How i disable multihomed address 192.168.178.254 on my FBF LAN Client?
alfonzo
6 Feb 2011
Hello,
How i disable multihomed address 192.168.178.254 on my FBF LAN 5050 Client? I have allocated some address (LAN Client DHCP, for example 192.168.178.88) but always is mirrored on 192.168.178.254 and i not want this, is any WAY?
thx
Scanning 192.168.178.254 [1000 ports]
Discovered open port 8080/tcp on 192.168.178.254
Discovered open port 80/tcp on 192.168.178.254
Discovered open port 23/tcp on 192.168.178.254
Discovered open port 1234/tcp on 192.168.178.254
Discovered open port 5060/tcp on 192.168.178.254
nobody know?
Hello
I see telnet is running.
Try ifconfig without paramter to see which device is bind to this IP.
Than use ifconfig devicename down (lan:0 lan:1 or whatever)
Example for rescue IP:
ifconfig lan:0 down
But keep in mind lan:0 appears back if multid is restarting or after a reboot.
Sorry for my bad english
webstermalcom51
