[Info] FRITZ!Box 7590 Fritz!OS 154.07.00-en-de-es-it-fr-pl-nl (CP 60481) Release vom 22.08.2018
18 Apr 2008
Download
# New Features in FRITZ!OS 7.00
##Internet:
- **NEW** register for regular status updates for your FRITZ!Box (MyFRITZ! report)
- **NEW** MyFRITZ! internet access to the FRITZ!Box without a warning from the browser (SSL certificate from Let's Encrypt)
##Telephony:
- **NEW** The FRITZ!Box configured as Mesh Master transfers your telephone numbers to an additional FRITZ!Box as a Mesh Repeater.
- **NEW** Scheduling function for call diversion
- **NEW** Telephone numbers can be blocked or added to your contacts directly from the call list
- **NEW** Support for Deutsche Telekom SIP Trunking (DeutschlandLAN SIP Trunk / SIP Trunk Pooling)
##DECT:
- **NEW** FRITZ!Fon phone number display shows region and country area codes
- **NEW** Now five different ring tones of your own can be selected for FRITZ!Fon
- **NEW** FRITZ!Fon start screen event log: received faxes are displayed
- **NEW** FRITZ!Fon Smart Home start screen now scrollable to display more Smart Home devices
- **NEW** Expanded registration mode for (re-)registration of all devices known to the FRITZ!Box, for instance, after switching to a new FRITZ!Box
- **NEW** FRITZ!Box supports software updates for compatible handsets from other manufacturers (CAT-iq SUOTA)
- **NEW** FRITZ!Fon supports updates for FRITZ!Box (can also be protected with a PIN)
- **NEW** Separate volume controls for the alarm sound
- **NEW** FRITZ!Fon media player: save and load playlists as .xsfp files via FRITZ!NAS
- **NEW ** Jump to next/last title when playing podcasts on your FRITZ!Fon
- **NEW** Support for Speedphone 11 from Deutsche Telekom
##Home network:
- **NEW** User interface with new Home Network -> "Mesh" menu for all settings concerning Mesh
- **NEW** Mesh Home Network Overview also shows telephone and Smart Home connections complete with topology and connection quality
- **NEW** In the ex works settings, a second FRITZ!Box connected via Ethernet becomes a Mesh repeater at the push of a button (WPS)
- **NEW** Switch for IP client or router operation in the network settings area
- **NEW** Switch for the function of the FRITZ!Box in the home network (Mesh operating mode) as Mesh Master or Mesh Repeater in the Home Network>Mesh>Mesh Settings and WLAN areas
- **NEW** Mesh events added to the event messages
- **NEW** The settings for push services, auto updates and AVM services are applied to the entire Mesh WiFi
More information on the new features for Mesh is presented at "New features for Mesh"
More information on configuration and using Mesh is presented at en.avm.de/mesh-faq
##Wireless:
- ** NEW** With a "FRITZ! Hotspot it's easier than ever to give guests WiFi access in public places such as bars, restaurants, doctor's practices etc. For details, see Wireless / Guest Access.
- **NEW** Improved wireless security through support of activated Protected Management Frames (PMF)
- **NEW** Support for 160 MHz bandwidth (only 7590/7580/6590)
- **IMPROVED** No more DFS waiting times (RADAR) on the 5-GHz band through the new "Zero Wait DFS" feature (7590, 7580, 6590)
##Smart Home:
- **NEW** Support for DECT ULE/HAN FUN
With each FRITZ!OS update, AVM also updates its security functions. Therefore we recommend performing the update for all devices.
