anon log[callmgr_main:pptp_callmgr.c:234]: Closing connection (unhandled)
192.168.178.1 14/10 22:32:11.243
<13>Oct 14 22:32:03 pptp[3986]: anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 12 'Call-Clear-Request'
<13>Oct 14 22:32:03 pptp[3986]: anon log[call_callback:pptp_callmgr.c:79]: Closing connection (call state)
192.168.178.1 14/10 22:32:11.244
I read somewhere I should pass "refuse-eap" to pppd. Only my current security level won't allow me.
I can find out how to change the security level and enter this in the box on the pppd page.
Good idea?
Deleted: double entry
entering
refuse-eap
didn't work.
Still: The synchronous pptp option is NOT activated
These Code is built into kernel and the errors of modprobe could be ignored. I don't know why pppd doesn't connect.
Regards
Oliver
Danke Oliver fuer dein Antwort.
Ich habe es nicht gewusst die log war nicht in ordnung. Wie soll ich das machen?
Getrennt? Ja, das ist vielleicht besser.
Ra67
