[Problem] AVM WebIF doesn't work
M66B
17 Feb 2010
I already tried to go back a few trunk revisions, but I cannot get the AVM WebIF to work again :-(
I believe this is the cause:
root@fritz:/var/media/ftp/uData# ctlmgr -f -v
ctlmgr: 2012-05-20 12:04:36(1) [Segmentation fault] /usr/bin/avm/ctlmgr(7188) CRASHED at (null)+0x2aabecb4 (/lib/libctlmgr.so at 00000cb4) accessing 00000000 (?)
ctlmgr: ze: 00000000 at: 00000001 v0: 2ada6048 v1: 2aabefd8
ctlmgr: a0: 00000001 a1: 00000001 a2: 2b344a40 a3: 00000001
ctlmgr: t0: 00000000 t1: fffffffe t2: 00000000 t3: fffffff0
ctlmgr: t4: 00000001 t5: 2b3d9000 t6: 00000400 t7: 2aabeb2c
ctlmgr: s0: 00000001 s1: 2b3449c0 s2: 2b344940 s3: 00000001
ctlmgr: s4: 2ad8bcbf s5: 2aabe000 s6: 2aabeff0 s7: 2aabefe4
ctlmgr: t8: 0000001f t9: 2aabee30 k0: 00000001 k1: 00000000
ctlmgr: gp: 2aad7010 sp: 7fa54b90 fp: 2aabe000 ra: 2aabeb2c
ctlmgr: Code: 8fbc0018  8fa31020  8e100000 <5600ffd3> 8e020004  8f99804c  0320f809  02202021  8fbc0018
ctlmgr: [bt] Number of functions: 6
ctlmgr: [bt] (null)+0x2aabeb24 (/lib/libctlmgr.so at 00000b24)
ctlmgr: [bt] ((null)+0x2aabea10)+0x114 (/lib/libctlmgr.so at 00000a10)
ctlmgr: [bt] ((null)+0x2aff40dc)+0x90 (/usr/share/ctlmgr/libctlusb.so at 000070dc)
ctlmgr: [bt] ((null)+0x423d98)+0x100 (/usr/bin/avm/ctlmgr at 00023d98)
ctlmgr: [bt] instantiate_module+0x140 (/usr/bin/avm/ctlmgr at 0001219c)
ctlmgr: [bt] main+0xed8 (/usr/bin/avm/ctlmgr at 0000e280)
but I don't know how to fix it.
I am using a 7270v2 international with 54.05.06-freetz-devel-9085.
Any help is highly appreciated!
Do you use the preload library for ctlmgr? If so, try without. If that helps, you could experiment with the different options for that library.
I have no idea what a preload library for ctlmgr is, so I guess not, but maybe I use something like that not knowing.
If you like you can answer in German (I can read it quite good, but it is better if I write English ;-) )
Thanks for your answer!
Edit: maybe the problem is libctlmgr_WITH_STRUCT_V3 ?
Anhang anzeigen config.txt
Edit #2: I guess you mean ticket #1648 ?
I am trying without these patches in a minute ...
I'm relatively sure that 54.05.06 only has STRUCT_V2.
Without
- Disable multid's DNS
- Disable multid's DHCP
is works again.
Edit: too fast: it doesn't work :-(
Then this might need a fix.
Just let me know if testing is needed.
The settings for multid should affect only multid, not ctlmgr.
You can try to start ctlmgr with /usr/bin/avm/ctlmgr. Be aware that it wil overwrite your /etc/passwd.
If you have libctlmgr_WITH_STRUCT_V3 at the moment, try libctlmgr_WITH_STRUCT_V2.
/usr/bin/avm/ctlmgr works
I will try with libctlmgr_WITH_STRUCT_V2 and report back.
I already quick fixed Config.in.has_avm and compiled, but I have to wait until I can reboot the box ...
Thanks, Oliver, I will try it in a minute and report if the patch works.
In any case I can confirm that libctlmgr_WITH_STRUCT_V3 is the problem.
Edit: patch works for me, thanks!
figo12
