[Gelöst] freetz 1.2 preview: php make issue with libcrypto / lib dl?
molfi
17 Okt 2006
Hi.
I was curious, trying out the new preview of freetz 1.2 (checked out trunk revision 7770 and started from scratch). Chose several packages, also php with ssl support.
During the build process php package terminated with error 1.
Make verbose 2 showed the following:
/home/freetz/freetz/freetz-1.2-preview/toolchain/build/mipsel_gcc-4.4.6_uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/libcrypto.a(dso_dlfcn.o): In function `dlfcn_bind_func':
dso_dlfcn.c:(.text+0x3f4): undefined reference to `dlsym'
dso_dlfcn.c:(.text+0x430): undefined reference to `dlerror'
/home/freetz/freetz/freetz-1.2-preview/toolchain/build/mipsel_gcc-4.4.6_uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/libcrypto.a(dso_dlfcn.o): In function `dlfcn_bind_var':
dso_dlfcn.c:(.text+0x540): undefined reference to `dlsym'
dso_dlfcn.c:(.text+0x57c): undefined reference to `dlerror'
/home/freetz/freetz/freetz-1.2-preview/toolchain/build/mipsel_gcc-4.4.6_uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/libcrypto.a(dso_dlfcn.o): In function `dlfcn_unload':
dso_dlfcn.c:(.text+0x674): undefined reference to `dlclose'
/home/freetz/freetz/freetz-1.2-preview/toolchain/build/mipsel_gcc-4.4.6_uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/libcrypto.a(dso_dlfcn.o): In function `dlfcn_load':
dso_dlfcn.c:(.text+0x70c): undefined reference to `dlopen'
dso_dlfcn.c:(.text+0x74c): undefined reference to `dlerror'
dso_dlfcn.c:(.text+0x7e8): undefined reference to `dlclose'
collect2: ld returned 1 exit status
make[1]: *** [sapi/cgi/php-cgi] Fehler 1
make[1]: Verlasse Verzeichnis '/home/freetz/freetz/freetz-1.2-preview/source/target-mipsel_uClibc-0.9.29/php-5.3.6'
Could it be that lib sl is not recognized through the build process?
Thanks
molfi
please find a redirected make > error.txt in the attachment
Ist that what you are missing?
//molfi
  • error.txt
In this file there is nothing about undefined references. In fact, there is no indication of anything beeing wrong, except for the "Build failed" at the end.
I do not know so much about compiling. I tried LDFLAGS, LIBS in the configure and make process, but nothing helped.
I know php with ssl worked in the freetz 1.1.x trunk (at least many revisions back in time)
Has there something important changed?
I will try with the new freetz-linux and another fresh 1.2 preview later this week.
//molfi
The additional lib for Zend fixed it.
Thanks
//molfi
  • solved.txt
broekar
