[gelöst-solved] 7240 don't install firmware major xx.04.xx
Tokka
1 Aug 2006
Hi all, i have a strenge question, and overall a strange situation :(
I use a 7240, a sometimes ago i opened a ticket on freetz beacuse i had a lot of failure tu upgrade the firmware. I supposed it was a freetz bug, but recently i discovedered it was a bug of my fritz.
It seems it don't like firmware xx.05.xx....:confused:
If i use firmware 73.04.xx it works, if i use alien firmware xx.04.xx works too, but if use firwmare 73.05.xx, alien xx.05.xx, or if i use original firmware or made a recovery with avm tool 73.05.xx it crash, and reboot all time.
Have anyone some ideas to where i can look to solve?
Thanks in advance
Tokka
Did you try to flash a firmware like xx.05.xx with the rukernelTool?
If not please do so and give a response here please....
It works great, thanks a lot!!! :groesste::groesste:
Asap i will try some experiments :kasper:
Regards
Tokka
Yes, with ruKernelTool i succesfully upgraded to firmware 73.05.xx :D
Just a little bit hard, but very powerfull.
I would like to make some test with it, just for curiosity :P
Mfg
Tokka
great, please set the thread by editing your 1st Post to "gelöst" :-)
me2k