# Additional improvements in FRITZ!OS 7.00
## Powerline:
- **IMPROVED** Option for checking and, if necessary, remedying detected interference from powerline to VDLS
## DSL
- **IMPROVED** Improvements for supervectoring (35b)
## Internet
- **IMPROVED** Display of internet connections on the Overview page also includes WAN connections
- **IMPROVED** Simplified display for internet connections on the Overview page under Connections
- **IMPROVED** Function for removing the FRITZ!Box from the MyFRITZ! account (myfritz.net)
- **IMPROVED** Optimizations for data throughput
- **IMPROVED** Optimizations for DNS resolution
- **Improved** Optimized registration with MyFRITZ! (myfritz.net) also possible without enabling MyFRITZ! internet access, under Internet > MyFRITZ! Account
- *IMPROVED** SHA-2 support for VPN connections
- **IMPROVED** Filter for port 25 (unsecured mail sending) also effective for the Guest Access (Wireless LAN/LAN)
- **CHANGE** Connections to 1&1 lines also with Internet Protocol version 6 (IPv6 and IPv4 Dual Stack)
- **CHANGE** Connections to Vodafone lines also with Internet Protocol version 6 (IPv6 and IPv4 Dual Stack)
- **CHANGE** Type of internet connection "existing connection via wireless LAN" also supports non-encrypted wireless LAN
- **CHANGE** Parental controls no longer differentiate between Windows users
- **CHANGE** Devices blocked for internet use in the parental controls can be reached via VPN
- **CHANGE** Internet service provider "GMX" removed
- **CHANGE** FRITZ!Box devices in IP client mode (as for connection to existing network) can be registered with myfritz.net
- **CHANGE** Certificate signed by letsencrypt.org (for MyFRITZ! addresses)
- **BUG FIX** "Default user already exists" message when configuring parental controls
- **BUG FIX** Possible circumvention of time limits defined in parental controls
- **BUG FIX** Circumvention of parental controls for certain blocked websites
- **BUG FIX** The LAN ports were switched for VPN LAN-LAN linkup
- **BUG FIX** Improved VPN interoperability
- **BUG FIX** VPN user connections not displayed in the home network overview
- **BUG FIX** MyFRITZ! FTP links corrected
- **BUG FIX** MyFRITZ! access or device with MyFRITZ! access could not be deleted under certain circumstances
- **BUG FIX** Error while entering an already assigned IP address for a new device for port sharing
- **BUG FIX** No IPv4 port sharing for devices with IPv6 interface ID during IPv4 internet connection without IPv6
- **BUG FIX** IPv6 NAS sharing link could not be used
- **BUG FIX** Google DynDNS service not supported
- **BUG FIX** Static IP address with /31 network mask not possible
##Telephony:
- **IMPROVED** Redesigned administration of call blocks for incoming calls (telephone numbers)
- **IMPROVED** Optimized management of telephone books
##DECT:
- **IMPROVED** Playback of web radio and podcasts with HTTPS addresses on AVM devices (only if contents can be played back without encryption)
- **BUG FIX** Speedphone 500 could no longer make calls
##Home network:
- **BUG FIX** Possible error message (Error code 1) when IP address entered manually in the Device Details
- **CHANGE** Connection Statistics area for the powerline network moved from the Network Device Details to the Contents>FRITZ!Box Support area
##Wireless:
- **IMPROVED** DFS wait times in the 5-GHz band optimized
- **IMPROVED** Band steering for wireless clients that support the 802.11v/k standards
- **IMPROVED** Display of wireless standards 802.11k and 802.11v as "Signal Properties" (for band steering)
- **IMPROVED** Display of frequency bands on Wireless LAN / Radio Channel page in the "Other radio networks in your vicinity" list
- **IMPROVED** Improved changing of SSID in Wireless Assistant during first configuration
- **BuG FIX** Selection of DFS channels in the 5 GHz band possible again in repeater mode
- **BUG FIX** Display of interference sources on Wireless LAN / Radio Channel page in the "Use of the Wireless LAN Channels" list
- **BUG FIX** The entire network environment of the base station is displayed in repeater mode
##Smart Home:
- **IMPROVED** Support for external temperature sensor to determine room temperature
- **IMPROVED** Push notification sent when an interrupted DECT connection is restored
- **IMPROVED** Error while saving Smart Home Device names
##Security:
- **CHANGE** The "Login without password (not recommended) option in the FRITZ!Box user interface now requires pressing a button on the FRITZ!Box
##Diagnostics:
- **IMPROVED** Function diagnostics shows insufficient memory for saving faxes and voice messages when USB storage is full
- **CHANGE** Display of port for Diagnostics & Maintenance
##System:
- **NEW** Additional confirmation for certain changes can now be performed using the Google Authenticator
- **IMPROVED** Redesigned Auto Update page
- **IMPROVED** Event protocol on the Mesh Master also contains all events on the other FRITZ! devices in the Mesh WiFi
- **IMPROVED** Push service sends mail after the update with additional information on the version and update progress
- **IMPROVED** Push service change notice now also includes information on the registration of a new DECT device
- **IMPROVED** Push service change notice on new devices in the home network now also includes information on new Mesh repeaters
- **IMPROVED** "New FRITZ!OS" push service mail now also includes planned time of for auto updates
- **IMPROVED** Optimized time synchronization (NTP) after internet dial-in
- **IMPROVED** Consent to "Diagnostics and Maintenance" does not include permission for software updates
- **IMPROVED** Simplified display for configuration of wireless LAN, LAN and WAN in the Interfaces area of the Overview menu
- **IMPROVED** Redesigned push services overview
- **CHANGE** For security reasons, the preconfigured user "ftpuser" can no longer be granted access from the internet
- **CHANGE** For FRITZ!Box users who are granted access from the Internet, the password must be different from the user name
- **CHANGE** The security of new password assignments must be rated at least "medium" or they will be rejected.
