[gelöst]FBF 7140 config freetz 1.1.2
arthi
25 Jun 2006
Hello, schreiben Sie mir bitte ob es alles in Ordnung ist. Unten ist mein config. Das image was immer zu gross und jetzt habe ich zwei image internal und external, aber was weiter? Erst muss ich internal image an fritz!box instalieren und dann external? Wo kann ich daruber lesen. Ich habe USb Festplatte Samsung mit filesystem FAT32http://trac.freetz.org/wiki/FAQ#Filesystemimagetoobig
# Automatically generated make config: don't edit
FREETZ_HAVE_DOT_CONFIG=y
# General --------------------------------
FREETZ_AVM_VERSION_04_67=y
# FREETZ_TYPE_300IP_AS_FON is not set
# FREETZ_TYPE_2170 is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_FON_5010 is not set
# FREETZ_TYPE_FON_5050 is not set
# FREETZ_TYPE_FON_5140 is not set
# FREETZ_TYPE_FON_WLAN is not set
# FREETZ_TYPE_FON_WLAN_7050 is not set
# FREETZ_TYPE_FON_WLAN_7112 is not set
# FREETZ_TYPE_FON_WLAN_7113 is not set
FREETZ_TYPE_FON_WLAN_7140=y
# FREETZ_TYPE_FON_WLAN_7141 is not set
# FREETZ_TYPE_FON_7150 is not set
# FREETZ_TYPE_FON_WLAN_7170 is not set
# FREETZ_TYPE_FON_WLAN_7240 is not set
# FREETZ_TYPE_FON_WLAN_7270 is not set
# FREETZ_TYPE_FON_WLAN_7270_V3 is not set
# FREETZ_TYPE_WLAN_3020 is not set
# FREETZ_TYPE_WLAN_3030 is not set
# FREETZ_TYPE_WLAN_3130 is not set
# FREETZ_TYPE_WLAN_3131 is not set
# FREETZ_TYPE_WLAN_3170 is not set
# FREETZ_TYPE_WLAN_3270 is not set
# FREETZ_TYPE_WLAN_3270_V3 is not set
# FREETZ_TYPE_SPEEDPORT_W501V is not set
# FREETZ_TYPE_CUSTOM is not set
FREETZ_AVM_VERSION_STRING="04.67"
# FREETZ_TYPE_LANG_DE is not set
# FREETZ_TYPE_LANG_A_CH is not set
FREETZ_TYPE_LANG_EN=y
FREETZ_TYPE_LANG_STRING="en"
FREETZ_TYPE_ANNEX_A=y
# FREETZ_TYPE_ANNEX_B is not set
FREETZ_TYPE_STRING="7140"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_REPLACE_KERNEL_AVAILABLE=y
# FREETZ_REPLACE_KERNEL is not set
FREETZ_SHOW_ADVANCED=y
FREETZ_TARGET_REF="8mb_26"
FREETZ_KERNEL_REF="8mb_26"
FREETZ_KERNEL_LAYOUT="ohio"
FREETZ_KERNEL_MTD_SIZE=119
FREETZ_HAS_PHONE=y
# FREETZ_HAS_TAM is not set
FREETZ_HAS_WLAN=y
# FREETZ_HAS_USB_CLIENT is not set
FREETZ_HAS_USB_HOST=y
# FREETZ_HAS_AVM_INETD is not set
FREETZ_HAS_LIBSSL=y
# Mod ------------------------------------
# FREETZ_LANG_DE is not set
FREETZ_LANG_EN=y
FREETZ_LANG_STRING="en"
# Patches
# Remove Brandings
# FREETZ_REMOVE_BRANDING_avme is not set
FREETZ_REMOVE_HELP=y
FREETZ_PATCH_ENUM=y
FREETZ_PATCH_SIGNED=y
FREETZ_PATCH_USBSTORAGE=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
# FREETZ_AUTOMOUNT_EXT2 is not set
FREETZ_AUTOMOUNT_EXT3=y
FREETZ_AUTOMOUNT_NTFS=y
# FREETZ_AUTOMOUNT_REISER_FS is not set
FREETZ_AUTORUN_AUTOEND=y
FREETZ_PATCH_MAXDEVCOUNT=y
# FREETZ_PATCH_GETCONS is not set
FREETZ_REMOVE_UPNP=y
# FREETZ_REMOVE_UPNP_LIBS is not set
FREETZ_REMOVE_USERMAN=y
# FREETZ_REMOVE_FTPD is not set
# FREETZ_REMOVE_MEDIASRV is not set
# FREETZ_REMOVE_SMBD is not set
FREETZ_REMOVE_DSLD=y
# FREETZ_REMOVE_CAPIOVERTCP is not set
# FREETZ_REMOVE_VOIP_ISDN is not set
# FREETZ_REMOVE_WLAN is not set
# Package selection
# *** not all packages support selected language ***
# FREETZ_SELECTED_LANG_ONLY is not set
# Standard packages
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BRIDGE_UTILS is not set
