FB 7050 - problem with LanB and Wifi
JPAdie
20 Sep 2006
Hi
i've got an old 7050 which i've used for years. recently i've noticed a problem in that i'm not able to access my LAN over WiFi and LanB.
the set up i have is as follows:
DSL -> 7050
7050 acts as gateway, of course
LANA -> connects to DHCP and DNS server (winserver 2003) via a router. all other LAN devices are connected to this router.
LANA -> fixed IP of 10.8.0.1
neither lanB nor the wifi will allow communication with lanA or the network behind it. do i need to set up a manual bridge or something?
in network settings the box 'all computers are located in the same network' is checked.
the 7050 does NOT act as a DHCP server.
this is the output from an ifconfig on the box
dsl       Link encap:Point-Point Protocol
          inet addr:192.168.179.1  P-t-P:192.168.179.1  Mask:255.255.255.255
          UP POINTOPOINT RUNNING NOARP ALLMULTI MULTICAST  MTU:1500  Metric:1
          RX packets:7190287 errors:0 dropped:0 overruns:0 frame:0
          TX packets:7815205 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:100
          RX bytes:561773971 (535.7 MiB)  TX bytes:875661591 (835.0 MiB)
eth0      Link encap:Ethernet  HWaddr 00:15:0C:97:46:1E
          UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:1500  Metric:1
          RX packets:7888367 errors:0 dropped:0 overruns:0 frame:0
          TX packets:7160947 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:978218164 (932.9 MiB)  TX bytes:634307692 (604.9 MiB)
eth1      Link encap:Ethernet  HWaddr 00:15:0C:97:46:1F
          UP BROADCAST ALLMULTI MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Base address:0x2800
lan       Link encap:Ethernet  HWaddr 00:15:0C:97:46:1E
          inet addr:10.8.0.1  Bcast:10.255.255.255  Mask:255.255.255.0
          RX packets:7889940 errors:0 dropped:0 overruns:0 frame:0
          TX packets:7158722 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:868623530 (828.3 MiB)  TX bytes:633403910 (604.0 MiB)
lan:0     Link encap:Ethernet  HWaddr 00:15:0C:97:46:1E
          inet addr:192.168.178.254  Bcast:192.168.178.255  Mask:255.255.255.0
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:4321 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4321 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:289688 (282.8 KiB)  TX bytes:289688 (282.8 KiB)
tap0      Link encap:Ethernet  HWaddr 00:FF:4F:EE:24:DF
          inet addr:10.8.0.136  Bcast:10.8.0.255  Mask:255.255.255.0
          TX packets:110938 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:26186657 (24.9 MiB)
usbrndis  Link encap:Ethernet  HWaddr 00:15:0C:97:46:22
and this is the output of a brctl show
# ./brctl show
bridge name     bridge id               STP enabled     interfaces
lan             8000.00150c97461e       no              eth0
                                                        usbrndis
                                                        eth1
any help would be much appreciated.
obviously the wifi is not turned on for the above traces. however when turned on, i can connect to the box but do not receive any IP address. when i configure manually, i can't get to the LAN or the internet.
atrora
