7270v3 new avm firmware 74.05.05 available/not used by freetz
RomMon
29 Aug 2011
As followup on thread http://www.ip-phone-forum.de/showthread.php?t=240245
I just tried trunk-7795 and found that 74.05.05 is not supported yet by Freetz.
I have some issues with 74.05.04 because it doesn't allow me to select different ATM-PVC than it autodetect. With 74.04.90 it dit work (without Freetz). And I would like to try 74.05.05.
Second question. is there a Freetz revision that makes use of 74.04.90 for the 7270v3?
Found that freetz-stable-1.2 (svn checkout http://svn.freetz.org/branches/freetz-stable-1.2 freetz-stable-1.2) and currently freetz-1.2_rc1 (wget http://freetz.org/downloads/freetz-1.2_rc1.tar.bz2) make use of 74.04.90.
Oliver,
Thanks a lot for applying this change so quick!
During make of revision 7796 I get an error:
Download failed - "http://freetz.magenbrot.net/fakeroot_1.17.orig.tar.bz2" -> error code 8
make: *** [dl/fakeroot_1.17.orig.tar.bz2] Error 1
Indeed on e.g. http://ftp.debian.org/debian/pool/main/f/fakeroot/ 1.17 is not there. The last version is fakeroot_1.18.1.orig.tar.bz2 made on 1-Oct.
I looked in changeset 7796 through 7802, but this was not yet addressed.
Edit: After copying fakeroot_1.17.orig.tar.bz2 from an older revision, make finished normally.
The image is also working on my 7270v3. I only tested ADSL so far.
Edit2: see that the fakeroot issue is soved in: http://freetz.org/changeset/7805
Ra67
