- Mitglied seit
- 23 Jul 2009
- Beiträge
- 493
- Punkte für Reaktionen
- 5
- Punkte
- 18
Gibt es eine Möglichkeit Festnetz Telefonnummern heraus zu finden, die nicht im Telefonbuch stehen auch gegen Gebühr?
<?php
header("Content-Type: text/xml; charset=utf-8");
echo "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\r\n\r\n";
//Add area code? true or false
$addAreaCode = true;
//Area code
$areaCode = "0621";
// Remove &, and leading/trailing whitespace
function tidyString($s) {
$search = array ("\xc2\xa0", "&");
$replace = array ( '', '');
return trim(str_replace($search,$replace, $s));
// Split 'Lastname [Firstname1 [Firstname2]]' into key-value pairs 'fn'=>'Firstname1 Firstname2','ln'=>'Lastname'
function splitName($name) {
$res = array('fn' => '', 'ln' => '');
$a = explode(' ', $name, 2);
$res['ln'] = $a[0];
if (count($a) > 1)
$res['fn'] = $a[1];
return $res;
// Split '[Street 1 a,]12345 City' into key-value pairs 'st'=>'Street','nr'=>'1a','zc'=>'12345','ct'=>'City'
function splitAddress($address) {
$res = array('st' => '', 'nr' => '', 'zc' => '', 'ct' => '');
if (preg_match('/^((.+) (\d+.*),)?(\d+) (.+)$/', $address, $m)) {
$res['st'] = $m[2];
$res['nr'] = str_replace(' ', '', $m[3]);
$res['zc'] = $m[4];
$res['ct'] = strtok($m[5], ','); # Remove suburb from name
return $res;
// Output Gigaset error response
function printError($id) {
echo '<error repsonse="get_list" type="pb"><errorid>' . $id . '</errorid></error>';
// Output Gigaset phonebook search response
function printResponse($entry) {
echo '<list response="get_list" type="pb" ';
// No result:
if (!is_array($entry) || !array_key_exists('ln', $entry) || empty($entry['ln'])) {
echo 'notfound="hm" total="0"/>';
// Person found:
else {
echo 'total="1" first="1" last="1"><entry>';
echo '<ln>' . $entry['ln'] . '</ln>';
if (array_key_exists('fn', $entry) && !empty($entry['fn']))
echo '<fn>' . $entry['fn'] . '</fn>';
if (array_key_exists('st', $entry) && !empty($entry['st']))
echo '<st>' . $entry['st'] . '</st>';
if (array_key_exists('nr', $entry) && !empty($entry['nr']))
echo '<nr>' . $entry['nr'] . '</nr>';
if (array_key_exists('zc', $entry) && !empty($entry['zc']))
echo '<zc>' . $entry['zc'] . '</zc>';
if (array_key_exists('ct', $entry) && !empty($entry['ct']))
echo '<ct>' . $entry['ct'] . '</ct>';
if (array_key_exists('hm', $entry) && !empty($entry['hm']))
echo '<hm>' . $entry['hm'] . '</hm>';
echo '</entry></list>';
// Reverse phone number search on DasOertliche.de
function lookupCaller($number) {
$dom = new DOMDocument();
if (!@$dom->loadHTML(file_get_contents('https://www.dasoertliche.de/Controller?form_name=search_inv&ph=' . $number)))
return; # HTML file unparseable
$xp = new DomXPath($dom);
$name = tidyString($xp->evaluate('string(//div[@id="entry_1"]//a/span[1])'));
$addr = tidyString($xp->evaluate('string(//div[@id="entry_1"]//address[1])'));
return array_merge(splitName($name), splitAddress($addr), array('hm' => $number));
//Begin
if (isset($_GET['hm']) && is_numeric($_GET['hm'])) {
$hm = $_GET["hm"];
if ($addAreaCode && strncmp($hm,"0",1) != 0) {
$hm = $areaCode.$hm;
$caller = lookupCaller($hm);
if (is_array($caller))
printResponse($caller);
else {
printError(6); # Service not available
else {
printResponse(NULL);
Achso, ich dachte es ginge um die Frage, wie man Anrufer mit Namen anzeigen kann, deren Nummer nicht im eigenen Telefonbuch stehen.Das geht aber völlig an der Frage vorbei
NeinAchso, ich dachte es ginge um die Frage, wie man Anrufer mit Namen anzeigen kann, deren Nummer nicht im eigenen Telefonbuch stehen.
Die Frage lautet: Festnetz Telefonnummern herausfinden ohne TelefonbucheintragDie Liste ist doch völlig wertlos, da Nummern heute von Anbieter zu Anbieter mitgenommen werden kann.
Aber durch die Rufnummernmitnahme ändert sich doch die Nummer nicht. In der Liste sind weiterhin alle Rufnummern zu finden, auch die, die nicht im Telefonbuch stehen. Wenn man wirklich nur Rufnummern ohne Telefonbucheintrag sucht, muss man die selber rausfiltern, aber das kann man ja automatisieren.wertlos, da Nummern heute von Anbieter zu Anbieter mitgenommen werden kann
Ich sehe in der Liste keine einzige Telefonnummer, nur anonyme Rufnummernblöcke. Welcher Telefonanbieter welchen Rufnummernblock gebucht hat, dürfte eher uninteressant sein.In der Liste sind weiterhin alle Rufnummern zu finden
Adressen kann man doch auch gegen Gebühr ermitteln, Telefonnummern nicht ?@analog_synth
Sowas gibt es nicht, das wär ja ein Skandal
Die Nummern/Namen, die du kennst, kannst du natürlich in dein eigenes Telefonbuch, z.B. bei Google oder in der Fritzbox, eintragen.
Wo?Adressen kann man doch auch gegen Gebühr ermitteln
