[Info] Fritz!Box als GSM-Gateway für Sprachtelefonie über UMTS-Stick (u.a 736x, 7390, 7490)
Bei der Verwendung von O²-SIM-Cards sollte man stets Roaming gestatten, da die Stick-Firmwares den Zusammenschluss von E-Plus und O² bzw. die gemeinsame Netzkennungen nicht kennen.
LG
Do You use the international version of Fritz!Box 7490 and 7.01 Firmware?
LG
Edit: Btw a short view e.g. https://routerunlock.com/download-firmware-huawei-e3276-hilink-normal-modem/ there are a plenty of "21"-FW for this stick. May be that one of these do have another HW-ID, unrecognized by Fritz!-Firmware.
Thanks for your reply!
Yes I use International version fw. Now I try to ask support from AVM, but without hope. Your link for Huawei FW is safe? Looks "interesting".
Any ways, it's a surprise that a common old Huawei LTE stick is not supported by Fritz. Not supported D-Link is not a big surprise. I have checked about 5 other pices USB sticks, 3pcs. old 3G huawei worked, but none LTE. Maybe I have to buy a TpLink and use with OpenWrt for networking... but I need Fritz because its wonderful VOIP support.
You should remember, that all "newer" Huawei-LTE-Sticks neither with HiLink nor without HiLink-FW are voicecapabale to realize a CVS-Mode (Circuit-Voice-System). You may have a look (some years ago) here in the thread for creating a special usbgsm.cfg for changing/assigning the Vendor-ID/Hardware-ID of the Stick, to be supported by the FB. My last/newest Stick is the E3372-s, which worked with both Stick-FW (Hi and None-HiLink) for just a I-Net-Mobile-Connection which is not the Topic here (CVS).
For Info from FB7490 FW7.01(DE-Version) to find the HW-ID for Your Stick
# cat usbgsm.cfg
VER=:15
V=:0421:05c6:0af0:1199:12d1:1410:16d8:1bbb:1c9e:1e0e:19d2:1ee8:
V=:0b3c:07d1:2357:0fce:
C=:1199:400b01
C=:12d1:000301
C=:19d2:c0a115
C=:0fce:c01102
B=:16d8:555342431234567800000000000009ff524445564348473100000000000000
B=:1c9e:1bbb:55534243123456780000000080000606f50402527000000000000000000000
B=:05c6:0af0:55534243123456780100000080000601000000000000000000000000000000
B=:1e0e:555342431234567800000000000006bd000000020000000000000000000000
B=:12d1:55534243876543210000000000000011062000000100000000000000000000
B=:12d1:55534243000000000000000000000611060000000000000000000000000000
B=:12d1:55534243123456780000000000000011062000000101000100000000000000
B=:0b3c:5553424312345678c000000080010606f50402527000000000000000000000
B=:0421:05c6:0af0:1199:12d1:1410:16d8:1bbb:1c9e:1e0e:19d2:1ee8:5553424312345678000000000000061b0000000200000000000000000
00000
B=:0b3c:07d1:2357:0fce:5553424312345678000000000000061b000000020000000000000000000000
B=:12d11446:12d11449:12d114ad:12d114b5:12d114b7:12d114ba:12d114c1:12d114c3:12d114c4:12d114c5:12d114d1:12d114fe:555342431
B=:12d11505:12d1151a:12d11520:12d11521:12d11523:12d11526:12d11527:12d11553:12d11557:12d1155a:12d1155b:12d1156a:12d1157c:
12d1157d:55534243123456780000000000000011062000000101000100000000000000
B=:12d11580:12d11581:12d11582:12d11583:12d11597:12d115ca:12d115cd:12d115ce:12d115cf:12d115d0:12d115d2:12d115e7:555342431
B=:12d11c0b:12d11c1b:12d1c24:55534243123456780000000000000011062000000101000100000000000000
B=:12d11f01:12d11f02:12d11f03:12d11f04:12d11f05:12d11f06:12d11f07:12d11f09:555342431234567800000000000000110620000001010
00100000000000000
B=:12d11f11:12d11f15:12d11f16:12d11f17:12d11f18:12d11f1b:12d11f1c:12d11f1d:12d11f1e:555342431234567800000000000000110620
B=:12d11f19:55534243000000000000000000000611060000000000000000000000000000
S=:1c9e3003:2
S=:0fced0cf:3
S=:0fced0e1:2
M=:0af07251:D2
M=:1c9e9603:D2
M=:1c9e9605:D3V2C1
M=:1c9e3003:D1C2V3
M=:11996880:D3
M=:119968a3:D2
M=:1bbb0000:D2
M=:12d11001:12d11c05:12d114c9:12d11506:D0V1C2
M=:12d11003:12d11c08:D0C1
M=:12d1140c:12d11436:12d11465:12d114ac:D0V2C3
M=:12d11444:D1C0
M=:1e0e9000:D2
M=:19d20031:19d20117:D2C1
M=:19d20063:19d20104:D3C1
M=:19d20143:D0C1
M=:19d22003:D3V2C1
M=:19d21592:D0V2C1
full quote removed
Sorry I could not identify the corresponding topic in this forum to my problem. I don't need CVS-mode telephony, I need only Voip. But Is it really possible to edit usbgsm.cfg in order to FB support my stick?
//edit by stoney: set [QUOTE] TAG [/QUOTE] correctly
I suggest, it would be more easy to flash a HiLink-FW e.g. 22.470.13.00.00
for Tethering-Mode than finding a generic 21.Firmware which is recognized by the FB7490 and therein the usbgsm.cfg. Editing etc. the usbgsm.cfg is not as easy for beginners, because "tainted FWs" for the FB7490international are rare ;)
LG
Edit: For Your Model calculate a flash-code and Look here e.g.
full quote removed by stoney
Thanks for your support. First I wait for AVM support's reply... maybe...