FREETZ_PACKAGE_CALLMONITOR=y
# FREETZ_PACKAGE_CHECKMAILD is not set
# FREETZ_PACKAGE_CIFSMOUNT is not set
# FREETZ_PACKAGE_CPMACCFG is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DECO is not set
FREETZ_PACKAGE_DNSMASQ=y
# FREETZ_PACKAGE_DROPBEAR is not set
FREETZ_PACKAGE_DTMFBOX=y
# CAPI/SIP
FREETZ_PACKAGE_DTMFBOX_WITH_CAPI=y
FREETZ_PACKAGE_DTMFBOX_WITH_VOIP=y
FREETZ_PACKAGE_DTMFBOX_WITH_ICE=y
# Codecs
FREETZ_PACKAGE_DTMFBOX_WITH_G711_CODEC=y
# FREETZ_PACKAGE_DTMFBOX_WITH_SPEEX_CODEC is not set
# FREETZ_PACKAGE_DTMFBOX_WITH_GSM_CODEC is not set
# Misc
# FREETZ_PACKAGE_DTMFBOX_SVN is not set
# FREETZ_PACKAGE_DTMFBOX_USE_DIFF_PATCH is not set
FREETZ_PACKAGE_DTMFBOX_WITH_WEBPHONE=y
FREETZ_PACKAGE_DTMFBOX_WITH_HELP=y
# FREETZ_PACKAGE_DTMFBOX_WITH_ESPEAK is not set
# FREETZ_PACKAGE_DTMFBOX_WITH_MADPLAY is not set
FREETZ_PACKAGE_ESPEAK=y
FREETZ_PACKAGE_ESPEAK_ALL_LANGUAGES=y
# FREETZ_PACKAGE_FUSE is not set
# FREETZ_PACKAGE_INETD is not set
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MINI_FO is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NETSNMP is not set
FREETZ_PACKAGE_NTFS=y
# FREETZ_PACKAGE_OPENNTPD is not set
# FREETZ_PACKAGE_OPENVPN is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_PRIVOXY is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_SAMBA is not set
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TOR is not set
# FREETZ_PACKAGE_VPNC is not set
# FREETZ_PACKAGE_VSFTPD is not set
# Web interface
# FREETZ_PACKAGE_DOWNLOADER is not set
# FREETZ_PACKAGE_NFSD_CGI is not set
# FREETZ_PACKAGE_RRDSTATS is not set
# FREETZ_PACKAGE_SPINDOWN_CGI is not set
# FREETZ_PACKAGE_SYSLOGD_CGI is not set
# FREETZ_PACKAGE_VIRTUALIP_CGI is not set
# FREETZ_PACKAGE_WOL_CGI is not set
# Debug helpers
# FREETZ_PACKAGE_LDD is not set
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Testing
# FREETZ_GROUP_APACHE_PHP is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_DTACH is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# FREETZ_PACKAGE_EMPTY is not set
FREETZ_PACKAGE_FSTYP=y
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_HD_IDLE is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NFS_UTILS is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_PORTMAP is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RRDTOOL is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SQUID is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# FREETZ_PACKAGE_TINYPROXY is not set
FREETZ_PACKAGE_TRANSMISSION=y
FREETZ_PACKAGE_TRANSMISSION_CLIENT=y
FREETZ_PACKAGE_TRANSMISSION_DAEMON=y
FREETZ_PACKAGE_TRANSMISSION_REMOTE=y
FREETZ_PACKAGE_TRANSMISSION_STATIC=y
FREETZ_PACKAGE_TRANSMISSION_WEBINTERFACE=y
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_USBROOT is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_WGET is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
FREETZ_SHOW_UNSTABLE_PACKAGES=y
