[Frage] Freetz-NG: 7560 ger vs int, has firmware 6.9x
cybermaus
5 Mai 2008
Hello
I recently got a pre-used 7560 1&1, to replace an ageing 7270 (yes, I am not on top of things)
While I consider keeping it german, I compiled with some packages in both german and english, and compared the .config files.
See below
So now I am wondering, the international .config has internal references to firmware 6.5x, the German one to 6.9x
Is this because of some missing AVM images and tarballs, or is this a mistake in the freetz?
Not urgent or a problem, just wondering and reporting in case it is a mistake.
Thanks
vanduerm@ubuntu:~/freetz-ng/images$ diff *.config
159,162c159,161
< FREETZ_TYPE_LANG_DE=y
< # FREETZ_TYPE_LANG_EN is not set
< FREETZ_TYPE_LANGUAGE="de"
< # FREETZ_TYPE_FIRMWARE_06_5X is not set
> # FREETZ_TYPE_LANG_DE is not set
> FREETZ_TYPE_LANG_EN=y
> FREETZ_TYPE_LANGUAGE="en"
164d162
< # FREETZ_TYPE_FIRMWARE_06_9X is not set
206c204
< # FREETZ_REMOVE_BRANDING is not set
> # FREETZ_REMOVE_LANGUAGE is not set
242d239
< # FREETZ_PATCH_MODFS_ANNEX_SELECTION is not set
2828,2830c2825,2826
< FREETZ_DL_SITE="@AVM/{fritzbox-7560/deutschland/fritz.os,fritzbox.7560/firmware/deutsch},@1&1/7560"
< FREETZ_DL_SOURCE="FRITZ.Box_7560-07.12.image"
< FREETZ_AVM_HAS_FIRMWARE_06_5X=y
> FREETZ_DL_SITE="@AVM/{fritzbox-7560/other/fritz.os,fritzbox.7560/firmware/english}"
> FREETZ_DL_SOURCE="FRITZ.Box_7560.int.07.12.image/FRITZ.Box_7560-07.12.image"
2832d2827
< FREETZ_AVM_HAS_FIRMWARE_06_9X=y
2852c2847,2854
< FREETZ_AVM_HAS_BRANDING_avm=y
> FREETZ_AVM_HAS_BRANDING_avme=y
> FREETZ_AVM_HAS_MULTIPLE_LANGUAGES=y
> FREETZ_AVM_HAS_LANGUAGE_de=y
> FREETZ_AVM_HAS_LANGUAGE_en=y
> FREETZ_AVM_HAS_LANGUAGE_es=y
> FREETZ_AVM_HAS_LANGUAGE_fr=y
> FREETZ_AVM_HAS_LANGUAGE_it=y
> FREETZ_AVM_HAS_LANGUAGE_pl=y
2875d2876
< FREETZ_AVM_HAS_MULTIPLE_BRANDINGS=y
2890d2890
< FREETZ_AVM_HAS_BRANDING_1und1=y
Reaktionen: gianni260357
Please mark your problem as (related to) "Freetz-NG" - thanks.
Plese remove the NG tag again. This is for all forks the same and exists since a long time.
Please distinct enabled and disabled items. And the meaning of every single
That's - obviously - wrong ... due to your comprehensive changes to the structure of used configuration values, it's impossible to compare (and to use) configuration files from one fork with the other.
That's why it should be identifiable, which fork was used/affected, if two configuration files are compared with a diff command - no matter, whether the same problem exists in the other fork, too.
AVM_HAS_FIRMWARE part is the same
May be right ... but if we want to establish a separate sub-forum for Freetz-NG related problems, WE are the first, who have to take care to be clear, which fork is meant.
The mods told me that my opinion does not matter, so there is no "we want"
That's one more reason for our own responsibility while creating/managing new threads ... if there will be no separate sub-forum for the "NG" fork, it's even more important to use thread titles, which clearly show a hint for the affected/related fork.
There's a german saying: Man muss sich nur zu helfen wissen.
GGT3
