Wäre das nicht dann doppelt gemoppelt? Also ich brauche beide Dateien, die sip"mac" und die sep"mac"?
Hier mal mein Log:
Irgendwas mit UDP scheint da nicht zu stimmen. Immerhin holt er sich die richtige Zeit von der PTB.
EDIT: Anscheinend ist die sip"mac".cnf nicht mit dem 7970 kompatibel. Gibts da ne passende XML-Datei zu?
Hier mal mein Log:
|== Syslogd TNP== Tue Feb 5 02:47:58 2013
1436: INF 02:47:58.106127 child user cpu = 0.000000000 secs
1437: INF 02:47:58.106164 child sys cpu = 0.000000000 secs
1438: INF 02:47:58.106212 sys interrupts = 0.006425640 secs for 65 interrupts
1439: INF 02:47:58.106263 total cpu = 0.026762379 secs ( 25% utilization )
1440: NOT 02:47:58.132488 xxtpClient: request server6 0 ---> ::
1441: NOT 02:47:58.133594 xxtpClient: tftp request rcv'd from /usr/tmp/tftp, emccMode =0, emccLocalOverride=0, tempTftp1= , tempTftp2 = , tempTftp3 = , tempTftp4 =
1442: NOT 02:47:58.135536 JVM: setTempTftpAddress, emcc_mode=0,retEmccMode=0,LocalOverride=0,retLocalOverride=0, status=1
1443: NOT 02:47:58.415129 SECD: loadTvsSrvrCfg: Not in EMCC mode.Loading the flash file :/flash0/sec/misc/tvs.conf
1444: NOT 02:47:58.416962 ESP: server 2 = ::
1445: NOT 02:47:58.603260 JVM: emccMode=0,localOverride=0, tftpAddr1=, tftpAddr2=,tftpAddr3=,tftpAddr4=
1446: NOT 02:47:58.608080 xxtpClient: request server6 1 ---> ::
1447: NOT 02:47:58.609175 xxtpClient: tftp request rcv'd from /usr/tmp/tftp, emccMode =0, emccLocalOverride=0, tempTftp1= , tempTftp2 = , tempTftp3 = , tempTftp4 =
1448: NOT 02:47:58.614996 JVM: setTempTftpAddress, emcc_mode=0,retEmccMode=0,LocalOverride=0,retLocalOverride=0, status=1
1449: WRN 02:47:58.831767 JVM: Startup Module Loader|cip.l10n.UserLocaleProperty:? - Unable to process LocaleProperty 'device.settings.config.localization.userlocale'
1450: NOT 02:47:58.874141 JVM: Startup Module Loader|cip.midp.midletsuite.InstallerModule:? - propertyChanged - device.settings.config.localization.userlocale.charset value=ASCII
1451: NOT 02:47:58.876577 JVM: Startup Module Loader|cip.midp.midletsuite.InstallerModule:? - propertyChanged - device.settings.config.localization.userlocale.charset value=ASCII
1452: NOT 02:47:58.878802 JVM: Startup Module Loader|cip.midp.midletsuite.InstallerModule:? - propertyChanged - device.settings.config.localization.userlocale.languagecode value=en
1453: NOT 02:47:58.881114 JVM: Startup Module Loader|cip.midp.midletsuite.InstallerModule:? - propertyChanged - device.settings.config.localization.userlocale.languagecode value=en
1454: WRN 02:47:58.883524 JVM: Startup Module Loader|cip.l10n.NetworkLocaleProperty:? - Unable to process LocaleProperty 'device.settings.config.localization.networklocale'
1455: WRN 02:47:58.967228 SECD: WARN:lookupCTL: ** no CTL, assume UCM NONSECURE
1456: ERR 02:47:59.434735 JVM: ..LOCALCONNECT FAILED
1457: NOT 02:47:59.508077 JVM: SIPCC-SIP_CTRL: sip_restart: In sip_restart
1458: NOT 02:47:59.524712 JVM: set_active_ccm: ccm=PRIMARY_CCM port=0
1459: ERR 02:47:59.525747 JVM: SIP : sip_transport_setup_cc_conn : Admin has not configured a valid cucm for cucm index=SECONDARY_CCM=1.
1460: ERR 02:47:59.526801 JVM: SIP : sip_transport_setup_cc_conn : Admin has not configured a valid cucm for cucm index=TERTIARY_CCM=2.
1461: ERR 02:47:59.527777 JVM: SIP : sip_transport_setup_cc_conn : Admin has not configured a valid cucm for cucm index=SRST_CCM=3.
1462: ERR 02:47:59.528728 JVM: sip_regmgr_setup_cc_conns: NO VALID STANDBY CALL CONTROL AVAILABLE!