# Unstable
# FREETZ_PACKAGE_COLLECTD is not set
# FREETZ_PACKAGE_IPTABLES is not set
# SANE
# FREETZ_PACKAGE_SANE_BACKENDS is not set
# FREETZ_PACKAGE_TINC is not set
# FREETZ_PACKAGE_USBIP is not set
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_MODCGI=y
# Advanced options
FREETZ_DL_OVERRIDE=y
FREETZ_DL_SITE="ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7140/firmware/english/annex_a"
FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7140.AnnexA.en.39.04.67.image"
# Freetz package download sites
FREETZ_MOD_DL_NUM_SITES="5"
# Download site #1 - default: http://freetz.3dfxatwork.de
FREETZ_MOD_DL_SITE_1="http://freetz.3dfxatwork.de"
# Download site #2 - default: http://freetz.wirsind.info
FREETZ_MOD_DL_SITE_2="http://freetz.wirsind.info"
# Download site #3 - default: http://freetz.magenbrot.net
FREETZ_MOD_DL_SITE_3="http://freetz.magenbrot.net"
# Download site #4 - default: empty (reserved for later use)
FREETZ_MOD_DL_SITE_4=""
# Download site #5 - user-defined
FREETZ_MOD_DL_SITE_5=""
FREETZ_VERBOSITY_LEVEL=0
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_SUBVERSION_STRING=y
# FREETZ_DEVELOPER_VERSION_STRING is not set
FREETZ_STATUS_STYLE=y
# External
EXTERNAL_ENABLED=y
# EXTERNAL_SUBDIRS is not set
EXTERNAL_CREATEPAK=y
EXTERNAL_DIR1=y
# EXTERNAL_DIR2 is not set
# EXTERNAL_DIR3 is not set
# EXTERNAL_CUSTOM_DIR is not set
EXTERNAL_DIRECTORY="/var/media/ftp/uStor01/external/"
EXTERNAL_OWN_FILES=""
# packages
EXTERNAL_FREETZ_PACKAGE_ESPEAK=y
EXTERNAL_FREETZ_PACKAGE_DTMFBOX=y
# EXTERNAL_FREETZ_PACKAGE_NTFS is not set
EXTERNAL_FREETZ_PACKAGE_TRANSMISSION_CLIENT=y
EXTERNAL_FREETZ_PACKAGE_TRANSMISSION_DAEMON=y
EXTERNAL_FREETZ_PACKAGE_TRANSMISSION_REMOTE=y
EXTERNAL_FREETZ_PACKAGE_TRANSMISSION_WEBINTERFACE=y
# services
# libraries
# EXTERNAL_FREETZ_LIB_libcrypto is not set
EXTERNAL_FREETZ_LIB_libresolv=y
EXTERNAL_FREETZ_LIB_libcurl=y
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
# FREETZ_SQUASHFS_BLOCKSIZE_16384 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_32768 is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
# FREETZ_SQUASHFS_BLOCKSIZE_131072 is not set
# BusyBox options
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_DIFF is not set
FREETZ_BUSYBOX_INETD=y
# FREETZ_BUSYBOX_IP is not set
# FREETZ_BUSYBOX_PATCH is not set
FREETZ_BUSYBOX_START_STOP_DAEMON=y
FREETZ_BUSYBOX_WGET=y
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_NICE is not set
# FREETZ_BUSYBOX_LS_COLOR is not set
# FREETZ_BUSYBOX_FASTPROC is not set
# FREETZ_BUSYBOX_KEYS is not set
# FREETZ_BUSYBOX_BRCTL is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_SEQ is not set
# FREETZ_BUSYBOX_TAC is not set
# FREETZ_BUSYBOX_MDEV_RENAME is not set
# FREETZ_BUSYBOX_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_MOUNT_LABEL is not set
# FREETZ_BUSYBOX_VOLUMEID is not set
# Kernel modules
# crypto
# FREETZ_MODULE_aes is not set
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_sha1 is not set
# FREETZ_MODULE_sha256 is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_async is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_ppp_generic is not set
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_slhc is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_hci_usb is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# fs
