7270 and asterisk registration problems
donnib
29 Okt 2009
I tried to search thru the forum and translate to find a solution for the problem i have. I hope that somebody can help me.
I have an internal Asterisk server which i want to register to with the fritzbox. It does register but then after a while it looses registration. Is this a known problem ? Can this be solved somehow ? I guess it´s a problem with how the fritz tries to get to the asterisk server thru WAN and not thru LAN but i hope that you guys can explain this.
btw i am using Firmware version 54.04.67
donnib
No one have experienced these problems i explained ?
I would really appreciate some help.
donnib, users here are quite ready to help, but they don't like to guess. The description of your environment is deficient, to say the least, and frankly doesn't allow for an answer to your problems.
I would suggest you create yourself a signature like most users of this forum have. But at least let us know in which network runs your asterisk (and on what ...) and the same for your fritzbox. Otherwise, I'm afraid, you will have to wait much longer for an answer.
Oh - and welcome to this forum! Maybe you would also like to tell us your language, we have quite a number of multilingual users on this board and you might even get a reply in your mother-tongue!
Cheers
Chris
Hi Chris,
True true so let´s start from the beginning.
I have a FreePBX server which is running fine. This server is on my local network with the ip 192.168.1.10. I have a Fritz!Box 7270 European model (annex a) which i am using as an extension 2337. My Fritz has the ip 192.168.1.1 and is also beeing used as a router for my ADSL connection.
Let me mention that before getting the Fritz i was using a Sipura SIP adaptor on the same extension and it worked perfect on the same server for more than a year. I made no changes to the server(freepbx) when i got the Fritz!Box.
The Fritz is connecting to the server with the local ip 192.168.1.10. After a reboot of the Fritz the fritz connects to the server and works, both incomming and outgoing calls works fine. After a while the connection to the Freepbx gives a 401 Unauthorized.
It seems to me from the asterisk logs that the Fritz!Box is trying to register to the asterisk with the external WAN ip and not the internal ip but then i don't understand why it works after a reboot.
Hopes this gives more information about the problem i am experiencing.
My native language is Danish or Romanian
Here is two examples. First one is when registering works after a reboot.
I have replaced my external IP with X.X.X.X just so you know when that appears.
pbx*CLI>
<--- SIP read from 192.168.1.1:5060 --->
REGISTER sip:192.168.1.10 SIP/2.0
Via: SIP/2.0/UDP X.X.X.X:5060;rport;branch=z9hG4bK6606A27E64C5106E
To: <sip:[email protected]>
Call-ID: [email protected]
CSeq: 1 REGISTER
Max-Forwards: 70
User-Agent: AVM FRITZ!Box Fon WLAN 7270 54.04.67 (Dec 17 2008)
Supported: 100rel,replaces
Allow-Events: telephone-event,refer,reg
Allow: INVITE,ACK,OPTIONS,CANCEL,BYE,UPDATE,PRACK,INFO,SUBSCRIBE,NOTIFY,REFER,MESSAGE,PUBLISH
Accept: application/sdp, multipart/mixed
Accept-Encoding: identity
Content-Length: 0
--- (14 headers 0 lines) ---
Using latest REGISTER request as basis request
Sending to 192.168.1.1 : 5060 (NAT)
<--- Transmitting (no NAT) to X.X.X.X:5060 --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK6606A27E64C5106E;received=192.168.1.1;rport=5060
CSeq: 1 REGISTER
User-Agent: asterisk
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces
Contact: <sip:[email protected]:5064>
Content-Length: 0