- **CHANGE** Additional confirmation for creating VPN connections
##USB:
- *IMPROVED** Message notifying about possible detriment to FRITZ!Box functions when contents deleted from the FRITZ! folder
- **BUG FIX** System folders no longer indexed for the FRITZ! media server
USB/UMTS:
- **BUG FIX** Internet via mobile network not offered for all detected 3G dongles during first configuration
Reaktionen: v!king
Ist das eine neuere Version als die normale 7.00er, oder einfach nur die gleiche mit mehr Sprachvarianten?
Sie wurde am 21.08. erstellt. Sollte daher in der Entwicklung am weitesten sein. Aktuell gibt es interne .98-Laborversionen um den Checkpoint 60430 auch für die 7590. Die deutsche Version war offensichtlich ein Schnellschuss, um den Veröffentlichungstermin Juli einhalten zu können.
Schon möglich. Sogar wahrscheinlich. Damit wäre allerdings 7.00 != 7.00 ...
AVM sollte endlich ermöglichen, dass sowohl die deutsche, als auch die internationale Version eingespielt werden können. Das funktioniert bei der 6890-LTE problemlos - zumindest in den Laborversionen. Im Jahr 2018, wo jeder Flachbildschirm ein mehrsprachiges Menü anbietet, sollte das auch bei anderen Geräten Standard sein.
Reaktionen: Micha0815
Beim 1750E Repeater ist es ja problemlos möglich, die "...en-de-es-it-fr-pl..." Versionen auf einen "deutschen" 1750E zu flashen, hier aber nicht. Stellt sich für mich gerade die Frage, für welche Boxen diese FW dann stattdessen gedacht ist, zumal ja "de" dabei ist. Schweiz/Österreich?
Für die 6890 LTE gibt es nur eine Version (OEM Branding avm,avme). Die Dateinamen sind zwar unterschiedlich, die Dateien selber sind identisch.
Mag sein, ich meine aber die FW, um die es hier geht. :)
na, dann mal abwarten .... wie die Testergebnisse hier ausfallen
Die 6890 LTE gibt es in zwei Varianten. Artikelnummer 20002818 (international) und Artikelnummer 20002817 (deutsch).
Die Firmware lässt es aber zu mit beiden Dateien zu arbeiten. Jedenfalls für die Laborversion. Es gab zwischenzeitlich auch eine interne Laborversion, wo die Box nur noch ein deutsches Menü hatte.
Von der Firmware her sind die Versionen von deutschen und internationalen Boxen meist nicht identisch, wenn AVM spezielle Anpassungen für Provider im Ausland vornimmt. Bei der 7590 wurde kürzlich eine Italy-Version eingestreut, die mit dem Release jetzt bestimmt hinfällig sein dürfte.
@BigBlue-007
Diese Firmware ist für die internationale 7590 gedacht. Diese sieht identisch bis baugleich aus. Im Vergleich dazu fehlen einer internationalen 7490 die in Deutschland üblichen TAe-Buchsen an der Seite.
