[English] Recover bricked fritzbox fon
warp_be
6 Feb 2007
sorry for this post in english, but i find nowhere forums dedicated to the fritz!box.
I have a fritz!box fon which is working well.
It's an english one.
I bought another one on ebay for my brother. But that one is a german one (freenet edition). I could change it to avm edition, and finally change the web interface in english, but ADSL connection could not be made.
So i connect to both fritz!box and compared the env variables.
Without doing anything to the "good" working fritz!box, this one stopped answering.
I reboot it, and now the power led light up, and after about 6 seconds, all leds light up and just after all of them shut off. I guess that the fritz!box reboots because it does this all the time, like a continuous cycle.
I still can send a firmware via the recover software, but no one is working.
(i tried : fritz.box_fon.06.04.27.image, fritz.box_fon.en.06.04.24.image, fritz.box_fon.annexa.en.06.04.24.image and finally FRITZ.Box_Fon.06.03.65.image).
With only one of them (FRITZ.Box_Fon.06.03.65.image) the power led keep blinking, and it seems the fritz box don't reboot, but i still can't access or ping the box.
....hope someone will help me.
Thanks.
How did you try to recover? With the command line tool from the CD plus the normal firmware images? Or did you try the recover tool which can be found on the AVM ftp server in the x_misc folder?
I think i used the one i found on the CD (an old distribution).
But the recover.exe works. It transfers the image and the kernel without error. (with every image i used).
I also tried a GUI recover that i found somewhere on internet, but that one doesn't find the fritz.box.
When i'll be back at home, i'll try the adam2 soft.
Thanks.
These are the informations i have :
ftp> debug
Débogage activé.
ftp> GETENV firmware_info
Commande non valide.
ftp> bin
---> TYPE I
200 Type set to I.
ftp> quote GETENV firmware_info
---> GETENV firmware_info
firmware_info 06.03.65
200 GETENV command successful
ftp> quote GETENV firmware_version
---> GETENV firmware_version
firmware_version avme
ftp> quote GETENV mtd0
---> GETENV mtd0
mtd0 0x900C0000,0x903C0000
ftp> quote GETENV my_ipaddress
---> GETENV my_ipaddress
my_ipaddress 192.168.178.1
ftp> quote GETENV bootloaderVersion
---> GETENV bootloaderVersion
bootloaderVersion 0.18.01
ftp> quote GETENV autoload
---> GETENV autoload
autoload yes
ftp> quote GETENV annex
---> GETENV annex
annex A
ftp> quote GETENV ProductID
---> GETENV ProductID
ProductID Fritz_Box_FON_AnnexA
ftp> quote GETENV flashsize
---> GETENV flashsize
flashsize 0x00400000
ftp> quote GETENV memsize
---> GETENV memsize
memsize 0x01000000
ftp> quote SYST
---> SYST
215 UNIX emulated bye ADAM2's FTP Server.
ftp> quote MEDIA SDRAM
---> MEDIA SDRAM
200 Media set to SDRAM.
ftp>
I don't know if this can help,
but all i see seems correct :
- Annex A
- ProductID
- firmware_version
Hope this can help.
This seems to be correct. But the firmware you have flashed is not for OEM avme?
Greets, Oliver
I flashed with every firmware i listed here.
Including the "good" one which i found on the avm website, in the english section, this one has to be good because it was the last upgrade i did.
...i really don't understand.
Perhaps you can try to change the firmware_version to avm.
Greets, Oliver
OK, i changed the firmware_version to avm,
but it did the same.
Connexion via ftp when starting the box, but nothing more.
So i tried once again to send the firmware, then again......then waiting a long time before rebooting the box, and now it's ok.
Not really OK, but the box starts, and i can connect to the webserver.
Everything looks fine, excepts that it doesn't want to connect to the ADSL.
I entered the right user and password, but it's not OK.
ADSL info are good (upload and download, DSL connection is active).
But on the overview screen i see
"Internet : Fritz!Box has no account information for an internet Service Provider."