SIP/2.0 401 Unauthorized
To: <sip:[email protected]>;tag=as4d80c2ec
CSeq: 1 REGISTER
Supported: replaces
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="7cad675b"
Content-Length: 0
Scheduling destruction of SIP dialog '[email protected]' in 32000 ms (Method: REGISTER)
CSeq: 1 REGISTER
Max-Forwards: 70
Content-Length: 0
SIP/2.0 100 Trying
CSeq: 1 REGISTER
Supported: replaces
Content-Length: 0
CSeq: 1 REGISTER
Supported: replaces
Content-Length: 0
pbx*CLI>
Via: SIP/2.0/UDP X.X.X.X:5060;rport;branch=z9hG4bK96B1050140E7E641
CSeq: 2 REGISTER
Authorization: Digest username="2337", realm="asterisk", nonce="7cad675b", uri="sip:192.168.1.10", response="69df0426bcc1a53df5329a116c5f9f05", algorithm=MD5
Max-Forwards: 70
Content-Length: 0
--- (15 headers 0 lines) ---
SIP/2.0 100 Trying
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK96B1050140E7E641;received=192.168.1.1;rport=5060
CSeq: 2 REGISTER
Supported: replaces
Content-Length: 0
SIP/2.0 200 OK
CSeq: 2 REGISTER
Supported: replaces
Expires: 0
Date: Sun, 08 Nov 2009 20:03:51 GMT
Content-Length: 0
CSeq: 2 REGISTER
Max-Forwards: 70
Content-Length: 0
SIP/2.0 100 Trying
CSeq: 2 REGISTER
Supported: replaces
Content-Length: 0
SIP/2.0 200 OK
CSeq: 2 REGISTER
Supported: replaces
Expires: 0
Content-Length: 0
pbx*CLI>
Via: SIP/2.0/UDP 192.168.1.1:5060;rport;branch=z9hG4bKD56518830B05B962
CSeq: 3 REGISTER
Contact: <sip:[email protected];uniq=59A111F54C1A04C7F9F14CFDE22CB>
Expires: 1800
Max-Forwards: 70
Content-Length: 0
--- (17 headers 0 lines) ---
<--- Transmitting (no NAT) to 192.168.1.1:5060 --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bKD56518830B05B962;received=192.168.1.1;rport=5060
CSeq: 3 REGISTER
Supported: replaces
Content-Length: 0
Reliably Transmitting (no NAT) to 192.168.1.1:5060:
OPTIONS sip:[email protected];uniq=59A111F54C1A04C7F9F14CFDE22CB SIP/2.0
Via: SIP/2.0/UDP 192.168.1.10:5064;branch=z9hG4bK3bb20498;rport
From: "Unknown" <sip:[email protected]:5064>;tag=as3f1b945a
To: <sip:[email protected];uniq=59A111F54C1A04C7F9F14CFDE22CB>
CSeq: 102 OPTIONS
Max-Forwards: 70
Supported: replaces
Content-Length: 0
    -- Registered SIP '2337' at 192.168.1.1 port 5060 expires 1800
SIP/2.0 200 OK
CSeq: 3 REGISTER
Supported: replaces
Expires: 1800
Contact: <sip:[email protected];uniq=59A111F54C1A04C7F9F14CFDE22CB>;expires=1800
Content-Length: 0
CSeq: 3 REGISTER
Expires: 1800
Max-Forwards: 70
Content-Length: 0
SIP/2.0 100 Trying
CSeq: 3 REGISTER
Supported: replaces
Content-Length: 0
SIP/2.0 200 OK
CSeq: 3 REGISTER
Supported: replaces
Expires: 1800
Content-Length: 0
NOTIFY sip:[email protected];uniq=59A111F54C1A04C7F9F14CFDE22CB SIP/2.0
Via: SIP/2.0/UDP 192.168.1.10:5064;branch=z9hG4bK39b8c819;rport
From: "Unknown" <sip:[email protected]>;tag=as1784ebe7
To: <sip:sip:[email protected];uniq=59A111F54C1A04C7F9F14CFDE22CB>;tag=6803745
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: message-summary
Content-Type: application/simple-message-summary
Subscription-State: active
Content-Length: 88
Messages-Waiting: yes
Message-Account: sip:*[email protected]
Voice-Message: 4/1 (0/0)
pbx*CLI>
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.10:5064;branch=z9hG4bK3bb20498;rport=5064
To: <sip:[email protected];uniq=59A111F54C1A04C7F9F14CFDE22CB>;tag=9C0D50EC5F3B90B6
CSeq: 102 OPTIONS
Content-Type: application/sdp
Content-Length:   379
v=0
o=user 4803438 4803438 IN IP4 192.168.1.1
s=call
c=IN IP4 192.168.1.1
t=0 0
m=audio 7078 RTP/AVP 8 0 2 102 100 99 97 18 101
a=sendrecv
a=rtpmap:2 G726-32/8000
a=rtpmap:102 G726-32/8000
a=rtpmap:100 G726-40/8000
a=rtpmap:99 G726-24/8000
a=rtpmap:97 iLBC/8000
