Betamax trail call reduction
baseman007
2 Mrz 2007
Sorry for the english post, but I couldn't register on the VoipBuster forum.
I have been trying out VoipDiscount and LowrateVoip, but the trial calls for the free destinations with the softphone-client only lasts a couple of minutes. But I have read, you are suppose to make trial calls lasting for 60 minutes. I would like to try to make a real call and not have to be disconnected after a couple of minutes. Has Betamax changed its trail call limitation, or is it only for some of the providers?
Again I apologize for the english post, but I would appreciate it, if anyone could help me.
Thanks in advance from baseman007
Do you have credit? Without it doesn't work for an hour.
Hi kombjuder,
Thanks for the reply. I have been looking on the VoipBuster site, and if you look here: http://www.voipbuster.com/en/free.html under Fair Use and Restrictions, it says: "New users can try VoipBuster out for free for a total of 60 minutes. During this trial period you can only call the destinations marked as free." And correct me, if I am wrong, is VoipBuster not the main Betamax provider, and shouldn't it then be the same for the other providers too.
I think you(kombjuder) are talking about the free trail calls you can make through the provider webpages. They only lasts a couple of minutes, but with the softphone-client and a registred user you should be able to call free for a total of 60 minutes.
/baseman007
"For a total of sixty minutes" doesn't mean "one call that lasts 60 minutes". If betamax decided to change the spreading of that 60 minutes to several 5-minute-calls, there's nothing wrong with that restriction.
Anyway I don't know if they really changed that rule. It's just an idea that could explain it.
stefan311
