Asterisk stürzt unregelmässig ab
Drenec
14 Jul 2006
Hallo, ich habe hier einen Asterisk 1.2.7.1-BRIstuffed-0.3.0-PRE-1o am laufen, dieser stürzt aber in unregelmässigen Abständen einfach ab.
Die letzt Info in den Logfiles des Asterisk ist folgende:
Aug 15 12:24:27 VERBOSE[13605] logger.c: -- Channel 0/1, span 1 received AOC-E charging 0 units
Aug 15 12:24:27 DEBUG[21986] channel.c: Didn't get a frame from channel: Zap/1-1
Aug 15 12:24:27 DEBUG[21986] channel.c: Bridge stops bridging channels Zap/4-1 and Zap/1-1
Aug 15 12:24:27 DEBUG[21986] chan_zap.c: Set option AUDIO MODE, value: ON(1) on Zap/1-1
Aug 15 12:24:27 DEBUG[21986] chan_zap.c: Hangup: channel: 1 index = 0, normal = 15, callwait = -1, thirdcall = -1
Aug 15 12:24:27 DEBUG[21986] chan_zap.c: Not yet hungup... Calling hangup once with icause, and clearing call
Aug 15 12:24:27 DEBUG[21986] chan_zap.c: disabled echo cancellation on channel 1
Aug 15 12:24:27 DEBUG[21986] chan_zap.c: Set option TDD MODE, value: OFF(0) on Zap/1-1
Aug 15 12:24:27 DEBUG[21986] chan_zap.c: Updated conferencing on 1, with 0 conference users
Aug 15 12:24:27 DEBUG[21986] chan_zap.c: Set option AUDIO MODE, value: OFF(0) on Zap/1-1
Aug 15 12:24:27 VERBOSE[21986] logger.c: -- Hungup 'Zap/1-1'
Aug 15 12:24:27 DEBUG[21986] app_dial.c: Exiting with DIALSTATUS=ANSWER.
Aug 15 12:24:27 VERBOSE[21986] logger.c: -- Executing Goto("Zap/4-1", "ds-ANSWER|1") in new stack
Aug 15 12:24:27 VERBOSE[21986] logger.c: -- Goto (macro-tsblcr,ds-ANSWER,1)
Aug 15 12:24:27 VERBOSE[21986] logger.c: -- Executing Goto("Zap/4-1", "end|1") in new stack
Aug 15 12:24:27 VERBOSE[21986] logger.c: -- Goto (macro-tsblcr,end,1)
Aug 15 12:24:27 DEBUG[21986] pbx.c: Expression result is '1'
Aug 15 12:24:27 VERBOSE[21986] logger.c: -- Executing GotoIf("Zap/4-1", "1?10") in new stack
Aug 15 12:24:27 VERBOSE[21986] logger.c: -- Goto (macro-tsblcr,end,10)
Aug 15 12:24:27 VERBOSE[21986] logger.c: -- Executing Goto("Zap/4-1", "restart|1") in new stack
Aug 15 12:24:27 VERBOSE[21986] logger.c: -- Goto (macro-tsblcr,restart,1)
Aug 15 12:24:27 VERBOSE[21986] logger.c: -- Executing Wait("Zap/4-1", "1.0") in new stack
Aug 15 12:24:28 DEBUG[13606] chan_zap.c: Received REMOTE_HOLD notification on NETWORK channel. Starting MoH
Leider hab ich keinen Plan was das bedeutet und im Netz ist zur letzten Zeile auch nichts brauchbares zufinden.
Hoffe irgendwer hat ne Idee woran es leigen könnte
mfg
prüfe ob Asterisk ohne Modul chan_zap.c noch abstürtzt!
#in etc/asterisk/modules.conf auskommentieren
nano etc/asterisk/modules.conf
noload =>chan_zap.c
#eintragen
könnte am ISDN liegen!
Darf ich fragen welcher Chipsatz im PC steckt? Ich hatte auch Probleme mit Abstürzen. Lag am Motherboard-Chipsatz, der ein fehlerhaftes Timing hatte.
Wenn dein Board zwei bis 4 Jahre alt ist, schau mal ob sich beiden Elkos um den Chipsatz die Deckel nach oben wölben.
Wenn die Dinger sterben kommt es erst zu irq-Problemen und später ist das Verhalten überhaupt nicht mehr vorhersehbar.
Sieht nach einem MusicOnHold Problem aus. Entweder mal den MoH Player austauschen oder MoH ganz abschalten.
Gruß,
Tin
figo12