a=fmtp:97 mode=30
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-11
a=rtcp:7079
--- (15 headers 17 lines) ---
SIP/2.0 200 OK
CSeq: 102 OPTIONS
Content-Length:   379
v=0
s=call
t=0 0
a=sendrecv
a=fmtp:97 mode=30
a=fmtp:18 annexb=no
a=fmtp:101 0-11
a=rtcp:7079
Really destroying SIP dialog '[email protected]' Method: OPTIONS
SIP/2.0 200 OK
CSeq: 102 OPTIONS
Content-Length:   379
v=0
s=call
t=0 0
a=sendrecv
a=fmtp:97 mode=30
a=fmtp:18 annexb=no
a=fmtp:101 0-11
a=rtcp:7079
SIP/2.0 200 OK
CSeq: 102 OPTIONS
Content-Length:   379
v=0
s=call
t=0 0
a=sendrecv
a=fmtp:97 mode=30
a=fmtp:18 annexb=no
a=fmtp:101 0-11
a=rtcp:7079
SUBSCRIBE sip:[email protected]:5064 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.1:5060;rport;branch=z9hG4bK0799E4D7061AF4D4
To: <sip:[email protected]:5064>
CSeq: 4 SUBSCRIBE
Expires: 3600
Max-Forwards: 70
Allow: NOTIFY
Accept: application/simple-message-summary
Content-Length: 0
Creating new subscription
Found peer '2337'
Looking for 2337 in from-internal (domain 192.168.1.10)
Really destroying SIP dialog '[email protected]' Method: SUBSCRIBE
Scheduling destruction of SIP dialog '[email protected]' in 3610000 ms (Method: SUBSCRIBE)
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK0799E4D7061AF4D4;received=192.168.1.1;rport=5060
To: <sip:[email protected]:5064>;tag=as573b2b9c
CSeq: 4 SUBSCRIBE
Supported: replaces
Expires: 3600
Contact: <sip:[email protected]:5064>;expires=3600
Content-Length: 0
CSeq: 4 SUBSCRIBE
Expires: 3600
Max-Forwards: 70
Allow: NOTIFY
Content-Length: 0
Ignoring this SUBSCRIBE request
Found peer '2337'
SIP/2.0 200 OK
CSeq: 4 SUBSCRIBE
Supported: replaces
Expires: 3600
Content-Length: 0
SIP/2.0 481 Call Leg/Transaction Does Not Exist
Via: SIP/2.0/UDP 192.168.1.10:5064;branch=z9hG4bK39b8c819;rport=5064
CSeq: 102 NOTIFY
Content-Length: 0
--- (8 headers 0 lines) ---
CSeq: 102 NOTIFY
Content-Length: 0
CSeq: 102 NOTIFY
Content-Length: 0
CSeq: 102 NOTIFY
Content-Length: 0
pbx*CLI> sip set debug off
SIP Debugging Disabled
Here is the log from asterisk were it fails the registration.
pbx*CLI>
Via: SIP/2.0/UDP X.X.X.X:5060;rport;branch=z9hG4bKCF796DF26D0D1676
CSeq: 1 REGISTER
Max-Forwards: 70
User-Agent: AVM FRITZ!Box Fon WLAN 7270 54.04.76 (Sep 14 2009)
Content-Length: 0
SIP/2.0 100 Trying
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bKCF796DF26D0D1676;received=192.168.1.1;rport=5060
CSeq: 1 REGISTER
Supported: replaces
Content-Length: 0
To: <sip:[email protected]>;tag=as5e7e68d2
CSeq: 1 REGISTER
Supported: replaces
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="4c7bc77f"
Content-Length: 0
CSeq: 1 REGISTER
Max-Forwards: 70
Content-Length: 0
SIP/2.0 100 Trying
CSeq: 1 REGISTER
Supported: replaces
Content-Length: 0
CSeq: 1 REGISTER
Supported: replaces
Content-Length: 0
pbx*CLI>
Via: SIP/2.0/UDP X.X.X.X:5060;rport;branch=z9hG4bKA906D7DA47575293
CSeq: 2 REGISTER
Authorization: Digest username="2337", realm="asterisk", nonce="4c7bc77f", uri="sip:192.168.1.10", response="fb8fbeeeddeceeeb414aebb18c813d85", algorithm=MD5
Max-Forwards: 70
Content-Length: 0
SIP/2.0 100 Trying
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bKA906D7DA47575293;received=192.168.1.1;rport=5060
CSeq: 2 REGISTER
Supported: replaces
Content-Length: 0
SIP/2.0 200 OK
CSeq: 2 REGISTER
Supported: replaces
Expires: 1610
Contact: <sip:[email protected]:5064>;expires=1610
Date: Tue, 03 Nov 2009 20:52:31 GMT
Content-Length: 0
CSeq: 2 REGISTER
Max-Forwards: 70
Content-Length: 0
SIP/2.0 100 Trying
CSeq: 2 REGISTER
Supported: replaces
Content-Length: 0
SIP/2.0 200 OK
CSeq: 2 REGISTER
Supported: replaces