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
FREETZ_MODULE_ext3=y
# FREETZ_MODULE_ext2 is not set
# FREETZ_MODULE_fat is not set
FREETZ_MODULE_fuse=y
FREETZ_MODULE_jbd=y
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_ntfs is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_smbfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_vfat is not set
# FREETZ_MODULE_msdods is not set
# FREETZ_MODULE_jffs2 is not set
FREETZ_MODULE_mbcache=y
# lib
# FREETZ_MODULE_crc_ccitt is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_l2cap is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
# Shared libraries
# FREETZ_STRIP_LIBRARIES is not set
# Libraries -------------------------------
# FREETZ_LIB_libatm is not set
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libxyssl is not set
FREETZ_LIB_libcrypto=y
FREETZ_LIB_libssl=y
# FREETZ_LIB_libavmhmac is not set
# Data compression
FREETZ_LIB_liblzo2=y
FREETZ_LIB_libz=y
# Graphics & fonts
# FREETZ_LIB_libfreetype is not set
# FREETZ_LIB_libart_lgpl_2 is not set
# FREETZ_LIB_libjpeg is not set
# FREETZ_LIB_libpng12 is not set
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
# FREETZ_LIB_libutil is not set
FREETZ_LIB_libuClibc__=y
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libglib_1 is not set
# GLib2
# FREETZ_LIB_libglib_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# ncurses
# FREETZ_LIB_libncurses is not set
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
# FREETZ_SHARE_terminfo is not set
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
FREETZ_LIB_libcapi20=y
FREETZ_LIB_libevent=y
# FREETZ_LIB_libexpat is not set
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libpcap is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# FREETZ_LIB_libusb is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libintl is not set
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libftdi is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libdevmapper is not set
# Compiler options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_TARGET_CFLAGS="-Os -pipe -march=4kc -Wa,--trap"
FREETZ_JLEVEL=2
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
FREETZ_KERNEL_VERSION_2_6_13_1=y
# FREETZ_KERNEL_VERSION_2_6_19_2 is not set
FREETZ_KERNEL_VERSION="2.6.13.1"
# FREETZ_TARGET_UCLIBC_VERSION_0_9_28 is not set
FREETZ_TARGET_UCLIBC_VERSION_0_9_29=y
FREETZ_TARGET_GCC_VERSION="4.2.1"
FREETZ_TARGET_UCLIBC_VERSION="0.9.29"
FREETZ_TARGET_BINUTILS_VERSION="2.17.50.0.17"
FREETZ_TARGET_UCLIBC_REF="mod"
# FREETZ_STATIC_TOOLCHAIN is not set
FREETZ_TARGET_GXX=y
FREETZ_TARGET_CCACHE=y
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
FREETZ_KERNEL_GCC_VERSION="3.4.6"
FREETZ_KERNEL_BINUTILS_VERSION="2.17.50.0.17"
# FREETZ_TARGET_TOOLCHAIN is not set
# GNU debugger (gdb)
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_GDB_SERVER is not set
# FREETZ_PACKAGE_GDB_HOST is not set
Zuerst external und dann internal.