Mit der 7590 hat AVM darauf verzichtet, die Box um die TAe-Buchse zu reduzieren. Erstmals spricht also nichts dagegen, auch eine einheitliche Firmware zu produzieren.
Auch die 7490 konnte mit der internationalen Firmware betrieben werden. Nur gibt es für die weniger Laborversionen.
Alles klar, danke. Da ich eine deutsche 7590 habe (so wie vermutlich die meisten hier), lässt sich diese FW hier also nicht verwenden. Das hatte ich auch selbst schon gemerkt, mich interessierte nur, warum.
Die seitlichen TAE-Buchsen sind üblicherweise nur den RJ12-Buchsen parallel geschaltet.
Das ist ein rein "mechanischer" Verdrahtungsunterschied, der überhaupt nichts mit der Firmware zu tun hat.
Einerseits ist das falsch und andererseits ist das wiederum richtig. Release 7.00 (oder 6.50 oder 6.20 oder 6.00 oder 5.00) ist Release 7.00 (oder 6.50 oder 6.20 oder 6.00 oder 5.00), also Ver. 7.00 = Ver. 7.00 (wenn man mal zurückgezogene Firmware-Images auf dem Server von AVM nicht mit berücksichtigt).
Aber das bei der 7590 "Ver. 7.00 de != Ver. 7.00 int." gilt war ja nicht anders zu erwarten. Oder hattest du tatsächlich erwartet, dass die internationale Ver. 7.00 für die 7590 das gleiche Builddate und die gleiche Buildnummer haben wird?
Das die Release-Ver. 7.00 (oder 6.50 oder 6.20 oder 6.00 oder 5.00) über die verschiedenen Modelle hinweg nicht absolut identisch ist, unterschiedliche Zeitpunkte für die Erstellung hat und auch unterschiedliche Buildnummern ist bekannt und (mittlerweile) üblich. Und natürlich gibt es prinzipbedingt auch Unterschiede bei der Firmware wenn beim betroffenen Modell überhaupt zwischen deutscher und internationaler Firmware unterschieden wird (ist ja auch nicht mehr bei allen Modellen der Fall, beispielsweise bei der 6890 LTE oder der 4040 sind die Images de/int. identisch, da gilt dann immer Ver. x de = Ver. x int.), in der Regel erscheint die internationale Version (bei Modellen wo zwischen de/int. unterschieden wird bei der Firmware) etwas verzögert und hat dann in der Regel auch eine höhere Buildnummer und ein neueres Datum. Das ist ja beileibe nicht neu oder kommt unerwartet. Manchmal hat dann die internationale Firmware sogar eine andere (höhere) Revisionsnummer (wenn es inzwischen vielleicht doch ein paar mehr relevante Änderungen gab) bei einem neuen Major-Release, aber eben auch nicht immer (so wie diesmal).
Auch kann es sonst mal kleinere Unterschiede geben (die nicht von der Hardware beeinflusst werden) bei gleicher Versionsnummer, man denke da vielleicht auch an die Ver. 6.50 (de) für die 7490 wo noch unsignierte Firmware-Images akzeptiert wurden, bei anderen Modellen mit der Ver. 6.50 war das dagegen nicht mehr der Fall (aber die hatten dann auch eine höhere Buildnummer).
Wobei das ja genau genommen auch nur daran liegt, dass es zwischen diesen deutschen und internationalen Firmware-Images überhaupt keinen Unterschied gibt (ist ja nicht nur bei der 6890 LTE oder der 4040 der Fall sondern auch bei der 4020 oder 5490), dieser wird anhand der Ordnerstruktur und der Dateinamen (wobei letzteres zumindest nicht für alle Modelle gilt) auf dem AVM-Server quasi nur vorgespielt aber die jeweiligen Images sind dennoch absolut identisch. Diese Firmware-Versionen akzeptieren dann auch avm und avme als Branding-Variable (oder das entsprechende Modell gibt es nur mit einen dieser beiden Werte).
