Freetz - Firmware-Update
2. Firmware extrahieren, Update vorbereiten
Firmware-Archiv extrahieren ...
./var/
./var/.packages
./var/tmp/
./var/tmp/filesystem.image
./var/tmp/kernel.image
./var/signature
./var/static.pkg
./var/flash_update.ko
./var/info.txt
./var/chksum
./var/regelex
./var/install
./var/.config
DONE
Ausführen des Firmware-Installationsskripts /var/install ...
install: have Kernel 2.6
install: check and install new firmware ...
OEM=1und1
ANNEX=B
testing acceptance for device Fritz_Box_7270 ...
korrekt install type: ur8_16MB_xilinx_4eth_2ab_isdn_nt_te_pots_wlan_usb_host_dect_61056
device has installtype ur8_16MB_xilinx_4eth_2ab_isdn_nt_te_pots_wlan_usb_host_dect_61056
OK - OEM 1und1 is supported
OK - accept this update for device Fritz_Box_7270 ...
testing acceptance for device Fritz_Box_7270 done
install type not korrekt: ur8_16MB_xilinx_4eth_2ab_isdn_nt_te_pots_wlan_usb_host_dect_61056
curr: 54.04.59 new: xx.04.59
debug: curr: 54.04.59
debug: new: "XX.04.59"
major_currFWver=54
middle_currFWver=4
minor_currFWver=59
middle_newFWver=4
minor_newFWver=59
check Firmware Version: xx.04.59
DEBUG: 4 >= 4
DEBUG: 59 >= 59
Accept Firmware Version: xx.04.59
install: 26 check files...
File already contains the checksum, verifying
Calculated checksum is 4C62C6F1
Saved checksum is 4C62C6F1
Checksum validation successful!
chksum for file /var/tmp/kernel.image ok
install: 26 getting mtd to install...
install: -----------------------------------------------------
bootloader_size 0x00020000
jffs2_size 0x00500000
Kernel_without_jffs2_size 2555904
kernel_image_size 10715400
kernel_mtd_size 7798784
Kernel_Start_Add=268566528
Kernel_End_Addr=279281928
Kernel_without_jffs2_End_Addr=271122432
install: Image would overlap - jffs2 will be deleted ...
install: kernel_size=7798784
install: kernel_update_start=268566528
install: kernel_update_len=7798784
install: 26 setting files to install...
install: /var/tmp/kernel.image to start(268566528) size(7798784)
install: check for old settings ...
set INFO led to blink (modul=7, state=4)
ERLEDIGT - Rückgabewert des Installationsskripts = 1 (INSTALL_SUCCESS_REBOOT)
Von /var/post_install generierter Inhalt:
#! /bin/sh
echo $0: start
sleep 1
killall run_clock
if ps | grep -v grep | grep -q telefon ; then killall telefon ; fi
if ps | grep -v grep | grep -q telnetd ; then killall telnetd ; fi
echo skip deleting language from env
echo MODE=update > /dev/avm_power
echo "disable" > /dev/watchdog
echo still running:
ps
lsmod
sleep 1
update_parameter=flash_update_file0="/var/tmp/kernel.image,268566528,7798784,crc=1"
insmod /var/flash_update.ko $update_parameter
exit 0
ENDE DER DATEI
Das Nach-Installationsskript läuft beim Neutart (reboot) und führt die
darin definiterten Aktionen aus, z.B. das tatsächliche Flashen der Firmware.
Sie können immer noch entscheiden, diesen Vorgang abzubrechen, indem Sie
das Skript und den Rest der extrahierten Firmware-Komponenten löschen.