But I bought this Huawei USB modem beacuse I wanted that Fritzbox get the private IP from mobile supplier without NAT. I also have an Huawei B593s mobile router which works properly, but I can not switch off its NAT. I also asked AVM support to provide me the supported mobile sticks, but I not yet got reply. Is there such a list anywhere? I do not want to by again a not supported stick.
Ps: Earlier I had to edit voip.cfg in Fritzbox. There is a program which converts the edited file to FB compatible and this works now too. Can you provide the method or link how can I edit usbgsm.cfg? Then I decide what to do.
Sorry I cannot follow Your intention about "without NAT"? Most mobile Network-Supplier are working with CGN and selden with APNs, which provides a public IPv4.
I remember these mentioned intention how AVM may handle nowadays with FW7.0x the elder UMTS-Sticks and newer LTE-Sticks together?
There is also an example for modifying the usbgsm.cfg from several Huawei-HW-Ids e.g.
M=:12d11001:12d11c05:12d114c9:12d11506:12d1<ID-ofyour-Stick>:D0V1C2
where iirc 12d1=Huawei and D0V1C2=the several combined Switching-Commands for the supported "Device-parts" of the Stick.
Therefore You need telnet or SIAB on the FB7490 ...
But please create a new thread, because we are moving to far from Topic
LG
Der Stick ist Frei von Simlock etc.
Ich hab den Stick mal unter Windows-XP angeschlossen. Es wird automatisch die Zugangssoftware installiert. Dann kommt eine Auswahl von Mobilfunkanbietern, hauptsächlich von Vodafone. Mein Anbieter aus dem O2-Netz ist nicht dabei. Ich habe Vodafone.de gewählt. Danach meldet die Zugangssoftware, dass eine andere SIM-Karte gefunden wurde und fragt ob diese verwendet werden soll. Das habe ich mit ja beantwortet, Meine SIM-Karte wird danach aber nicht angezeigt (siehe Bilder).
Versuche es mal mit Mobile Partner oder mwconn als Dashboard-Software
LG
Gesendet von meiner Handquetsche mit dicken Fingern
Diese Sticks haben eine Vodafone-gebrandete Windows-Software. Um die mit anderen Providern zu verwenden muß man irgendeine xml-Datei editieren. Für den Betrieb an der Fritzbox ist das egal, da wird die auf dem Stick vorhandene Software nicht installiert.
Ich habe versucht das Dasboard von dieser Seite herunterzuladen:
http://www.surf-stick.net/software/huawei-mobile-partner.html
Von dieser seite wird man dann weitergeleitet zum Download:
http://download4.freefiles-18.de/software/s83035/d27502/27/502/Huawei_E1550_MobilePartner_v16.zip
Allerdings sperrt mein Eset Nod32 Antivirus den Zugriff auf diese Seite wegen gefärlicher Inhalte.
@erik
Meine Fritzbox-7390 erkennt den Stick leider nicht (es erscheint unter Internet kein Menüpunkt Mobielfunk).
Ich dachte daher man muss an dem Stick noch irgendwas konfigurieren.
Musst dich einmal über die Box mit dem Stick ins Internet verbinden dann sollte der Stick den Punkt Mobilfunk verfügbar sein. Falls nicht ist der Stick nicht kompatibel.
über die Box mit dem Stick ins Internet verbinden .........Punkt Mobilfunk verfügbar sein.
Wie soll das gehen, wenn der TS den Stick bisher nicht an der FB zum laufen bekommen hat.
Gesendet von meinem GS370_Plus mit Tapatalk
Das "riecht" eher nach einer zu schwachen USB-Stromversorgung seitens der FB7390, falls im Ereignislog keinerlei "Event" zu Massenspeicher, Huawei etcpp auftaucht. Ein aktiver USB-Hub dürfte Abhilfe schaffen.
LG
oder einfach ein defekter USB-Port an der Box. Soll ja bei der 7390 nicht ganz selten sein. Wird denn die Speicherkarte im Stick erkannt?
Oder das 2A Netzteil der Fritte ist durch. Mein ehemaliger Huawei E173u-2 lief am der 7390 7490 ohne Probleme. Bei der 7490 hatte ich USB 3.0 aktiviert.
Der USB-Anschluss ist in Ordnung. Ander USB-Geräte werden erkannt. Ich hab jetzt mal eine andere FritzBox- 7390 von 1&1 probiert. Bei der habe ich jetzt einen Eintrag Mobilfunk unter Internet. Aber es fehlt die Rubrik Telefonie über Mobilfunk. Es gibt lediglich einen Eintrag: Internettelefonie über mobile Internetverbindung (siehe Anhang). Muss ich bei der 7390 noch irgendetwas freischalten?
Baue mit einer geeigneten SIM-Card die mobile Internetverbindung mal kurz auf. Falls die Stick-Firmware voicefähig, taucht das Mobilfunknummern-Fenster wie von selbst auf. Bei O² empfiehlt sich zudem das Roaming zu gestatten, da der Zusammenschluss mit E-Plus in der Stickfirmware altersbedingt nie ankam.
LG
OK, jetzt funktioniert es.
Kann ich für das GSM-Gateway auch eine Anbietervorwahl zuordnen? Sowas wie die 0000000000 für den analogen Telefonanschluss. Wenn ja wie lautet die?
Dorko
