Dropbear and vsftp in WAN interface
vasila
7 Mai 2008
Hello,
Is possible to use dropbear and vsftp in the wan interface of my Fritz! 7270 ?
This is, if i run dropbear, i only can access using Putty (or other SSH client) in the LAN or wireless. However i want to reach my fritz from the outside.
I'm using the fritz without modem (LAN1 becomes the WAN interface).
Thank you.
Best regards
Valter
Hi.
Sure this is possible. Therefor you have to setup a portforwarding onto the box.
This can either be done with Freetz Package virtual-ip-cgi or avm-firewall-cgi or by editing /var/flash/ar7.cfg directly.
Regards Oliver
Hi.
Regards Oliver
Can you explain better??
Can i setup portforwarding in the AVM web interface ??
Thank you
Best Regards
no, you can not setup the protforwarding using AVM WebIF. Oliver said you already: you need avm-firewall-cgi package, if you plan setup this portforwarding in WebGUI. You can also probe to use virtual-ip or edit directly ar7.cfg.
Best regards
Hello,
I have AVM-firewall and also virtualIP installed in my freetz image.
In the webGUI from AVM-firewall the port forwarding rules are the same as define in the AVM WebIF. Because of this i as if i can do it in the AVM WebIF ;);)
I have to setup a por forwarding to the fritz! itself ? Is this correct?
Thank you
Best regards
figo12