1463: NOT 02:47:59.529741 JVM: SIPCC-SIP_REG: sip_sm_init: Disabling mass reg state
1464: NOT 02:47:59.572304 JVM: SIPCC-SIP_REG: ccsip_register_all_lines: Disabling mass reg state
1465: NOT 02:47:59.573663 JVM: SIPCC-UI_API: 1/0, ui_set_sip_registration_state: 0
1466: NOT 02:47:59.577446 JVM: SIPCC-CC_API: 0/0, cc_int_feature: UI -> GSM: UPD_MEDIA_CAP
1467: NOT 02:47:59.578720 JVM: SIPCC-SIP_CTRL: sip_restart: sip.taskInited is set to true
1468: NOT 02:47:59.579781 JVM: SIPCC-CC_API: 0/0, cc_int_fail_fallback: SIP -> GSM: FAILOVER_FALLBACK
1469: NOT 02:47:59.584323 JVM: SIPCC-DCSM: dcsm_process_event: DCSM 0 :(DCSM_READY:FEAT:UPD_MEDIA_CAP)
1470: NOT 02:47:59.590733 JVM: SIPCC-SIP_MSG_SEND: ccsip_dump_send_msg_info: <192.168.0.1:5060>:REFER s: <sip:192.168.0.1> :1000 REFER::[email protected]
1471: NOT 02:47:59.593622 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1472: NOT 02:47:59.595046 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_IDLE <- E_SIP_REG_REG_REQ
1473: NOT 02:47:59.597962 JVM: ccsip_messaging: sipSPIAddContactHeader: CFGID_DEVICE_NAME = SEP0018733A1D16
1474: NOT 02:47:59.602171 JVM: SIPCC-SIP_MSG_SEND: ccsip_dump_send_msg_info: <192.168.0.1:5060>:REGISTE: <sip:[email protected]> :102 REGISTER::[email protected]
1475: NOT 02:47:59.604889 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1476: NOT 02:47:59.946831 JVM: Startup Module Loader|cip.sipcc.SipCcAdapter: - cmname=192.168.0.1 cmIp=192.168.0.1 port=5060 isValid=true
1477: ERR 02:47:59.949507 JVM: Startup Module Loader|cip.sipcc.SipCcAdapter: - addSrstToCAgentList: isSrstSecure=false
1478: NOT 02:47:59.951779 JVM: Startup Module Loader|cip.midp.midletsuite.InstallerModule:? - propertyChanged - device.callagent.messages.0 value=0
1479: NOT 02:47:59.954204 JVM: Startup Module Loader|cip.sipcc.d: - initializeLinePlane(): Mgmt Interface is in Service now..
1480: WRN 02:47:59.956301 JVM: Startup Module Loader|DisplayTask:? - Line 1 property added with dn 620
1481: ERR 02:47:59.958433 JVM: Startup Module Loader|cip.props.u:? - device.settings.energywise.keywords IO error.
1482: ERR 02:48:00.018847 JVM: tftpClient dialplan.xml /usr/cache/DP-1619593489 550001 1
1483: NOT 02:48:00.029406 JVM: Startup Module Loader|cip.cfg.ConfigManager:? - --->ConfigManager PropertyChanged: device.callagent.callcount
1484: NOT 02:48:00.031769 JVM: Startup Module Loader|cip.cfg.ConfigManager:? - <---ConfigManager PropertyChanged: device.callagent.callcount
1485: NOT 02:48:00.034080 JVM: Startup Module Loader|cip.midp.midletsuite.InstallerModule:? - propertyChanged - device.callagent.messages.0 value=0
1486: NOT 02:48:00.035853 xxtpClient: xxtp request rcv'd from /usr/tmp/tftp, srcFile = dialplan.xml, dstFile = /usr/cache/DP-1619593489 max size = 550001
1487: NOT 02:48:00.038622 ESP: server 3 = ::
1488: NOT 02:48:00.057646 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
1489: NOT 02:48:00.063215 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1490: NOT 02:48:00.066620 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1491: NOT 02:48:00.069046 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1492: NOT 02:48:00.089378 xxtpClient: auth server - tftpList[0] = ::ffff:192.168.0.2
1493: NOT 02:48:00.091889 xxtpClient: look up server - 0
1494: WRN 02:48:00.095065 SECD: WARN:lookupCTL: ** no CTL, assume TFTP NONSECURE
1495: NOT 02:48:00.099264 xxtpClient: secVal = 0xa
1496: NOT 02:48:00.100441 xxtpClient: ::ffff:192.168.0.2 is a NONsecure server
1497: NOT 02:48:00.101282 xxtpClient: temp retval = SRVR_NONSECURE, keep looking
1498: NOT 02:48:00.102166 xxtpClient: retval = 10
1499: NOT 02:48:00.102998 xxtpClient: Secure file requested
1500: NOT 02:48:00.103790 xxtpClient: Non secure file approved -- dialplan.xml
1501: NOT 02:48:00.132445 HTTPCL: downdload will be limited to 537 KB
