[Frage] Looking for input on Fritz!Box capture interfaces
jeroenp
24 Jun 2017
(Sorry for doing this in English; I can read and speak German fine, but getting the writing bearable for readers is well...; feel free to answer in German though)
Now that I've done some `fritzcap` maintenance,
I'm looking for more information in the interfaces that can be captured on a Fritz!Box.
As a start, I've put some documentation at https://github.com/jpluimers/fritzcap/blob/feature/More_documentation/fritzcap-interfaces-table.md that is also below (hopefully copy/paste on the forum works fine).
I'm looking for input to complete these tables. That way it's easier for `fritzcap` users to know what interfaces can be captured and what the captures will contain.
You can either answer here, or create an issue on the github repository https://github.com/jpluimers/fritzcap/issues
Note: if the tables below look like garbage: it's the forum software messing up. Before posting the "Vorschoau" looked perfectly fine after pasting the tables from https://github.com/jpluimers/fritzcap/blob/feature/More_documentation/fritzcap-interfaces-table.md
Observed interfaces on various Fritz!Box models and configurations
The below table has keys, descriptions and Fritz!Box configurations I've observed them on.
This makes it easier to estimate what interface you want to specify with --cap_interface.
The table has been assembled by observing various --show_interfaces outputs.
[TABLE="width: 888"]
[TR]
[TH]Key[/TH]
[TH]English[/TH]
[TH]Deutsch[/TH]
[TH="align: center"]7360 124[/TH]
[TH="align: center"]7490 124[/TH]
[TH="align: center"]7490 171[/TH]
[TH="align: center"]7490 178[/TH]
[/TR]
[TR]
[TD]1-ath0[/TD]
[TD]ath0[/TD]
[TD]ath0[/TD]
[TD="align: center"]X[/TD]
[/TR]
[TR="bgcolor: #F6F8FA"]
[TD]1-ath1[/TD]
[TD]ath1[/TD]
[TD]ath1[/TD]
[TD="align: center"][/TD]
[/TR]
[TR]
[TD]1-eth0[/TD]
[TD]eth0[/TD]
[TD]eth0[/TD]
[/TR]
[TD]1-eth1[/TD]
[TD]eth1[/TD]
[TD]eth1[/TD]
[/TR]
[TR]
[TD]1-eth2[/TD]
[TD]eth2[/TD]
[TD]eth2[/TD]
[/TR]
[TD]1-eth3[/TD]
[TD]eth3[/TD]
[TD]eth3[/TD]
[/TR]
[TR]
[TD]1-guest[/TD]
[TD]guest[/TD]
[TD]guest[/TD]
[/TR]
[TD]1-guest4[/TD]
[TD]guest4[/TD]
[TD]guest4[/TD]
[/TR]
[TR]
[TD]1-guest5[/TD]
[TD]guest5[/TD]
[TD]guest5[/TD]
[/TR]
[TD]1-guest_ct1[/TD]
[TD]guest_ct1[/TD]
[TD]guest_ct1[/TD]
[/TR]
[TR]
[TD]1-guest_st1[/TD]
[TD]guest_st1[/TD]
[TD]guest_st1[/TD]
[/TR]
[TD]1-lan[/TD]
[TD]lan[/TD]
[TD]lan[/TD]
[/TR]
[TR]
[TD]1-ptm_vr9[/TD]
[TD]ptm_vr9[/TD]
[TD]ptm_vr9[/TD]
[/TR]
[TD]1-tunl0[/TD]
[TD]tunl0[/TD]
[TD]tunl0[/TD]
[/TR]
[TR]
