Interfaces
equinox
24 Okt 2005
ich hab derzeit ein kleines Verständnisproblem zu den Interfaces meiner FB Fon WLAN.
# ifconfig
dsl       Link encap:Point-Point Protocol
          inet addr:192.168.179.1  P-t-P:192.168.179.1  Mask:255.255.255.255
          UP POINTOPOINT RUNNING NOARP ALLMULTI MULTICAST  MTU:1500  Metric:1
          RX packets:41624 errors:0 dropped:0 overruns:0 frame:0
          TX packets:24455 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:100
          RX bytes:54956288 (52.4 MiB)  TX bytes:2060609 (1.9 MiB)
eth0      Link encap:Ethernet  HWaddr 00:04:0E:5D:C4:C2
          UP BROADCAST RUNNING PROMISC MULTICAST  MTU:1500  Metric:1
          RX packets:43767 errors:0 dropped:0 overruns:0 frame:0
          TX packets:24471 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:55883644 (53.2 MiB)  TX bytes:2405091 (2.2 MiB)
eth0:1    Link encap:Ethernet  HWaddr 00:04:0E:5D:C4:C2
          inet addr:192.168.178.253  Bcast:192.168.178.255  Mask:255.255.255.0
eth1      Link encap:Ethernet  HWaddr 00:04:0E:5D:C4:C3
          UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:1500  Metric:1
          RX packets:25407 errors:0 dropped:0 overruns:0 frame:0
          TX packets:41223 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:2421844 (2.3 MiB)  TX bytes:52296930 (49.8 MiB)
          Base address:0x2800
lan       Link encap:Ethernet  HWaddr 00:04:0E:5D:C4:C2
          inet addr:192.168.170.1  Bcast:192.168.170.255  Mask:255.255.255.0
          TX packets:41228 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:2066146 (1.9 MiB)  TX bytes:52297708 (49.8 MiB)
lan:0     Link encap:Ethernet  HWaddr 00:04:0E:5D:C4:C2
          inet addr:192.168.178.254  Bcast:192.168.178.255  Mask:255.255.255.0
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:437 errors:0 dropped:0 overruns:0 frame:0
          TX packets:437 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:42895 (41.8 KiB)  TX bytes:42895 (41.8 KiB)
tiwlan0   Link encap:Ethernet  HWaddr 00:04:0E:5D:C4:C4
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:223 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:66017 (64.4 KiB)
usbrndis  Link encap:Ethernet  HWaddr 00:04:0E:5D:C4:C6
          UP BROADCAST ALLMULTI MULTICAST  MTU:1500  Metric:1
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wdsdw0    Link encap:Ethernet  HWaddr 00:04:0E:5D:C4:C4
wdsdw1    Link encap:Ethernet  HWaddr 00:04:0E:5D:C4:C4
wdsdw2    Link encap:Ethernet  HWaddr 00:04:0E:5D:C4:C4
wdsdw3    Link encap:Ethernet  HWaddr 00:04:0E:5D:C4:C4
wdsup0    Link encap:Ethernet  HWaddr 00:04:0E:5D:C4:C4
zu allererst, die FB läuft als NAT-Router im eigenen Subnetz (192.168.170.*) und hat die externe IP 192.168.0.175 (sagt mir zumindest der dhcp-server, sofern die fritzbox "datapipe" heisst (warum? oO).
zurück zu obiger liste: kann mir jemand sagen welcher dieser interfaces der lan a port ist bzw. warum die ip aus dem anderen netz, die die FB haben muss dort nicht auftaucht.
ausserdem:
# ifconfig | grep 00:04:0E:5D:C4:C2
warum haben die die selbe mac-adressen? (man beachte die verschiedenen ip-adressen)..
danke für die aufklärung :)
nachtrag:
da ich vermute, dass die nachfolgenden verwirrspielchen aus dem syslog irgendwie kaputt sind. ich dachte mir ich pack das mal hier dazu, wo wir grade schon in meinem ip-netz spazieren gehen..
Sep  8 01:49:56 voipd[426]: is_register_allowed - running (voip=0)
Sep  8 01:49:56 voipd[426]: 0: connected    vcc 0/0/RBE/14 stay online 1
Sep  8 01:49:56 voipd[426]: 0: ip 192.168.0.175/192.168.0.1 mtu 1500 dns 82.212.63.2/192.168.0.1
Sep  8 01:49:56 voipd[426]: STUN: udp 5060 -> 91.89.6.120:59869
Sep  8 01:49:56 voipd[426]: [email protected]: REGISTER starting
Sep  8 01:49:56 voipd[426]: >>>UDP Request: REGISTER sip:sipgate.de
Sep  8 01:49:56 voipd[426]: <<<UDP Status: 401 Unauthorized
Sep  8 01:49:56 voipd[426]: query_local_ipaddress - running (voip=0)
Sep  8 01:49:56 voipd[426]: query_local_ipaddress: 192.168.0.175
Sep  8 01:49:56 voipd[426]: ip address changed 91.89.6.120 -> 192.168.0.175
Sep  8 01:49:56 voipd[426]: 5604640: my address 192.168.0.175
Sep  8 01:49:56 voipd[426]: <<<UDP Status: 200 OK
Sep  8 01:49:56 voipd[426]: ip address changed 192.168.0.175:59869 -> 91.89.6.120:59869
Sep  8 01:49:56 voipd[426]: 5604640: my address 91.89.6.120:59869
Sep  8 01:49:56 voipd[426]: [email protected]: REGISTER end
Sep  8 01:49:56 voipd[426]: [email protected]: REGISTER (sip:[email protected]:59869;uniq=B947FA29EBCE0D5807ED6C9E1234B) complete (next in 1620 seconds)
Sep  8 01:49:56 voipd[426]: >>>UDP Request: SUBSCRIBE sip:[email protected]
Sep  8 01:49:56 voipd[426]: <<<UDP Status: 407 Proxy Authentication Required
Sep  8 01:49:56 voipd[426]: <<<UDP Status: 404 Not found
was läuft da schief?
Die Fritz hat die IP die bei lan steht. (192.168.170.1)
equinox schrieb:
ausserdem:
warum haben die die selbe mac-adressen? (man beachte die verschiedenen ip-adressen)...
Weil das alles der selbe Lanport ist.
Keine Ahnung warum die FritzBox in diesem Modus datapipe heißt, aber das soll wohl so sein.
/sbin # cat dsld |grep datapipe
dh_datapipe
dh_datapipetrace
datapipe
datapipetrace
datapipe
datapipetrace
/sbin #
MfG Oliver
shreddler
