mISDN - Asterisk hängt sich beim starten auf
RcRaCk2k
4 Aug 2005
Schönen guten Abend liebe Community.
Ich verwende asterisk-1.2.0-beta1 mit mISDN_for_PBX4Linux-2.5-fix6.tar.gz und mISDNuser_for_PBX4Linux-2.7-fix1.tar.gz sowie chan_misdn-0.1.1.
Folgende Module sind geladen:
Module                  Size  Used by
mISDN_l2               44704  -
mISDN_l1               10600  -
mISDN_dsp             194336  -
hfcpci                 29068  -
mISDN_core             77516  -
Meine CCD/Billion/Asuscom card name: 2BD0 Karte wurde laut LOG-File richtig geladen. Hier ein kleiner Ausschnitt:
Oct  5 18:32:09 storage Modular ISDN Stack core $Revision: 1.23 $
Oct  5 18:32:09 storage mISDNd: kernel daemon started
Oct  5 18:32:09 storage HFC card f1e5d040 dch f1e5d0d0 bch1 f1e5d258 bch2 f1e5d3ec
Oct  5 18:32:09 storage mISDN: HFC-PCI driver Rev. 1.38
Oct  5 18:32:09 storage ACPI: PCI Interrupt 0000:01:06.0[A] -> Link [APC3] -> GSI 18 (level, low) -> IRQ 18
Oct  5 18:32:09 storage mISDN: HFC-PCI card manufacturer: CCD/Billion/Asuscom card name: 2BD0
Oct  5 18:32:09 storage HFC-PCI: defined at mem 0xf8adc000 fifo 0xf40e8000(0x340e8000) IRQ 18 HZ 250
Oct  5 18:32:09 storage spin_lock_adr=f1e5d0ac now(f8aeaf09)
Oct  5 18:32:09 storage busy_lock_adr=f1e5d0b0 now(f8aeaf09)
Oct  5 18:32:09 storage reset_hfcpci: entered
Oct  5 18:32:09 storage HFC_PCI: resetting HFC ChipId(30)
Oct  5 18:32:09 storage HFC-PCI status(4) before reset
Oct  5 18:32:09 storage mISDNd: test event done
Oct  5 18:32:09 storage HFC-PCI status(2) after reset
Oct  5 18:32:09 storage HFC-PCI status(4) after 5us
Oct  5 18:32:09 storage init_card: entered
Oct  5 18:32:09 storage inithfcpci: entered
Oct  5 18:32:09 storage HFC PCI: IRQ 18 count 1
Oct  5 18:32:09 storage HFC card f1c79840 dch f1c798d0 bch1 f1c79a58 bch2 f1c79bec
Oct  5 18:32:09 storage HFC-PCI: No more PCI cards found
Oct  5 18:32:09 storage HFC 1 cards installed
Oct  5 18:32:23 storage mISDN_dsp: Audio DSP  Rev. 1.10 (debug=0x0)
Oct  5 18:32:26 storage ISDN L1 driver version 1.11
Oct  5 18:32:27 storage ISDN L2 driver version 1.19
Und wenn ich jetzt Asterisk versuche zu Starten, dann sieht das ganze folgendermaßen aus:
[res_monitor.so] => (Call Monitoring Resource)
  == Registered application 'Monitor'
  == Registered application 'StopMonitor'
  == Registered application 'ChangeMonitor'
  == Manager registered action Monitor
  == Manager registered action StopMonitor
  == Manager registered action ChangeMonitor
 [skipping chan_modem_i4l.so]
 [chan_mgcp.so] => (Media Gateway Control Protocol (MGCP))
  == Parsing '/etc/asterisk/mgcp.conf': Found
  == MGCP Listening on 0.0.0.0:2727
  == Using TOS bits 0
  == Registered channel type 'MGCP' (Media Gateway Control Protocol (MGCP))
 [skipping chan_zap.so]
 [chan_misdn.so] => (Channel driver for mISDN Support (Bri/Pri))
Er bleibt einfach beim chan_misdn.so stehen, und der Asterisk-Process belegt 100% der CPU-Usage. Nix geht mehr weiter. Killen per kill -SIGKILL [pid] nutzt nix, ein System-Restart ist notwendig.
Ich benötige den HFC-Treiber für PCI um meine Karte im NT Modus betreiben zu können.
Vielleicht weiß jemand wie man das Problem beheben kann.
Vielen Dank im Voraus.
Freundliche Grüße aus Freilassing.
Michael Rack
gäsbock
