Old avm firmvare for 7490
nabla79
22 Jan 2018
Hi All,
I have unsuccessfully tried to compile freetz for 7490, with version 6.30 of the avm image, in order to include iptables support.
The compilation aborted at the beginning because of the following needed avm image:
FRITZ.Box_7490.en-de-it-it-for-pl.113.06.31.image
is no longer available.
Could someone share that image version, in case he has it?
Thanks
There a specialized thread to satisfy such "firmware search requests" - but you should (nevertheless) think and challenge your decision (or intention) again.
These old versions aren't usable on an edge-router in a secure manner ... the whole "WAN-side" of the device is encapsulated in a proprietary component called 'dsld' (with a kernel module 'kdsldmod.ko') and if you continue to use such an old version, your router will be exposed to (widely unknown) security threats, which were fixed meanwhile in newer versions.
If you do not intend to use the firmware on an edge-router in a network, you seldom need 'iptables' really to mock-up anything already present in AVM's WAN stack.
Reaktionen: nabla79
holh-66
