Samba service displayed as stop! but is running.
flemse
14 Mrz 2007
Hi
Just made a new Freetz svn 1999, all i running, but samba is displayed as stopped on the "Freetz - Services" pages. why?
The command ps:
730 root 3116 S N smbd -D -s /mod/etc/smb.conf
//Flemming
same for me on one you my two 7270.
on the other one it works well. (both have exactly the same smb.conf)
in /var/run is a smbd.pid with the right id nevertheless.
maybe a complete reset (configs etc. too) might help, but since it's no severe error, i can live with it.
Samba in svn is dead. Taka a look here
compiling samba works with:
cd source/samba-3.0.24/source
make clean
then a make in freetz dir will compile samba successfully. and with this version i have no problems (samba web-interface works too) on one box and the mentioned problem above on another.
it would be good to know how the webinterface determines if a process is running or not. clicking on "start" says it's already running, so it seems to be only a problem with the webinterface on special configs
Thanks.
Then it must be a error in the init.d script. I know i have not installed "nmbd" because i deselected it when making my "make menuconfig".
Thanks for the info.
status)
 if [ -s "/var/run/smbd.pid" ] && [ -s "/var/run/nmbd.pid" ]; then
       echo 'running'
 else
      echo 'stopped'
 fi
//Flemming
figo12
