Sipura 2000 mit freenet oder Sipgate Konfigurieren
ich habe gestern und heute mal versucht ein Syslog zu erstellen, ich hoffe dass sie aussagekräftig genug sind.
Syslog Nummer 1 :
syslog server(port:514) started on Sun Feb 20 23:42:59 2005
RSE_DEBUG: reference domain:iphone.freenet.de
[0:5060]->194.97.54.97:5060
NOTIFY sip:iphone.freenet.de SIP/2.0
Via: SIP/2.0/UDP 83.135.141.169:32771;branch=z9hG4bK-43aa503c;rport
From: Anruf <sip:[email protected]>;tag=c8a5da4b8dcea4fdo0
To: <sip:iphone.freenet.de>
Call-ID: [email protected]
CSeq: 1186 NOTIFY
Max-Forwards: 70
Event: keep-alive
User-Agent: Sipura/SPA2000-2.0.10(e)
Content-Length: 0
CSeq: 1186 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
CSeq: 1186 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
CSeq: 1186 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
CSeq: 1186 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
CSeq: 1186 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
CSeq: 1186 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
CSeq: 1186 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
[5060]STUN trying 0
[5060]STUN trying 1
[5060]STUN trying 2
[5060]STUN trying 3
CSeq: 1186 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
[5060]STUN trying 4
[5060]STUN trying 5
[5060]STUN trying 6
CSeq: 1186 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
[5060]STUN trying 7
[5060]STUN trying 8
CSeq: 1186 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
REGISTER sip:freenet.de SIP/2.0
Via: SIP/2.0/UDP 83.135.141.169:32771;branch=z9hG4bK-371d68ac;rport
To: Anruf <sip:[email protected]>
CSeq: 21 REGISTER
Max-Forwards: 70
Authorization: Digest username="magnus.kranenberg",realm="freenet.de",nonce="421905d1cbea61395ddcf4b6589ef26ef68ea95d",uri="sip:[email protected]",algorithm=MD5,response="eae4083611c734e6347c9045d3f71117",qop=auth,nc=00000002,cnonce="4ccdbcc0"
Contact: Anruf <sip:[email protected]:32771>;expires=3600
Warning: 399 spa "STUN Server Not Responding"
Content-Length: 0
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Supported: x-sipura
RSE_DEBUG: getting alternate from domain:iphone.freenet.de
RSE_DEBUG: unref domain, iphone.freenet.de
CSeq: 21 REGISTER
Max-Forwards: 70
Authorization: Digest username="magnus.kranenberg",realm="freenet.de",nonce="421905d1cbea61395ddcf4b6589ef26ef68ea95d",uri="sip:[email protected]",algorithm=MD5,response="026678e3b558e305d3f0db7d15eddff5",qop=auth,nc=00000003,cnonce="4ccdbcc0"
Content-Length: 0
Supported: x-sipura
CSeq: 21 REGISTER
Max-Forwards: 70
Content-Length: 0
Supported: x-sipura
CSeq: 21 REGISTER
Max-Forwards: 70
Content-Length: 0
Supported: x-sipura
CSeq: 21 REGISTER
Max-Forwards: 70
Content-Length: 0
Supported: x-sipura
CSeq: 21 REGISTER
Max-Forwards: 70
Content-Length: 0
Supported: x-sipura
RSE:GetServerAddrErr(iphone.freenet.de,0)=-101
TP:?Tx->0
[0:5060]->0.0.0.0:5060
Via: SIP/2.0/UDP 83.135.141.169:32771;branch=z9hG4bK-ac42a674;rport
CSeq: 1187 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
CSeq: 21 REGISTER
Max-Forwards: 70
Content-Length: 0
Supported: x-sipura
CSeq: 21 REGISTER
Max-Forwards: 70
Content-Length: 0
Supported: x-sipura
CSeq: 21 REGISTER
Max-Forwards: 70
Content-Length: 0
Supported: x-sipura
CSeq: 21 REGISTER
Max-Forwards: 70
Content-Length: 0
Supported: x-sipura
TP:?Tx->0
Via: SIP/2.0/UDP 83.135.141.169:32771;branch=z9hG4bK-72a54929;rport
CSeq: 1188 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
Syslog Nummer 2 :
syslog server(port:514) started on Mon Feb 21 21:20:42 2005
Via: SIP/2.0/UDP 83.135.144.16:33638;branch=z9hG4bK-9a2919c9;rport
CSeq: 3964 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
CSeq: 3964 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
CSeq: 3964 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
CSeq: 3964 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
CSeq: 3964 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
[0:5060]<<194.97.54.97:5060
SIP/2.0 403 Anruf nicht erlaubt
Via: SIP/2.0/UDP 83.135.144.16:33638;branch=z9hG4bK-9a2919c9;rport=33638
To: <sip:iphone.freenet.de>;tag=5f61617ce4661383c5d475661db5b4db.35ee
CSeq: 3964 NOTIFY
Content-Length: 0
[0]ExtSipPortChanged:0
Ich hoffe das die beiden Syslogs aussagekräftig genug sind!
Anmerkung von Christoph: Bitte "Code"-Funktion nutzen.
Irgendwie hat Dein Sipura keine IP-Adresse:
Statt 0:5060 sollte hier die lokale IP stehen.
Entweder Du hast DHCP ausgeschaltet, aber keine manuelle IP eingetragen, oder Du hast DHCP eingeschaltet, aber keinen DHCP Server im Netzwerk (z.B. im Router).