.....so it's better, but still not OK.
i have lots of error on telnet :
multid[848]: 0.0.0.0:2054: failed to send UDP-datagram to 192.168.180.1:53 - Network is unreachable
And after trying to restart the adsl connection (i just changed to expert mode and applied the config) i have this error :
dsld[912]: not running
dsld[938]: csock: using poll
dsld[938]: Couldn't load shared library libavmssl.so - File not found - Bad file descriptor (9)
dsld[938]: startup (Jul 6 2006 15:02:21)
dsld[941]: DSL Mac 00:04:0e:ff:ff:04
dsld[941]: VOIP Mac 00:04:0e:ff:ff:05
dsld[941]: DSLD terminating
dsld[941]: PPP led: on (value=199)
And that's all. I can't get it to work.
I now linux very well, so i'l try to play with this, but i'm not sure i will get something.
Try with the recover 06.04.01 for annex A.
What's your HWRevision ?
I tried the recover for annex A 06.04.01.
Except that the firmware is now in 06.04.01, everything is the same.
It can not connect to the ADSL anymore. (same error message).
Maybe this could help someone find the solution :
on the web interface, i have nothing printed in the system log.
...anyway thanks for your help.
HWRevision 64
SerialNumber 0000000000000000
annex A
autoload yes
bootserport tty0
bluetooth 00:04:0E:FF:FF:07
cpufrequency 150000000
firstfreeaddress 0x947310d8
firmware_info 06.04.20
maca 00:04:0E:FF:FF:01
macb 00:04:0E:FF:FF:02
macwlan 00:04:0E:FF:FF:03
macdsl 00:04:0E:FF:FF:04
memsize 0x01000000
modetty0 38400,n,8,1,hw
modetty1 38400,n,8,1,hw
mtd1 0x90010000,0x900C0000
mtd2 0x90000000,0x90010000
mtd3 0x903C0000,0x903E0000
mtd4 0x903E0000,0x90400000
prompt Adam2_AVM
reserved 00:04:0E:FF:FF:00
req_fullrate_freq 125000000
sysfrequency 125000000
urlader-version 93
usb_board_mac 00:04:0E:FF:FF:05
usb_rndis_mac 00:04:0E:FF:FF:06
usb_device_id 0x4001
usb_revision_id 0x0100
usb_device_name USB DSL Device
usb_manufacturer_name AVM
firmware_info is not the correct one, i took this just after putting the 06.04.20 firmware
I had also problems with recover to 06.04.24 and I loose some good hours.
The recover stop at quart mtd0 deleting with winError 10054.
Finally I try with an old celeron 500 with xp sp1 and the recover was good from the first try.( 2 fritx boxes fon)
I think Windows SP2 is the problem with updating firmware & recover.
Warp_be, try to reset to factory settings and put firmware( or recover) with another PC.
Thanks for the advice,
i'll try this.....but i have to find a PC without XP ;)
Hope this will work. I'm not sure the recover process could not complete.
Is there a way via ftp to put the factory defaults, or erase the flash.....or something i could to do by myself.
Something like this maybe :
http://www.wehavemorefun.de/fritzbox/Hilfsprogramme_/_Tipps_&_Tricks#Firmware_wieder_herstellen
ftp> quote MEDIA FLSH
200 Media set to FLSH.
ftp> put empty "0x0 mtd3"
local: empty remote: 0x0 mtd3
200 Port command successful.
150 Opening BINARY mode data connection for file transfer.
226 Transfer complete.
ftp> put empty "0x0 mtd4"
local: empty remote: 0x0 mtd4
550 invalid <blockname>.
ftp> quote REBOOT
221-Thank you for using the FTP service on ADAM2.
221 Goodbye.
I don't exactly know what it does.
When you execute a recover-Image from the AVM-ftp all settings are deleted. I don't think that it is a good idea to do "put empty "0x0 mtd3/4". Then all settings of you Box are away including your MAC an so on. Sure you have this info but you have to set it manually...
MfG Oliver
Hello,
I'm looking for the value of environmental variable HWRevision for FRITZ!Box Fon Annex A English. In German Annex B boxes it is HWRevision='58'. And what is it like in English Annex A?
I can see in the above listing that there is HWRevision 64, which is quite strange in this model...
Kraehe82
