How to set up fritz box 7050 own call ID ?
voipuser.int
5 Dez 2006
I am using an 'Officially the lowratevoip.com Certified' AVM FRITZ!Box 7050
What are the correct settings to use the new custom callerid feature with FRITZ!Box 7050 ?
I tried cutting and pasting the verified telephone number from the owratevoip.com software client to the 'Internet number' field in the FRITZ!Box.
The callerid looks like: 00447756xxxxxx
Did anybody get it working?
Thanks
Idrees
UK
Thank you for reply. See attached screenshot. This was my configuration from the beginning, but still my number is not shown on the telephon i call.
int. format 00447759253265.
My german box fb 7050 Aneex A
Internetrufnummer 00447759253265
Anmeldedaten, die Ihnen Ihr Internettelefonie-Anbieter mitgeteilt hat:
Benutzername: desivoip
Kennwort : xxx
Kennwortbestätigung : xxxx
Registrar: sip.lowratevoip.com
Proxy-Server : sip.lowratevoip.com
Internetrufnummer für die Anmeldung verwenden
NOT WORKING ANY IDE
THANKS
I guess "Internetrufnummer für die Anmeldung verwenden" is activated?
If it is activated and it still doesn't work you probably forgot to enable "custom CallerID" in the lowratevoip-application. You have to verify your number and select that number in that application (Options - CallerID).
Thanks
U give info (Options - CallerID).
my number in 0044xxx format and now it works fine. Thank you
(because Deutsch language is very hard for me to understand).
How to change language of the software to English of FB 7050 website All Menu
Thanks
You don't need the first file. That's why I said the tutorial at the bottom of the page would be easier (the "Alternative approach"). It's more up to date.
For the 7050 you need another recovery tool.
The tutorial adapated for the 7050:
- download a GUI recovery tool with image bundled: ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7050/x_misc/english/annex a
- enable telnet by dialing #96*7* a phone connected to "Fon 2"
- your network cable should be connected to "LAN A" port now
- establish a telnet connection (factory default IP of the FBF is 192.168.178.254): telnet 192.168.178.254 ("start" - "run" in Windows)
- type in the following command:
echo firmware_version avme > /proc/avalanche/env
- run the program downloaded in the first step
- follow the instructions provided by the program
It often takes several tries before the program connects to the box.
Before you start:
Which Firmware-Version is on your Box?
Be aware that you can kill your box if something goes wrong!
Do you have a Firmware-File for your box with German Annex A-Firmware? There is none on AVM's FTP-Server, but it could be helpful IF something goes wrong.
Thanks for reply back
Which Firmware-Version is on your Box? german Firmware
FRITZ!Box Fon WLAN 7050, Firmware-Version 14.04.15
I have modfir from FB7050 Aneex B to FB7050 Aneex a..
Fb 7050 ip adress is 192.168.178.1
pc ip adress is 192.168.178.20
I ned to have change ip adess of pc to 192.168.178.10 ?
Thanks
Idees
Ah, okay.
Could be better (Any IP between 192.168.178.1 and 192.168.178.20 will do).
Here is a german FAQ for the recovery tool:
http://www.avm.de/de/Service/FAQs/FAQ_Sammlung/12798.php3
In short form:
- Connect PC to LAN A of the box. Deactivate all other connections.
- Give your PC IP-Adress 192.168.178.2 and subnet mask 255.255.255.0. (gateways 192.168.178.1); activate Netbios over TCP/IP and LMHOSTS-query in the WINS options.
- stop firewalls and other protection programs
- start the recovery tool and follow the instructions
If errors occur:
- be sure all other network connections are disabled; switch the network adapter connected to the box to 10 MBit/s half duplex
- start again
Hi
I have not change any thing frtiz box ..
only i have do press *96*7* and *96*8*
I can not get acc to fb box ip adress
http://192.168.178.1
http://192.168.179.1
http://192.168.178.254
http://fritz.box
http://fritz.fonata.box
The page cannot be found
The page you are looking for might have been removed, had its name changed, or is temporarily unavailable.
Please try the following:
If you typed the page address in the Address bar, make sure that it is spelled correctly.
Open the 192.168.178.1 home page, and then look for links to the information you want.
Click the Back button to try another link.
Click Search to look for information on the Internet.
HTTP 404 - File not found
Internet Explorer
I CAN PING THE IP ADRESS
Hmm, strange.
Did you try to restart the box (pull the power plug and plug it in again after a few seconds).
If that doesn't help, try to reset the box to factory defaults by dialing #991*15901590* on a phone that is connected to the box.
Tanks sir
Have do 10 Time
Yes I have do the .. An box is now reset . still same problem can not ping the fb 7050 box
C:\>ping 192.168.178.1
Pinging 192.168.178.1 with 32 bytes of data:
Destination host unreachable.
Ping statistics for 192.168.178.1:
Packets: Sent = 4, Received = 0, Lost = 4 (100%
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\>ipconfig/all
Windows 2000 IP Configuration
Host Name . . . . . . . . . . . . : e8q5i1
Primary DNS Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Broadcast
IP Routing Enabled. . . . . . . . : Yes
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 5:
Media State . . . . . . . . . . . : Cable Disconnected
Description . . . . . . . . . . . : AVM FRITZ!Box Fon WLA
Physical Address. . . . . . . . . : 00-04-0E-69-80-69
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : SiS 900 PCI Fast Ethe
Physical Address. . . . . . . . . : 00-0A-E6-81-FD-1E
I am useing USB Connetion
Hello sir
Did you try using the LAN connection? You need it anyway for the recovery tool.
Yes i have do the . i get other ip adress .
When i makre pinge
RUN > CMD> DOQ 169.254.160.107
bUT NOT ACC TO FRITZ BOX
ANY OTHER OPTION ..
For the USB connection it might help to update (or renew) the driver:
ftp://ftp.avm.de/fritz.box/usb/ ?
THIS FORUM HAVE 4 FILE. WHICE FILE I NED TO HAVE
THANKS
PatrickSt91
