[HowTo] O2 DSL modem P-2602HWN-d7A [Annex-B --> Annex-A] ?
Zaheer
9 Dez 2010
Hi folks, I have searched this forum and google for the tips about converting the mentioned modem from Annex-B to Annex-A but no success. Any idea? Are there any telnet command to change related firmware configuration?
P.S. I hope this is the right sub forum for this question although there exist ZyXEL forums. :)
Welcome in our Forum!
I see no chance to modify the settings permanent to Annex-A. Especially the O2-OEM modell makes it difficult.
Thanks. Interestingly you used the word 'permanent'. So is there a way to temporary change the settings?
right, with some tricks it´s maybe possible to change settings. Due to OEM-firmware a restart change back this settings. I cannot guarantee success for your wished configuration. I recommend - don´t re-use such a router in other environements. The O2-firmware must not contain every feature from Zyxel!
Lutzel
