Fehler bei make clean 7170 Trunk
winstonS
27 Aug 2007
habe einen seltsamen Fehler.
Trunk Image lässt sich für FritzBox7170 problemlos erstellen.
Nur make clean bricht mit Fehler ab.
--snip
freetz@freetz-linux:~/freetz-trunk$ make clean
rm -f busybox/busybox-8mb_26 busybox/busybox-8mb_26.links
cmd() { PATH="/home/freetz/freetz-trunk/toolchain/target/bin:/home/freetz/freetz-trunk/toolchain/kernel/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2 "$@" || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed."; exit 1; } }; if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.29/ref-8mb_26/busybox-1.16.1 clean
make: *** source/target-mipsel_uClibc-0.9.29/ref-8mb_26/busybox-1.16.1: No such file or directory. Schluss.
make: [busybox-clean] Fehler 1 (ignoriert)
cmd() { PATH="/home/freetz/freetz-trunk/toolchain/target/bin:/home/freetz/freetz-trunk/toolchain/kernel/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2 "$@" || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed."; exit 1; } }; if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/kernel/ref-ohio-8mb_26-04.80/linux-2.6.13.1 \
CROSS_COMPILE="mipsel-unknown-linux-gnu-" \
KERNEL_MAKE_PATH="/home/freetz/freetz-trunk/toolchain/kernel/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" \
KERNEL_LAYOUT="8mb_26" \
clean
make[1]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/kernel/ref-ohio-8mb_26-04.80/linux-2.6.13.1'
scripts/Makefile.clean:10: sound/oss/davinci/Makefile: No such file or directory
make[4]: *** Keine Regel, um »sound/oss/davinci/Makefile« zu erstellen. Schluss.
make[3]: *** [sound/oss/davinci] Fehler 2
make[2]: *** [sound/oss] Fehler 2
make[1]: *** [_clean_sound] Fehler 2
make[1]: *** Warte auf noch nicht beendete Prozesse...
make[1]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/kernel/ref-ohio-8mb_26-04.80/linux-2.6.13.1'
make: *** [kernel-clean] Fehler 1
Ist ein Fehler und wird demnächst behoben. Danke für die Meldung.
@markuschen
Die Option im Makefile fängt nicht mit obj- sonder mit subdir- an. Scheint sich von 2.6.13.1 auf 2.6.19.2 geändert zu haben.
subdir-$(CONFIG_SOUND_DAVINCI)  += davinci
subdir-$(CONFIG_SOUND_OMAP)        += davinci
subdir-$(CONFIG_SOUND_OMAP_TSC2101)+= davinci
MfG Oliver
Fehler ist im Trunk (#4875) beseitigt.
stego88
