7050 mit FW .33 an Kabelmodem: Verbindung timed alle paar Minuten aus
mindless
2 Okt 2005
Seit dem Update auf FW .33 hab ich das Problem, daß die Internetverbindung alle paar Minuten kurz einfriert. Ein laufender Ping sieht dann so aus:
64 bytes from sipgate.at (217.116.119.252): icmp_seq=191 ttl=51 time=60.3 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=192 ttl=51 time=35.8 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=193 ttl=51 time=28.0 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=194 ttl=51 time=40.5 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=195 ttl=51 time=25.0 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=196 ttl=51 time=32.9 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=197 ttl=51 time=27.2 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=198 ttl=51 time=40.2 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=199 ttl=51 time=59.8 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=200 ttl=51 time=24.8 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=202 ttl=51 time=14689 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=203 ttl=51 time=13690 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=204 ttl=51 time=12690 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=205 ttl=51 time=11691 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=206 ttl=51 time=10705 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=207 ttl=51 time=9706 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=208 ttl=51 time=8714 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=209 ttl=51 time=7719 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=210 ttl=51 time=6729 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=211 ttl=51 time=5737 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=212 ttl=51 time=4737 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=213 ttl=51 time=3737 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=214 ttl=51 time=2742 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=215 ttl=51 time=1748 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=216 ttl=51 time=754 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=217 ttl=51 time=26.7 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=218 ttl=51 time=43.1 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=219 ttl=51 time=41.3 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=220 ttl=51 time=28.8 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=221 ttl=51 time=38.5 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=222 ttl=51 time=28.2 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=223 ttl=51 time=27.5 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=224 ttl=51 time=70.5 ms
64 bytes from sipgate.at (217.116.119.252): icmp_seq=225 ttl=51 time=28.3 ms
Meine 7050 hängt als Router am Kabelmodem (kein DSL). Das Problem tritt auf allen Rechner im LAN auf, und wenn ich einen Rechner direkt an das Kabelmodem hänge, tritt das Problem nicht auf --> die Fritz!Box ist das Problem.
Wie oben erwähnt tritt der Fehler erst seit FW .33 auf.
Beim Surfen könnt ich die kurzen ausfälle ja verkraften (ist nur ärgerlich), aber telefonieren ist unmöglich und damit muß ich das Problem lösen!
Bitte um Hilfe,
Danke,
bye
Mindless.
ich hatte neulich dasselbe Problem, als ich auf meinen neuen Kabelanschluss umgestellt habe (alle ca. 10 Minuten für ca. 10 Sekunden eine Unterbrechung; Ping sah ziemlich ähnlich wie bei dir aus). Bei mir hat der Tipp aus dem Thread zur 33er Firmware geholfen, einen Werksreset zu machen und alle Einstellungen erneut von Hand vorzunehmen. Seitdem funktioniert mein Internetzugang über Fritzbox 7050 und Kabelmodem incl. VoIP ohne Probleme und Aussetzer.
Viele Grüße,
Andreas
Hallo Andreas,
Danke für den Tipp. Leider hatte ich dabei folgendes Problem:
Nach dem zurücksetzen, war plötzlich im Menü keine Möglichkeit mehr da den LAN-A Anschluß als Internetanschluss zu verwenden. Er wollte partout eine DSL Verbindung aufbauen. Auch sonst hatte ich den Eindruck, daß im Menü einige Punkte fehlten (so wie das Menü vor Urzeiten mal ausgesehen hat, möglicherweise zu dem Zeitpunkt wo meine betagte FB gebaut wurde).
Auch ein neuerliches FW .33 einspielen hat nichts gebracht (obwohl er eigentlich auch nach dem Zurücksetzen die FW .33 meldete).
Erst nachdem Einspielen meiner Settings tauchten die Menüeinträge wieder korrekt auf. - jetzt ist aber mein Problem wieder da :-(
Ideen?
bye
Marcus.
Du musst einfach nur unter Einstellungen -> System -> Ansicht die Expertenansicht aktivieren. Dann sind wieder alle Punkte da.
... und mal den Browsercache löschen. Das Einspielen der gesicherten Konfig bringt gar nichts, weil damit alle Fehler wiederhergestellt werden.
Danke! Das mit der Expertenansicht wars natürlich!
So, jetzt beobachte ich mal ob die Verbindungsabbrüche wieder auftauchen...
bye
Marcus.
Ansh
