Error beim erzeugen der Firmware
skoti_de
13 Dez 2008
habe eine frische Freetz-Installation und die aktuelle Labor-Firmare
(dl/fw/FRITZ.Box_Fon_WLAN_7270.Labor.54.04.74-14331.image)
Wenn ich das ganze mit der aktuellen Firmware erstelle, gibt es keine
Probleme - sobald ich allerdings Freetz sage das er o.g. Labor nehmen soll,
bircht er mit folgender Fehlermeldung ab:
[Edit frank_m24: Bitte benutzt CODE Tags für solche Ausgaben.]
STEP 1: UNPACK
unpacking firmware image
splitting kernel image
unpacking filesystem image
  3262 inodes (3439 blocks) to write
  created 2735 files
  created 130 directories
  created 347 symlinks
  created 180 devices
  created 0 fifos
unpacking var.tar
done.
STEP 2: MODIFY
applying patches
  applying patches (7270-de)
    applying patch file ./patches/7270/100-webif.sh
  Applying symlinks, deleting additional webinterfaces
    applying patch file ./patches/7270/110-inittab.sh
    applying patch file ./patches/7270/200-modules_symlink.sh
  making symlink for modules (-ur8)
    applying patch file ./patches/100-profile.patch
    patching file etc/profile
    applying patch file ./patches/110-multid-wait.patch
    patching file etc/init.d/rc.net
    applying patch file ./patches/110-system_status.patch
    patching file usr/bin/system_status
    applying patch file ./patches/120-inittab_console.patch
    patching file etc/inittab
    applying patch file ./patches/130-fstab.patch
    patching file etc/fstab
    applying patch file ./patches/7270/100-rc.net-dnsmasq.patch
    applying patch file ./patches/7270/110-rc.S-mknod.patch
    patching file etc/init.d/rc.S
    Hunk #1 succeeded at 217 (offset -730 lines).
    applying patch file ./patches/7270/120-rc.S-dev.patch
    applying patch file ./patches/7270/130-rc.S-logging.patch
    applying patch file ./patches/7270/140-rc.S-no_avm_exit.patch
    Hunk #1 succeeded at 1487 (offset 7 lines).
    applying patch file ./patches/7270/290-replace_websrv-remove_igdd.patch
    patch unexpectedly ends in middle of line
    patch: **** Only garbage was found in the patch input.
ERROR: modpatch: Error in patch-file ./patches/7270/290-replace_websrv-remove_igdd.patch
make: *** [firmware-nocompile] Error 2
Kann mir evtl. jemand bei der Lösung des Problems helfen?
Es sind keine Pakete oder Patches an- oder abgewählt.
Box: AVM Fritzbox 7270
Freetz: Freetz 1.0.3
Skoti
Das sieht aber nicht nach der Labor-Firmware aus, dann sollte patches/7270_labor_aio/* kommen. Häng mal deine .config an (gezippt)
ähm...hüstel....gerne.... wenn Du mir sagst wo die ist - Sorry, für
die dumme Frage.
Oder anders rum.... wie muss ich vorgehen um aus der aktuellen Laborversion eine Firmware zu bauen.
Hab leider nirgends etwas gefunden das mir weiterhelfen würde (Board, Google)
Skoti
Für die neueste Labor Firmware musst du den trunk nehmen.
MfG Oliver
Für Labor-Versionen muss man allgemein den Trunk nehmen ;)
Hm, hab ich garnicht gesehen dass er die 1.0.3 nimmt.
Hi@all,
vielen Dank für den Hinweis - dadurch konnte ich an anderer Stelle
herausfinden wie ich das mit dem Trunk machen muss. :rolleyes:
-closed-
MfG
Skoti
Elemir