[TD]1-wasp[/TD]
[TD]wasp[/TD]
[TD]wasp[/TD]
[/TR]
[TD]1-wifi0[/TD]
[TD]wifi0[/TD]
[TD]wifi0[/TD]
[/TR]
[TR]
[TD]1-wifi1[/TD]
[TD]wifi1[/TD]
[TD]wifi1[/TD]
[/TR]
[TD]1-wlan[/TD]
[TD]wlan[/TD]
[TD]wlan[/TD]
[/TR]
[TR]
[TD]1-wlan_guest[/TD]
[TD]wlan_guest[/TD]
[TD]wlan_guest[/TD]
[/TR]
[TD]2-1[/TD]
[TD]1. Internet connection[/TD]
[TD]1. Internetverbindung[/TD]
[/TR]
[TR]
[TD]3-0[/TD]
[TD]Routing interface[/TD]
[TD]Routing-Schnittstelle[/TD]
[/TR]
[TD]3-17[/TD]
[TD]Interface 0 ('internet')[/TD]
[TD]Schnittstelle 0 ('internet')[/TD]
[/TR]
[TR]
[TD]3-18[/TD]
[TD]Interface 1 ('iptv')[/TD]
[TD]Schnittstelle 1 ('iptv')[/TD]
[/TR]
[TD]4-128[/TD]
[TD]WLAN Management Traffic - Interface 0[/TD]
[TD]WLAN Management Traffic - Schnittstelle 0[/TD]
[/TR]
[TR]
[TD]4-129[/TD]
[TD]HW (2.4 GHz, wifi0) - Interface 0[/TD]
[TD]HW (2.4 GHz, wifi0) - Schnittstelle 0[/TD]
[/TR]
[TD]4-131[/TD]
[TD]AP (2.4 GHz, ath0) - Interface 0[/TD]
[TD]AP (2.4 GHz, ath0) - Schnittstelle 0[/TD]
[/TR]
[TR]
[TD]4-132[/TD]
[TD]AP (2.4 GHz, ath0) - Interface 1[/TD]
[TD]AP (2.4 GHz, ath0) - Schnittstelle 1[/TD]
[/TR]
[TD]4-137[/TD]
[TD]AP2 (2.4 + 5 GHz, ath1) - Interface 0[/TD]
[TD]AP2 (2.4 + 5 GHz, ath1) - Schnittstelle 0[/TD]
[/TR]
[TR]
[TD]4-138[/TD]
[TD]AP2 (2.4 + 5 GHz, ath1) - Interface 1[/TD]
[TD]AP2 (2.4 + 5 GHz, ath1) - Schnittstelle 1[/TD]
[/TR]
[TD]4-141[/TD]
[TD]Guest (2.4 GHz, guest4) - Interface 0[/TD]
[TD]Guest (2.4 GHz, guest4) - Schnittstelle 0[/TD]
[/TR]
[TR]
[TD]4-142[/TD]
[TD]Guest (2.4 GHz, guest4) - Interface 1[/TD]
[TD]Guest (2.4 GHz, guest4) - Schnittstelle 1[/TD]
[/TR]
[TD]4-143[/TD]
[TD]Guest2 (2.4 + 5 GHz, guest5) - Interface 0[/TD]
[TD]Guest2 (2.4 + 5 GHz, guest5) - Schnittstelle 0[/TD]
[/TR]
[TR]
[TD]4-144[/TD]
[TD]Guest2 (2.4 + 5 GHz, guest5) - Interface 1[/TD]
[TD]Guest2 (2.4 + 5 GHz, guest5) - Schnittstelle 1[/TD]
[/TR]
[TD]5-161[/TD]
[TD]usb1[/TD]
[TD]usb1[/TD]
[/TR]
[TR]
[TD]5-162[/TD]
[TD]usb2[/TD]
[TD]usb2[/TD]
[/TR]
[/TABLE]
Observed devices
[TR]
[TH]Key[/TH]
[TH]Description[/TH]
[/TR]
[TR]
[TD]7360 124[/TD]
[TD]Fritz!Box 7360 manually setup: switch on LAN als doing VoIP[/TD]
[/TR]
[TD]7490 124[/TD]
[TD]Fritz!Box 7490 manually setup: router on fiber network[/TD]
[/TR]
[TR]
[TD]7490 171[/TD]
[TD]Fritz!Box 7490 manually setup: router on fiber network also doing VoIP[/TD]
[/TR]
[TD]7490 178[/TD]
[TD]Fritz!Box 7490 xs4all default configuration: router on fiber network also doing VoIP[/TD]
[/TR]
[/TABLE]
Notes/explanation on some of these interfaces I've found or deducted. ??? or empty means I still need more information.