1502: ERR 02:48:00.142520 HTTPCL: connect() failed
1503: NOT 02:48:00.154000 SYSMSG: pid 19 (/sbin/httpcl) Normal Exit, status = 102
1504: INF 02:48:00.154072 runtime = 0.040 secs
1505: INF 02:48:00.154118 user cpu = 0.001987804 secs
1506: INF 02:48:00.154162 system cpu = 0.017446777 secs
1507: INF 02:48:00.154199 child user cpu = 0.000000000 secs
1508: INF 02:48:00.154239 child sys cpu = 0.000000000 secs
1509: INF 02:48:00.154282 sys interrupts = 0.000740974 secs for 8 interrupts
1510: INF 02:48:00.154331 total cpu = 0.019434581 secs ( 25% utilization )
1511: WRN 02:48:00.174360 xxtpClient: HTTP failed with code 102
1512: NOT 02:48:00.232480 TFTP: [26]:Requesting dialplan.xml from 192.168.0.2 with size limit of 550001
1513: NOT 02:48:00.245095 TFTP: [26]:Finished --> rcvd 70 bytes
1514: NOT 02:48:00.428879 xxtpClient: request server6 0 ---> ::
1515: NOT 02:48:00.467592 xxtpClient: request server 0 ---> 192.168.0.2
1516: NOT 02:48:00.469344 ESP: server 0 = 192.168.0.2
1517: NOT 02:48:00.491910 xxtpClient: request server6 1 ---> ::
1518: ERR 02:48:00.502443 JVM: ..LOCALCONNECT FAILED
1519: ERR 02:48:00.507431 JVM: ..LOCALCONNECT FAILED
1520: ERR 02:48:00.517610 JVM: ..LOCALCONNECT FAILED
1521: ERR 02:48:00.524446 JVM: ..LOCALCONNECT FAILED
1522: ERR 02:48:00.529405 JVM: ..LOCALCONNECT FAILED
1523: ERR 02:48:00.534572 JVM: ..LOCALCONNECT FAILED
1524: ERR 02:48:00.539624 JVM: ..LOCALCONNECT FAILED
1525: NOT 02:48:00.555862 xxtpClient: request server 1 --->
1526: NOT 02:48:00.557512 ESP: server 1 =
1527: WRN 02:48:00.564973 SECD: WARN:getTLInfoFromFile: ** phone has no TL file /flash0/sec/ctl//CTLFile.tlv
1528: WRN 02:48:00.566417 SECD: WARN:getTLInfoFromFile: ** phone has no TL file /flash0/sec/ctl//ITLFile.tlv
1529: WRN 02:48:00.574285 SECD: WARN:getTLInfoFromFile: ** phone has no TL file /flash0/sec/ctl//CTLFile.tlv
1530: WRN 02:48:00.575689 SECD: WARN:getTLInfoFromFile: ** phone has no TL file /flash0/sec/ctl//ITLFile.tlv
1531: WRN 02:48:00.584808 SECD: WARN:getTLInfoFromFile: ** phone has no TL file /flash0/sec/ctl//CTLFile.tlv
1532: WRN 02:48:00.586229 SECD: WARN:getTLInfoFromFile: ** phone has no TL file /flash0/sec/ctl//ITLFile.tlv
1533: WRN 02:48:00.593740 SECD: WARN:getTLInfoFromFile: ** phone has no TL file /flash0/sec/ctl//CTLFile.tlv
1534: WRN 02:48:00.595239 SECD: WARN:getTLInfoFromFile: ** phone has no TL file /flash0/sec/ctl//ITLFile.tlv
1535: NOT 02:48:00.628702 xxtpClient: request server6 0 ---> ::
1536: NOT 02:48:00.630524 ESP: server 2 = ::
1537: NOT 02:48:00.656720 xxtpClient: request server 0 ---> 192.168.0.2
1538: NOT 02:48:00.679524 xxtpClient: request server6 1 ---> ::
1539: NOT 02:48:00.684161 ESP: server 3 = ::
1540: NOT 02:48:00.725709 xxtpClient: request server 1 --->
1541: NOT 02:48:00.770333 CDP-D: cdpGetPortCfg SPANTOPC CFG:11
1542: NOT 02:48:00.908044 xxtpClient: request server6 0 ---> ::
1543: NOT 02:48:00.928724 xxtpClient: request server6 1 ---> ::
1544: ERR 02:48:00.936296 JVM: ..LOCALCONNECT FAILED
1545: ERR 02:48:00.942914 JVM: ..LOCALCONNECT FAILED
1546: ERR 02:48:00.947944 JVM: ..LOCALCONNECT FAILED
1547: ERR 02:48:00.953047 JVM: ..LOCALCONNECT FAILED
1548: ERR 02:48:00.958017 JVM: ..LOCALCONNECT FAILED
1549: ERR 02:48:00.969356 JVM: ..LOCALCONNECT FAILED
1550: ERR 02:48:00.974660 JVM: ..LOCALCONNECT FAILED
1551: NOT 02:48:01.076457 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1552: NOT 02:48:01.080186 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1553: NOT 02:48:01.082504 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1554: ERR 02:48:01.206262 JVM: ..LOCALCONNECT FAILED
1555: WRN 02:48:01.211339 JVM: Startup Module Loader|DisplayTask:? - acceptEWPowerSetting(): level 10
1556: ERR 02:48:01.214655 JVM: Startup Module Loader|cip.props.u:? - device.settings.energywise.phonepowerlevel IO error.
