[Problem] FritzBox 7369
mrelmar
10 Dez 2015
Hallo ich habe frittsboks 7369 und DECT-Telefon MT-F Fritz Problem ist, dass das Telefon nicht in die Fritz-Firmware 119.06.30 neuesten Baukosten, die beraten werden? Wie man das Problem lösen zu verbinden?
You should not use translator software.
Try to post your question in english (or french?).
I have fritz box 7369 firmware 119.06.30 and Fritz mt-f dect phone firmware 01.03.12 the problem no connect to fritz box can you help me?
The reason for the error is displayed on the cordless dect telephone.
Hello!My fritz box connect with other dect company but don t connect with fritz mt-f what is problem?
Can i update my fritz box firmware on the other version fritz box model?
When I registered new telephone in menu fritz box show me message The reason for the error is displayed on the cordless dect telephone.
Screen
Screen in menu.
Try again, but using DECT Eco unmarked.
Your MTF will ask for this if not: set PIN to it's default value 0000.
I used both of the versions but it didn t help me.
did you try to revert the fon to it's original factory default values ?
... The reason for the error is displayed on the cordless dect telephone.
And what is now the reason? What is displayed on the DECT-Phone?
A try:
Disable DECT-Eco, switch to "non-encrypted DECT connections" and activate "Troubleshooting for cordless telephones not compatible with GAP" (Edit 2: Is not necessary for a FritzFon).
http://en.avm.de/service/fritzbox/f...show/65_Cannot-register-a-cordless-telephone/
Edit: + Note from post #13!
Also, can you update to the latest stable (Ver. 6.30)? 6.11 is not the newest version.
ftp://ftp.avm.de/fritz.box/fritzbox.7369/firmware/english/
http://en.avm.de/service/fritzbox/fritzbox-7369/knowledge-base/publication/show/2_Updating-FRITZ-OS/
http://en.avm.de/service/fritzbox/f...ication/show/1574_Updating-FRITZ-OS-manually/
I update the firmware version fritz box 7369 at moment version 119.06.30 no help me dont connected disable eco no help.
Which frequency do you work fritz mt-f no information in the internet.
HKIPP
