[Info] Fritz!WLAN Repeater 300E Firmware Version 101.06.20 international vom 05.12.2014
  • Ersteller Ersteller SF1975
S
SF1975
Guest
Product:         FRITZ!WLAN Repeater 300E
Version:             FRITZ!OS 6.20
Language:              English, French, Italian, Spanish, Polish
Release date:     05.12.2014
New in FRITZ!OS 6.20
WLAN:
NEW: Start WPS for wireless LAN guest access/private hotspot in the fritz.repeater user interface
NEW: Wireless LAN schedule can now be entered conveniently on the tablet or smartphone
NEW: Wireless auto channel can be updated in the user interface (LAN bridge mode)
NEW: Detailed information on connected wireless devices (Rx/Tx data rate, RSSI value, wireless standard, etc.)
NEW: Option for restricting wireless auto channel to channels without DFS (no interference from radar; LAN bridge mode)
NEW: Adopt parental controls from the FRITZ!Box*
System:
NEW: the user interface now supports English, French, Italian, Spanish, Polish, German
NEW: Option for automatically updating FRITZ!OS**
NEW: The complete repeater name is displayed in the Repeater user interface
System/Security:
NEW: Information about recent user registrations on the FRITZ!Repeater interface
NEW: Supports HTTPS even when the fritz.repeater user interfaces are accessed locally
NEW: Supports the securest TLS 1.2 standards (SSL with AES) for https connections with the FRITZ!WLAN Repeater
Improvements and Bug Fixes in FRITZ!OS 6.20
System
Improvement: New 5-GHz message for 10 min. wait time on the weather channels
Improvement: New 5-GHz message for radar detection (DFS wati time)
Improved stability and performance
Improvement: Optimized display of the user interface on Windows phone devices
Improved display in the Energy Monitor
Improvement: 802.11a/b/g wireless devices are correctly displayed as 802.11a/b/g wireless devices
Improvement: Display of number of wireless streams corrected
Improvement: Switch to encrypted mail sending via port 587 with fallback to port 25 if no other port is specified
Improvement: Revised e-mail configuration for push service
Improvement: Saving settings before updating with a FRITZ!OS file now with password
Improvement: Separate test mail for configuring each push service
WLAN:
Improved: Wireless LAN stability
Improvement: Display of wireless LAN registration data as QR code
Improvement: Printout of wireless LAN registration data separate for network and wireless guest access
Improvement: List of access points in wireless LAN environment sorted by reception field strength
Improvement: Stability and latency times improved for Repeater mode
Improvement: More stable and robust
Change: MAC address filter now under WLAN/Security
Change: Push service customizes e-mail subject lines
Home network:
Improvement: Display of the IPv4 address range assigned to guests
Improvement: Revised check of host name and FRITZ!Box name
Improvement: Adopt parental controls from the FRITZ!Box*
System/Security:
Improvement: Supports new mail systems (STARTTLS) for push mail
* Adopting parental controls requires a FRITZ!Box with recent FRITZ!OS verion, which supports the repeater function. You can find an overview of suitable FRITZ!Box and FRITZ!OS here:
http://en.avm.de/nc/service/fritzbox/fritzbox-7390/knowledge-base/publication/show/1483_Overview-of-FRITZ-Box-models-that-support-the-repeater-function/
** Automatic update: default configuration is "Notify me about new versions of FRITZ!OS and install necessary updates automatically (recommended)"
*** Using a mac-filter in the WLAN base station:
After updating the new FRITZ!OS some issues concerning the reconnect to the WLAN base station can exist caused by changed mac address. Please deactivate the mac filter in the WLAN base station temporarily and reactivate it after succesfully reconnected.
Download: >>>klick<<<
Es gibt jetzt eine 101.06.32i
Als deutsche Version gibt es nur die 6.30, als internationale die 6.32. Ich müsste also die internationale installieren, wenn ich die neuste Version haben möchte. Kann man die einfach so auf den Repeater spielen wie ein normales Update oder muss da vorher irgendetwas geändert werden?
Die Umstellung/Rebranding von der deutschen auf die internationale Version geschieht grob in zwei Schritten
1. das Branding des 300e ändern: firmware_version von "avm" in "avme" ändern
2. mit dem int. 06.32 Recovery-Tool eine Wiederherstellung fahren
Zu beiden sollte es hier im Forum genug Lesestoff geben, ansonsten noch einmal fragen. Die Default-IP-Adresse der 300e im Bootloader (adam2) ist bei mir sowohl auf "my_ipaddress = 169.254.209.1" als auch "my_ipaddress =192.168.178.1" eingestellt, ansonsten sicherheitshalber zuvor in den Supportdaten nachsehen.
Das Ändern der HW von der deutschen in die int. Version und umgekehrt ist sicherlich nicht von AVM vorgesehen/gewünscht, nicht unterstützt und geschieht natürlich auf eigene Gefahr.
Bei mir ist auch mit FRITZ!OS: 06.30 Schluss.
Da werde ich Mal versuchen herauszufinden, ob und wie ich meinen 300E auf international umstellen kann.
dane1