Das ist bei den Modellen wo zwischen de/int. Firmware (noch) unterschieden wird (wie beispielsweise bei der 7430, 7490, 7530, 7560 oder 7590) jedenfalls nicht der Fall, dort akzeptiert die internationale Firmware den Wert "avm" nicht und die deutsche Firmare den Wert "avme" nicht.
Das funktioniert nicht nur bei den Laborversionen so sondern auch bei den Release-Versionen der 6890 LTE. Es gibt beim Image für die Ver. 6.87 der 6890 keinen Unterschied zwischen der internationalen und deutschen Variante.
Wozu? in der Int. ist doch schon deutsch dabei, oder geht es hier nicht nur um die Sprache?
Bei den Modellen wo (noch) zwischen der deutschen und internationalen Firmware unterscheiden wird gibt es mehr Unterschiede als nur die Sprachauswahl.
--- Zusammengeführt ---
Auch hier gilt das gleiche wie oben geschrieben. Das liegt einfach nur daran, dass es überhaupt keinen Unterschied gibt zwischen dem jeweiligen "deutschen" Firmware-Image und dem "en-de-es-it-fr-pl(-nl)" Image. Deshalb spielt es ja auch keine Rolle welche der beiden Dateien du herunterlädst beim 1750E (bei gleicher Versionsnummer), die sind beide absolut identisch. Genaugenomen veräppelt uns da AVM eigentlich auf ihren Download-Servern nur. ;)
Na für die internationale Variante der 7590 (Artikel-Nr. beispielsweise 2000-2804 (int.) oder 2000-2814 (A/CH) anstatt 2000-2784 für die deutsch Retail-Variante). Das schließt die A/CH-Variante mit ein (da ist ja auch nicht neu, war ja schon bei der 7490, 7390 usw. der Fall).
... ich meine aber die FW, um die es hier geht.
Um nichts anderes geht es.
Das war vermutlich eher ein Fehler oder Bug in dieser speziellen Version. Auch könnte ein solches Verhalten trotz identischer Firmware-Images auch durch Bootloader-Variablen wie "counry" und "language" beeinflusst werden. Würde mich auch nicht wundern wenn sich diesbezüglich die Artikel-Nr. 2000-2817 und 2000-2818 (nur) in diesem Punkt unterscheiden.
Dem würde ich mal widersprechen (bezüglich "erstmals", nicht was die einheitliche Firmware generell betrifft).
Denn eigentlich sprach auch schon bei der 7490 (trotz der Unterschiede bezüglich der TAE-Buchsen) nichts gegen eine einheitliche Firmware für de und int. Zumindest nicht wegen der TAE-Buchsen (die der internationalen Version fehlten), die sind ja auf dem PCB sowieso nur parallel mit den beiden RJ11-Buchsen verbunden und somit macht die Firmware diesbezüglich auch keinen Unterschied beziehungsweise "sieht" sie es überhaupt nicht ob da die TAE-Buchsen auf dem PCB überhaupt bestückt sind oder nicht.
Also im Sinne von "erstmals" wäre es meiner Ansicht nach auch schon bei der 7270 oder 7390 möglich gewesen oder vielleicht sogar schon bei der 7170. Aber Sinn hätte das wohl (wenn überhaupt) auch erst mit den NAND-Boxen gemacht (7390 ausgenommen weil da die Firmware noch im NOR-Flah lag) wo nun genug Speicher für die Firmware zur Verfügung steht. Also erstmals hätte das eigentlich schon mit der 3370, 3390 oder 7490 gemacht werden können.
@NDiIPP
Da ich seit längerem mit der Laborversion unterwegs bin, hab ich diesen Test noch nicht gemacht.
Das Urteil über "erstmals" bezog sich nur auf die optisch sichtbaren Unterschiede. Ich konnte weder bei der 7490, noch bei der 7490-int irgendwelche Einbußen feststellen, wenn ich die mit der jeweils anderen Firmware betrieben habe.
Die Artikelnummern beziehen sich sicherlich hauptsächlich auf den Inhalt der Verpackung.
Also um noch präziser zu werden: mittlerweile sind die Boxen in der Verpackung wohl baugleich. Das sollte sich auch in der Firmware etablieren. Bei allen Boxen.
