Integrate New language in Fritz firmware
skizzo3000
14 Jul 2006
Hi, i'm an italian Boy, I translated the german firmware in italian and now i would to put the new page htm in the fritz box 7050.
I tried with bftp to write in folder /usr/www but failed because the filesystem is Read-only !
Can I integrate my htm files in the firmware with DS_MOD ?
Repeat: I translated the original german htm files in italian and i would to up them in the firmware.
If i put these files in ./root/usr/www in cygwin as same as descript in the HOWTO_integrate_own_files.txt, the ds_mod overwrite the original with my version?
Sorry for my bad english.
Thanks to all Users !!
Skizzo3000
It should work the way you described. But the language specific part is not in the htm-files. It is in the .inc files.
Greets, Oliver
I translated the inc files, putted them in ./root/usr/www with its path, i made menu with no packages, made the firmware with NO ERRORS.
But when i put it on fritz 7050 it says that "Das Firmware-Update ist fehlgeschlagen: Die angegebene Datei enthält keine für Ihr Gerät gültige Firmware "
what can i do now ?
Thanks
Skizzo3000
What Firmware do you use? german/international?
What Boxtype do you have? OEM (avm/avme/...)?
Greets, Oliver
Can you verify that you did not remove the OEM in "make menuconifg".
Or you have to change firmware_version from 1und1 to avm.
Greets, Oliver
holh-66
