FB 7270 English Interface
JPAdie
20 Sep 2006
Hi
I am about 75% through translating the interface into English.
Can anyone tell me whether I am allowed to share this on the forum? I'd like to be able to give something back in return for all the help i've received.
thanks
Justin
I guess the silence means that i am not allowed to do so.
oh well.
Hi.
The webinterface is copyright by AVM. If you hadn't asked to I think no one would complain. But after you have asked if you are allowed to do it there might be a mod who will warn you.
Greets Oliver
It depends on the way you want to publish the translated interface. AVM doesn't like it if firmware images are spread, no matter if they are modified or not. That's why you will only find scripts in this forum that modify original firmwares.
If you find a way to write a script which does the necessary modifications so that everyone can build his own english interface: Share it! :-)
i was planning just to upload a zip/tar of the html and include files that people could add as a patch in freetz. (may need a bit of help with the mechanics of the patching...).
Due to lack of response (prior to today), i've put the project on the back burner. i'll pick it back up in a couple of weeks.
atrora