Falls ich etwas nicht falsch verstanden habe, könnte man theoretisch die hier behandelte FW patchen, sodass sie auch auf DE-7590 einfach aufspielbar wäre?
Dann könnte man sich doch den eher mühsamen Weg des Debrandens sparen, seitdem die neueren Bootloaderversionen die vormals einfacheren Wege versperrt haben.
Komisch, dass keiner der FW-Gurus sich das mal genauer angeschaut hat, wie man eine FW minimalinvasiv (ohne Freetz-Umgebung) hinbiegen könnte, sodass sie von avm-, avme- und 1und1-Branding geschluckt würde?
LG und sorry, falls ich dies verpeilt habe und dies Vorgehen irgendwo beschrieben steht.
Das würde ich prinzipiell auch begrüßen. Ich hatte eigentlich auch schon mal damit gerechnet, dass das AVM bei allen neuen Modellen mal so machen wird (nicht nur bei einigen).
Aber vielleicht möchte man das, zumindest bei den DSL-Modellen die auch in größeren Mengen vertrieben werden, nicht (die 6890 LTE dürfte wohl nicht so oft verkauft werden wie die 7590, zudem die 6890 LTE auch nicht als 1und1-Modell zu bekommen ist). Vielleicht um auch schneller auf deutsche oder international auftretende Veränderungen (beispielsweise was die Anbieter-Profile betrifft) reagieren zu können.
Aber vielleicht (alles nur Mutmaßungen) möchte man auch deutsch und international nicht zusammenführen wenn es vom entsprechenden Modell auch eine 1und1-Variante gibt (wie bei der 7530, 7560 oder hier der 7590). Würde ja dann bedeuten, dass man auch die (vielleicht günstiger zu bekommenden) 1und1-Modelle einfacher im internationalen Bereich verwenden kann (sogar noch einfacher als früher wo man erst die Branding-Variable ändern musste, das würde dann ja sogar entfallen, das ist vielleicht weder im Sinne von AVM noch von 1und1), die gemeinsame Firmware akzeptiert dann ja nicht nur avm und avme sondern auch 1und1 als Wert bei der Branding-Variable.
Also von der Hard- und Software wäre es prinzipiell kein Problem (auch schon bei früheren Modellen wie der 7490) so wie bei der 4020, 4040, 6890 usw. eine gemeinsame Firmware für die deutsche und internationale Variante anzubieten. Das hätte ja auch den Vorteil der Sprachwahl im deutschen Markt welcher meiner eigenen Erfahrung nach auch bei AVM Produkten tatsächlich schon nachgefragt wurde, beispielsweise bei einem Finnen (der in Deutschland arbeitet), der wollte damals lieber Englisch als Sprache eingestellt haben anstatt deutsch. Das war aber damals bei FRITZ!Fax (auf dem Windows-PC in der englischen Variante) nur mit einem Versions-Downgrade möglich und bei der Fritzbox nur wenn man die (damals ebenfalls ältere) internationale Firmware installiert hätte. Letztlich hat er sich deshalb dann doch mit der deutschen Sprache bei den Soft- und Hardware-Produkten von AVM arrangiert (der Rest war auf Englisch eingestellt).
Aber vielleicht hat AVM eben doch noch andere Gründe (siehe oben) weshalb man bei bestimmten Produkten deutsch und international, zumindest bezüglich der Software, weiterhin trennen möchte.
... könnte man theoretisch die hier behandelte FW patchen, sodass sie auch auf DE-7590 einfach aufspielbar wäre?
Ja klar geht das.
... sich das mal genauer angeschaut hat, wie man eine FW minimalinvasiv (ohne Freetz-Umgebung) hinbiegen könnte, sodass sie von avm-, avme- und 1und1-Branding geschluckt würde?
Da die Freetz-Buildumgebung für mich eigentlich fast immer griffbereit ist habe ich zumindest noch kein Bedürfnis dazu verspürt einen solchen Weg zu finden.
Das prinzipielle Vorgehen ist ja mittlerweile auch in Beitrag #1 des bekannten "Branding-Threads" von @*Eisbär* als "4. Variante" verlinkt.
0xFaB1