[TR]
[TH]Key[/TH]
[TH]Explanation[/TH]
[TH]Notes[/TH]
[/TR]
[TR]
[TD]1-ath0[/TD]
[TD]WLAN0: First physical Atheros WLAN controller[/TD]
[TD][/TD]
[/TR]
[TD]1-ath1[/TD]
[TD]WLAN1: Second physical Atheros WLAN controller[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]1-eth0[/TD]
[TD]LAN1: First physical Ethernet controller[/TD]
[TD][/TD]
[/TR]
[TD]1-eth1[/TD]
[TD]LAN2: First physical Ethernet controller[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]1-eth2[/TD]
[TD]LAN3: Third physical Ethernet controller[/TD]
[TD][/TD]
[/TR]
[TD]1-eth3[/TD]
[TD]LAN4: Fourth physical Ethernet controller[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]1-guest[/TD]
[TD]??? LAN bridge for guest access[/TD]
[TD][/TD]
[/TR]
[TD]1-guest4[/TD]
[TD]???[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]1-guest5[/TD]
[TD]???[/TD]
[TD][/TD]
[/TR]
[TD]l2tp client tunnel[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]l2tp LAN2LAN server tunnel[/TD]
[TD][/TD]
[/TR]
[TD]1-lan[/TD]
[TD]LAN bridge for regular access[/TD]
[TD]all LAN traffic[/TD]
[/TR]
[TR]
[TD]1-ptm_vr9[/TD]
[TD]PPPoE connection[/TD]
[TD][/TD]
[/TR]
[TD]1-tunl0[/TD]
[TD]???[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]1-wasp[/TD]
[TD]???[/TD]
[TD][/TD]
[/TR]
[TD]1-wifi0[/TD]
[TD]???[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]1-wifi1[/TD]
[TD]???[/TD]
[TD][/TD]
[/TR]
[TD]1-wlan[/TD]
[TD]WLAN bridge for regular access[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]WLAN bridge for guest access[/TD]
[TD][/TD]
[/TR]
[TD]2-1[/TD]
[TD]Only when configured as router[/TD]
[TD]on Fritz!Box 7360 in switch mode it never seems to show traffic[/TD]
[/TR]
[TR]
[TD]3-0[/TD]
[TD]??? Routing interface[/TD]
[TD][/TD]
[/TR]
[TD]3-17[/TD]
[TD]??? Interface 0 ('internet')[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]3-18[/TD]
[TD]??? Interface 1 ('iptv')[/TD]
[TD][/TD]
[/TR]
[TD]4-128[/TD]
[TD]??? WLAN Management Traffic - Interface 0[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]4-129[/TD]
[TD]??? HW (2.4 GHz, wifi0) - Interface 0[/TD]
[TD][/TD]
[/TR]
[TD]4-131[/TD]
[TD]??? AP (2.4 GHz, ath0) - Interface 0[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]4-132[/TD]
[TD]??? AP (2.4 GHz, ath0) - Interface 1[/TD]
[TD][/TD]
[/TR]
[TD]4-137[/TD]
[TD]??? AP2 (2.4 + 5 GHz, ath1) - Interface 0[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]4-138[/TD]
[TD]??? AP2 (2.4 + 5 GHz, ath1) - Interface 1[/TD]
[TD][/TD]
[/TR]
[TD]4-141[/TD]
[TD]??? Guest (2.4 GHz, guest4) - Interface 0[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]4-142[/TD]
[TD]??? Guest (2.4 GHz, guest4) - Interface 1[/TD]
[TD][/TD]
[/TR]
[TD]4-143[/TD]
[TD]??? Guest2 (2.4 + 5 GHz, guest5) - Interface 0[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]4-144[/TD]
[TD]??? Guest2 (2.4 + 5 GHz, guest5) - Interface 1[/TD]
[TD][/TD]
[/TR]
[TD]5-161[/TD]
[TD]??? usb1[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]5-162[/TD]
[TD]??? usb2[/TD]
[/TR]
[/TABLE]
pinguin2001
