Feb 9 22:17:18 asterisk1 init: Entering runlevel: 3
Feb 9 22:17:18 asterisk1 microcode_ctl: microcode_ctl startup succeeded
Feb 9 22:17:19 asterisk1 DIVAS4LINUX: Load Diva DIDD driver ...
Feb 9 22:17:19 asterisk1 DIVAS4LINUX: Warning: kernel-module version mismatch
Feb 9 22:17:19 asterisk1 DIVAS4LINUX: /usr/lib/eicon/divas/divadidd.o was compiled for kernel version 2.4.21-32.EL
Feb 9 22:17:19 asterisk1 DIVAS4LINUX: while this kernel is version 2.4.21-37.0.1.EL
Feb 9 22:17:19 asterisk1 DIVAS4LINUX: Warning: loading /usr/lib/eicon/divas/divadidd.o will taint the kernel: forced load
Feb 9 22:17:19 asterisk1 DIVAS4LINUX: See http://www.tux.org/lkml/#export-tainted for information about tainted modules
Feb 9 22:17:19 asterisk1 DIVAS4LINUX: Module divadidd loaded, with warnings
Feb 9 22:17:19 asterisk1 DIVAS4LINUX: OK
Feb 9 22:17:19 asterisk1 DIVAS4LINUX: Load Diva XDI driver ... Warning: kernel-module version mismatch
Feb 9 22:17:19 asterisk1 DIVAS4LINUX: /usr/lib/eicon/divas/divas.o was compiled for kernel version 2.4.21-32.EL
Feb 9 22:17:19 asterisk1 DIVAS4LINUX: Warning: loading /usr/lib/eicon/divas/divas.o will taint the kernel: forced load
Feb 9 22:17:19 asterisk1 DIVAS4LINUX: Check for saved MAINT debug/trace buffer ...
Feb 9 22:17:19 asterisk1 DIVAS4LINUX: idle
Feb 9 22:17:19 asterisk1 DIVAS4LINUX: Write Diva configuration to CFGLib ...
Feb 9 22:17:19 asterisk1 DIVAS4LINUX: succeeded
Feb 9 22:17:19 asterisk1 DIVAS4LINUX: Start adapter Nr:1 - 'Diva Server V-BRI-2', SN: 36800 ...
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: OK
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: Save Diva Server V-BRI-2 SN:36800 initial XLOG to /var/log/diva1.log ...
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: Load Diva IDI driver ... Warning: kernel-module version mismatch
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: /usr/lib/eicon/divas/diva_idi.o was compiled for kernel version 2.4.21-32.EL
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: while this kernel is version 2.4.21-37.0.1.EL
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: Warning: loading /usr/lib/eicon/divas/diva_idi.o will taint the kernel: forced load
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: See http://www.tux.org/lkml/#export-tainted for information about tainted modules
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: Module diva_idi loaded, with warnings
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: Load Diva MTPX driver ...
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: Load optimized Diva CAPI driver ... not available
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: Load KERNELCAPI driver ...
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: Warning: kernel-module version mismatch
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: /usr/lib/eicon/divas/kernelcapi.o was compiled for kernel version 2.4.21-32.EL
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: Warning: loading /usr/lib/eicon/divas/kernelcapi.o will taint the kernel: forced load
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: Module kernelcapi loaded, with warnings
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: Load Diva CAPI driver ... Warning: kernel-module version mismatch
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: /usr/lib/eicon/divas/divacapi.o was compiled for kernel version 2.4.21-32.EL
Feb 9 22:17:22 asterisk1 DIVAS4LINUX: Warning: loading /usr/lib/eicon/divas/divacapi.o will taint the kernel: forced load
Feb 9 22:17:23 asterisk1 DIVAS4LINUX: OK
Feb 9 22:17:23 asterisk1 DIVAS4LINUX: Load CAPI driver ... Warning: kernel-module version mismatch
Feb 9 22:17:23 asterisk1 DIVAS4LINUX: /usr/lib/eicon/divas/capi.o was compiled for kernel version 2.4.21-32.EL
Feb 9 22:17:23 asterisk1 DIVAS4LINUX: while this kernel is version 2.4.21-37.0.1.EL
Feb 9 22:17:23 asterisk1 DIVAS4LINUX: Warning: loading /usr/lib/eicon/divas/capi.o will taint the kernel: forced load
Feb 9 22:17:23 asterisk1 DIVAS4LINUX: See http://www.tux.org/lkml/#export-tainted for information about tainted modules
Feb 9 22:17:23 asterisk1 DIVAS4LINUX: Module capi loaded, with warnings
Feb 9 22:17:23 asterisk1 DIVAS4LINUX: Initialize Diva call history ...
Feb 9 22:17:23 asterisk1 divalogd[2940]: started
Feb 9 22:17:23 asterisk1 rc: Starting DIVAS4LINUX: succeeded
.Feb 9 22:17:53 asterisk1 kernel: capifs: Rev 1.1.4.1
Feb 9 22:17:53 asterisk1 kernel: b1: revision 1.1.4.1
Feb 9 22:17:53 asterisk1 kernel: b1dma: revision 1.1.4.1
Feb 9 22:17:53 asterisk1 kernel: b1pci: revision 1.1.4.1
Feb 9 22:17:53 asterisk1 kernel: kcapi: driver b1pci attached
Feb 9 22:17:53 asterisk1 kernel: b1pciv4: revision 1.1.4.1
Feb 9 22:17:53 asterisk1 kernel: kcapi: driver b1pciv4 attached
Feb 9 22:17:53 asterisk1 kernel: b1pci: NO B1-PCI card detected
Feb 9 22:17:53 asterisk1 kernel: kcapi: driver b1pci detached
Feb 9 22:17:53 asterisk1 kernel: kcapi: driver b1pciv4 detached
Feb 9 22:17:53 asterisk1 kernel: c4: revision 1.1.4.1
Feb 9 22:17:53 asterisk1 kernel: kcapi: driver c4 attached
Feb 9 22:17:53 asterisk1 kernel: c2: revision 1.1.4.1
Feb 9 22:17:53 asterisk1 kernel: kcapi: driver c2 attached
Feb 9 22:17:53 asterisk1 kernel: c4: NO C4/C2 card detected
Feb 9 22:17:53 asterisk1 kernel: kcapi: driver c4 detached
Feb 9 22:17:53 asterisk1 kernel: kcapi: driver c2 detached