1557: NOT 02:48:03.073317 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1558: NOT 02:48:03.076559 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1559: NOT 02:48:03.078799 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1560: NOT 02:48:07.152957 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1561: NOT 02:48:07.156201 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1562: NOT 02:48:07.158466 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1563: NOT 02:48:11.152936 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1564: NOT 02:48:11.156171 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1565: NOT 02:48:11.158474 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1566: NOT 02:48:15.153000 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1567: NOT 02:48:15.157048 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1568: NOT 02:48:15.159297 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1569: NOT 02:48:19.183032 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1570: NOT 02:48:19.186324 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1571: NOT 02:48:19.188581 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1572: NOT 02:48:23.183052 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1573: NOT 02:48:23.186354 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1574: NOT 02:48:23.188578 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1575: NOT 02:48:27.183108 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1576: NOT 02:48:27.186340 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1577: NOT 02:48:27.188581 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1578: NOT 02:48:31.183022 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1579: NOT 02:48:31.186260 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1580: NOT 02:48:31.188569 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1581: NOT 02:48:31.681561 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_ACK
1582: ERR 02:48:31.683033 JVM: %REG auth failed: ack timer
1583: NOT 02:48:31.684175 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1584: NOT 02:48:31.685246 JVM: sip_platform_udp_channel_close:closed listening UDP socket
1585: NOT 02:48:31.696229 JVM: set_active_ccm: ccm=PRIMARY port=-1
1586: ERR 02:48:31.697331 JVM: SIPCC-LINE_NUM: sip_platform_localexpires_timer_stop: Error: Line number (88) is invalid
1587: NOT 02:48:31.698981 JVM: SIPCC-UI_API: 1/0, ui_set_sip_registration_state: 0
1588: NOT 02:48:31.701635 JVM: SIPCC-UI_API: 0/0, ui_set_notification: Registering: 123:20
1589: ERR 02:48:35.181709 JVM: SIP : subsmanager_handle_retry_timer_expire : Either exceeded max retries for UDP or Timer F fired for TCP
1590: NOT 02:48:35.184924 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1591: NOT 02:48:35.187147 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1592: NOT 02:48:36.183485 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1593: NOT 02:48:36.185720 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1594: NOT 02:48:38.183445 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1595: NOT 02:48:38.185695 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1596: NOT 21:52:54.311649 NTP: Local clock reset to NTP reference.
1597: NOT 21:52:55.183445 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1598: NOT 21:52:55.185693 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1599: NOT 21:52:59.183458 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1600: NOT 21:52:59.185723 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1601: NOT 21:53:03.183463 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1602: NOT 21:53:03.185697 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1603: NOT 21:53:07.183482 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1604: NOT 21:53:07.185815 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1605: NOT 21:53:11.188423 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1606: NOT 21:53:11.190744 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1607: NOT 21:53:15.183482 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1608: NOT 21:53:15.185792 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1609: NOT 21:53:19.183445 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1610: NOT 21:53:19.185699 JVM: sip_platform_udp_channel_destroy:closed UDP socket successfully
1611: ERR 21:53:20.577920 JVM: Calling enable listening for incoming http connections
1612: NOT 21:53:23.183453 JVM: SIPCC-SIP_REG_STATE: 1/51, sip_reg_sm_process_event: SIP_REG_STATE_REGISTERING <- E_SIP_REG_TMR_RETRY
1613: ERR 21:53:23.212879 JVM: Calling enable listening for incoming http connections
1614: ERR 21:53:24.030370 JVM: Calling enable listening for incoming http connections
1615: ERR 21:53:24.031283 JVM: Calling enable listening for incoming http connections