FREETZ_LIB_libssl=y
Hast Du bei der Image-Erstellung einen Hinweis mit einem Link erhalten?
Ich habe librcrypto und libcurl liberies auf external USB speichern und fur transsmision habe ich statically link markieren.
Hmm... tatsachlich
Caution: Replacing libcrypto or libssl may cause an unusable image. See http://trac.freetz.org/wiki/FAQ#NachdemFlashenistdasAVM-Webinterfacenichtmehrerreichbar for details.
Ich habe es nicht gesehen
Muss Replace libavmhmac markieren?
Ich habe librcrypto und libcurl liberies auf external USB speichern ...
# EXTERNAL_FREETZ_LIB_[COLOR="Red"]libcrypto is not set[/COLOR]
...was ja OK ist.
EDIT:
Probier mal. Bei mir funktioniert das nicht.
Aber wenn Du statisch linken tust, warum brauchst Du die libcrypto und die libssl in deinem Image? Ich würde neu konfigurieren und schauen, dass ich die libcrypto und die libssl nur statisch im Image habe.
Wie wäre es mal mit Deutsch? Das hier ist grandios daneben, sry, denn ich verstehe nicht, wieso du dein PRoblem nicht in den Griff bekomms,t wo du doch schon einen Wiki-Link zur Behebung deines Problems direkt am Ende des Buildvorgangs beschrieben bekommst.
EXTERNAL_FREETZ_LIB_libcrypto=y
Aber das Problem mit liberies ist wieder da. Das muss noch etwas sein....
Ja, lustigerweise hab ich die Warnung damals wegen der libcrypto und der libssl gemacht. Und welche ist drin? Und welche hast du nun drin im Image (oder external, das ist _vollkommen_ irrelevant)?
Bei mir auch!
ich habe auch ohne statically link probieren, auch ohne external liberies...
Ich habe noch eine probieren!
Auch wenn eigentlich kein Paket mehr die OpenSSL-Libs benötigt, kann es sein, dass diese immer noch ins Image gepackt werden. Das kommt daher, dass menuconfig eine automatische Abwahl nicht unterstützt. Hierfür gibt es den Befehl make config-clean-deps.
make
Jetzt is in Ordnung. Vielen Dank!
FREETZ_HAS_PHONE=y
FREETZ_HAS_WLAN=y
FREETZ_HAS_LIBSSL=y
FREETZ_LANG_EN=y
# Patches
# Remove Brandings
FREETZ_PATCH_ENUM=y
# Package selection
# Standard packages
# CAPI/SIP
# Codecs
# Misc
# Web interface
# Debug helpers
# Testing
# Unstable
# SANE
# Advanced options
# External
EXTERNAL_ENABLED=y
EXTERNAL_DIR1=y
# packages
# services
# libraries
# BusyBox options
# FREETZ_BUSYBOX_INETD is not set
# Kernel modules
# crypto
# drivers
# fs
FREETZ_MODULE_jbd=y
# lib
# net
# Shared libraries
# Crypto & SSL
# FREETZ_LIB_libcrypto is not set
# Data compression
# FREETZ_LIB_liblzo2 is not set
# FREETZ_LIB_libz is not set
# Graphics & fonts
# uClibc
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
# FREETZ_LIB_libresolv is not set
FREETZ_LIB_librt=y
# GLib2
# ncurses
# terminfo database
# FREETZ_LIB_libcurl is not set
# FREETZ_LIB_libevent is not set
# Readline
# Compiler options
FREETZ_JLEVEL=2
FREETZ_TARGET_GXX=y
FREETZ_TARGET_LFS=y
Daniel_913
