[Problem] Hilfe! fehler beim Bau von freetz-dhu für 7490
axleu
13 Nov 2011
hab eine Frage zur fork freetz-dhu.
Beim Bau bekomme ich folgende Fehlermeldung:
/bin/mkdir -p /home/freetz/7940_trunk_7.0x/freetz-dhu/freetz/toolchain/build/mips_gcc-5.5.0_uClibc-1.0.14-nptl_kernel-3.10/mips-linux-uclibc/usr/lib
/usr/bin/install -c -m 644 libnettle.so /home/freetz/7940_trunk_7ß.0x/freetz-dhu/freetz/toolchain/build/mips_gcc-5.5.0_uClibc-1.0.14-nptl_kernel-3.10/mips-linux-uclibc/usr/lib/libnettle.so.6.4
[ -z "libnettle.so.6" ] \ || (cd /home/freetz/7940_trunk_7.0x/freetz-dhu/freetz/toolchain/build/mips_gcc5.5.0_uClibc-1.0.14-nptl_kernel-3.10/mips-linux-uclibc/usr/lib \
        && rm -f libnettle.so.6 libnettle.so \
        && ln -s libnettle.so.6.4 libnettle.so.6 \
        && ln -s libnettle.so.6.4 libnettle.so)
make[1]: Verzeichnis „/home/freetz/7940_trunk_7.0x/freetz-dhu/freetz/source/target-mips_gcc-5.5.0_uClibc-1.0.14-nptl_kernel-3.10/nettle-3.4“ wird verlassen
sed -i -r -e "s,^(libdir=)(['"'"'"]?)([^'"'"'"]*)(\2)$,\1\2/home/freetz/7940_trunk_7.0x/freetz-dhu/freetz/toolchain/build/mips_gcc-5.5.0_uClibc-1.0.14-nptl_kernel-3.10/mips-linux-uclibc\3\4,g" -e "s,^(includedir=)(['"'"'"]?)([^'"'"'"]*)(\2)$,\1\2/home/freetz/7940_trunk_7.0x/freetz-dhu/freetz/toolchain/build/mips_gcc-5.5.0_uClibc-1.0.14-nptl_kernel-3.10/mips-linux-uclibc\3\4,g" -e "s,^(prefix=)(['"'"'"]?)([^'"'"'"]*)(\2)$,\1\2/home/freetz/7940_trunk _7.0x/freetz-dhu/freetz/toolchain/build/mips_gcc-5.5.0_uClibc-1.0.14-nptl_kernel-3.10/mips-linux-uclibc\3\4,g" -e   "s,^(exec_prefix=)(['"'"'"]?)([^'"'"'"]*)(\2)$,\1\2/home/freetz/7940_trunk_7.0x/freetz-dhu/freetz/toolchain/build/mips_gcc-5.5.0_uClibc-1.0.14-nptl_kernel-3.10/mips-linux-uclibc\3\4,g" -e "/^dependency_libs/s,[ \t],  ,g;s,([              '])((/usr)?/lib/[^ /]+[.]la)([ ']),\1/home/freetz/7940_trunk_7.0x/freetz-dhu/freetz/toolchain/build/mips_gcc-5.5.0_uClibc-1.0.14-nptl_kernel-3.10/mips-linux-uclibc\2\4,g;s, +, ,g" \
 /home/freetz/7940_trunk_7.0x/freetz-dhu/freetz/toolchain/build/mips_gcc-5.5.0_uClibc-1.0.14-nptl_kernel-3.10/mips-linux-uclibc/usr/lib/pkgconfig/nettle.pc /home/freetz/7940_trunk_7.0x/freetz-dhu/freetz/toolchain/build/mips_gcc-5.5.0_uClibc-1.0.14-nptl_kernel-3.10/mips-linux-uclibc/usr/lib/pkgconfig/hogweed.pc
sed: /home/freetz/7940_trunk_7.0x/freetz-dhu/freetz/toolchain/build/mips_gcc-5.5.0_uClibc-1.0.14-nptl_kernel-3.10/mips-linux-uclibc/usr/lib/pkgconfig/hogweed.pc kann nicht gelesen werden: Datei oder Verzeichnis nicht gefunden
make/libs/nettle/nettle.mk:30: recipe for target '/home/freetz/7940_trunk_7.0x/freetz-dhu/freetz/toolchain/build/mips_gcc-5.5.0_uClibc-1.0.14-nptl_kernel-3.10/mips-linux-uclibc/usr/lib/libnettle.so.6.4' failed
make: *** [/home/freetz/7940_trunk_7.0x/freetz-dhu/freetz/toolchain/build/mips_gcc-5.5.0_uClibc-1.0.14-nptl_kernel-3.10/mips-linux-uclibc/usr/lib/libnettle.so.6.4] Error 2
Fehler kommt seit den letzten Änderungen (Changeset's) ??
Meine Box: 7490, Auswahl für Make FW7.01 (anbei auch meine .config)
Danke im Voraus für eure Hilfe!
Gruß axleu
holh-66
