Can't build my custom freetz
I compiled successfully on a virtual machine with VirtualBox and ubuntu 8.10 as guest (fully updated)
On the same computer, the host OS (Debian Unstable) exit with squashfs error. -> Pentium M 1.73ghz @ 32bit
On another computer with Debian unstable too and the same config file I've the squashfs problem -> Core 2 Duo Mobile 2.0 Ghz @ 32bit
ok, uploaded...
Now I've another problem :(
Opening Freetz Config or Freetz WOL I get a 404 error...
Can you all try the attached patch?
Just save the patch file to tools/make/patches/ and run "make squashfs3-dirclean; make".
  • 150-malloc_size.squashfs3.zip
I'm able to compile with the latest revision without any patch on Debian!
The patch is included in the latest SVN version.
I also notified the author of squashfs. Hopefully it will be fixed in the next version.
AA-Idealbau
