openvpn stays with default configuration
graymalking
4 Feb 2008
model 7270 v2 fw international freetz devel
I've used for a week openvpn with tap configuration, yesterday I tried to use a tun configuration. Finally when I changed the configuration to return on tap setting and I saved it the gui shows again the default tun configuration.
I've done telephon resect, two recoveries, used the German fw but I'm non able to chance the openvpn configuration (each time when I save return to the default configuration).
Any Ideas ?
Please try the latest Patch from Ticket 1129 and report if it is working for you. Probably a known error (but not yet fixed in SVN).
freetz trunk 54.04.88 freetz-devel-6615M
I chance
"document.getElementById('div_add_tap').style.display=(this.checked)? 'block' : 'none';"
it works :)
Thanks a lot
An italian pizza for everybody :)
rehe992