Expires: 1610
Content-Length: 0
pbx*CLI>
Via: SIP/2.0/UDP 192.168.1.1:5060;rport;branch=z9hG4bK67CFE67426C8E034
CSeq: 3 REGISTER
Expires: 1800
Max-Forwards: 70
Content-Length: 0
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK67CFE67426C8E034;received=192.168.1.1;rport=5060
CSeq: 3 REGISTER
Supported: replaces
Content-Length: 0
pbx*CLI>
SIP/2.0 200 OK
CSeq: 3 REGISTER
Supported: replaces
Expires: 1800
Content-Length: 0
pbx*CLI>
CSeq: 3 REGISTER
Expires: 1800
Max-Forwards: 70
Content-Length: 0
pbx*CLI>
SIP/2.0 100 Trying
CSeq: 3 REGISTER
Supported: replaces
Content-Length: 0
pbx*CLI>
SIP/2.0 200 OK
CSeq: 3 REGISTER
Supported: replaces
Expires: 1800
Content-Length: 0
pbx*CLI>
Via: SIP/2.0/UDP 192.168.1.1:5060;rport;branch=z9hG4bK1D3C4D6943847F3A
CSeq: 4 SUBSCRIBE
Expires: 3600
Max-Forwards: 70
Allow: NOTIFY
Content-Length: 0
Found peer '2337'
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK1D3C4D6943847F3A;received=192.168.1.1;rport=5060
To: <sip:[email protected]:5064>;tag=as6073ebb3
CSeq: 4 SUBSCRIBE
Supported: replaces
Expires: 3600
Content-Length: 0
Via: SIP/2.0/UDP 192.168.1.10:5064;branch=z9hG4bK7b501703;rport
From: "Unknown" <sip:[email protected]>;tag=as6073ebb3
To: <sip:sip:[email protected];uniq=59A111F54C1A04C7F9F14CFDE22CB>;tag=1885445596
CSeq: 102 NOTIFY
Max-Forwards: 70
Content-Length: 88
Voice-Message: 3/1 (0/0)
CSeq: 4 SUBSCRIBE
Expires: 3600
Max-Forwards: 70
Allow: NOTIFY
Content-Length: 0
Found peer '2337'
SIP/2.0 200 OK
To: <sip:[email protected]:5064>;tag=1885445596
CSeq: 4 SUBSCRIBE
Supported: replaces
Expires: 3600
Content-Length: 0
pbx*CLI>
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.10:5064;branch=z9hG4bK7b501703;rport=5064
CSeq: 102 NOTIFY
Content-Length: 0
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
pbx*CLI>
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
pbx*CLI>
donnib, thanks, that's already pretty good as info. I'm not really an expert on the matter and still hope that someone else in this forum comes to assistance.
My first reflex would be to think of a NAT problem. I don't think the fritzbox has a NAT setting, but have you tried in the sip.conf to set nat = yes ? I haven't used freepbx yet, are you allowed to edit the asterisk confs yourself or you have to do it through the interface?
Might be useful to post your sip.conf, at least the general and the fritzbox contexts. Sorry not to be of more assistance ...
Cheers
Chris
Thanks for your post.
I have tried enabling NAT on the extension and it still fails. :(
/donnib
Since nobody cares to respons is it because i described the problem in English or am i the only one running a Asterisk server internal and want to connect to it ?
@donnib: I didn't see your post before. I'm running some FritzBoxes (7270) and even more Asterisk's ;-) and never faced any problems. So I'm sure this can be solved. Please post you sip.conf.
On my Asterisk-Server (running on the 7270 itself) my sip.conf looks like this:
[general]
context=from-extern
bindport=5061
externhost=xxx.xxx.xx
srvlookup=no
language=de
canreinvite=no
register => XXXXXXXXXXX:[email protected]/NNNNNNNNNN
[1000]
context=from-intern
callerid=Mini <0>
host=dynamic
nat=no
qualify=yes
type=friend
secret=XXXXXX
I register the 7270s like this:
Provider    other Provider
Number     1000
Username  1000
Password   XXXXX
Registrar   192.168.178.1:5061
Proxy        (none)
STUN        (none)
That's basically it. It doesn't matter if this registration comes from the same FritzBox or the second one with a different IP. (All in the lokal network). This setup runs absolutely stable.
Good luck
Udo