Darüber hinaus scheint der STUN-Server nicht zu antworten. Prüfe auch da mal, ob Du den richtigen Server eingetragen hast.
Sowohl im Router, als auch im SPA ist DHCP aktiviert. Beim IP Check im SPA wird mir als IP 192.168.0.2 angegeben und im Router die selbe IP. Ich verstehe daher nicht wo der Fehler sein soll.
Was hast Du denn als STUN-Server unten auf der Seite mit SIP-Reiter eingetragen? Wie hast Du die restlichen NAT-Support Parameters eingestellt?
Meine NAT Support Parameter sehen wie folgt aus:
NAT Support Parameters
Handle VIA received: yes Handle VIA rport:yes
Insert VIA received: yes Insert VIA rport:yes
Substitute VIA Addr: yes Send Resp To Src Port:yes
STUN Enable: yes STUN Test Enable:yes
STUN Server: iphone-stun.freenet.de EXT IP:
EXT RTP Port Min: NAT Keep Alive Intvl: 15
Ich frage mich nur, warum mein SPA sich täglich für 8 bis 14 Stunden registriert. Die Registrierung scheint ja bei meinen Einstellungen nicht grundsätzlich unmöglich zu sein!
Ich habe übrigens gerade erfahren, dass ich noch ein zweites Problem habe.
Bei einem Versuch einen Bekannten anzurufen ertönte zunächst ein Besetztzeichen. Im zweiten Versuch wurde mir dann mitgeteilt, dass man
mich beim ersten Versuch anzurufen gehört hätte, obwohl bei mir selbst
das Besetztzeichen ertönte. Vielleicht ist dieser weitere Fehler ja hilfreich,
um das Problem einzukreisen.
Ich hab im Augenblick keine Idee mehr.
Vielleicht probierst Du mal den STUN-Server von Sipgate:
stun.sipgate.net:10000
Man muss da nicht registriert sein, um den STUN-Server zu nutzen und zumindest einen Versuch, um den Fehler einzugrenzen, ist es schon wert.
wird der stunserver ausschließlich in den NAT support parameters eingetragen oder noch an anderer Stelle? Wenn ich ihn ausschließlich dort gegen den Eintrag :iphone-stun.freenet.de austausche passiert rein gar nichts,- insbesondere ist dann meine Registrierung auf failed und ich kann erst wieder raustelefonieren, wenn ich im Line-Reiter die Option <Call without registration> auf YES eingestellt habe.
Vor diesem Versuch war über die gesamte Nacht die Registrierung erfolgreich, ich konnte jedoch trotz einer erfolgreicher Registrierung nicht vom Festnetz aus angerufen werden.
Ich kann da jetzt auch nur raten, aber ich nehme an, dass Du deshalb nicht erreichbar bist, weil bei der Registrierung nicht Deine wirkliche IP-Adresse vorliegt. Daher kann beim Gesprächsaufbau das Gespräch auch gar nicht an Deine Adresse bzw. Deinen Sipura signalisiert werden.
Du könntest natürlich mit einem Syslog prüfen, ob irgendwas Besonderes passiert, wenn Du angerufen werden sollst.
Ah so: ja, der Stun-Server wird nur bei den NAT Support Parameters eingetragen. Allerdings ist mir nicht ganz klar, was Du da nun durch was ersetzt hast. Eine kurze Recherche auf der Freenet-Seite hat mir übrigens keine Klarheit gebracht, wie deren STUN-Server heißt - normal ist das nicht!
Ich habe die Auskunft, dass der Freenet Stun Server wie folgt eingetragen werden soll: iphone-stun.freenet.de
Soll ich mir das mit dem Syslog so vorstellen, dass ich kurz bevor ich mich vom Festnetz aus anrufe das Syslog starte?
Wenn Du mir verrätst, wie ich Dir ein Bildschirmcapture von meinen Einstellungen am besten zukommen lasse, würde ich mal meine Einstellungen komplett einfangen und veröffentlichen. Müssen die Bildschirmcaptures dann im JPG-Format als Attachment eingefügt werden oder wie geht das im Forum?
Ganz genau!
Das ist ein gängiger Weg. Weniger aufwendig ist es womöglich, die HTML-Seite zu speichern (da sind dann nämlich alle Reiter mit drin) und die gezipped als Attachment hier hochzuladen. Natürlich kannst Du die gespeicherte Seite noch mal überarbeiten und all zu persönliche Daten unkenntlich machen, beim JPEG müsstest Du dazu ein Grafikprogramm benutzen.
Und wie stelle ich das Syslog ein. Als Attachment geht nicht, da Log-Dateien nicht unterstützt werden. Mein letztes Syslog wurde als Code eingestellt (Anmerkung von Christoph: bitte code benutzen),- nur wie geht das?
Nütz ein neues Syslog überhaupt etwas, wenn der SPA nicht registriert ist und ankommende Gespräche überhaupt nicht eingehen. Dann kann doch auch im Syslog keine entsprechende Meldung erfolgen.
Erstens: Ausführlichere Bearbeitung der Antwort, Attachments einstellen etc. geht, wenn Du auf den Button "antwort erstellen" klickst. Dort findest Du einen Button für "Code", den Du einmal klickst bevor Du Dein Log einfügst und einmal, nachdem. Dadurch werden dann die Code-Tags in Deinem Post erzeugt.
Dateien mit nicht unterstützer Endung kann man als ZIP-Datei komprimieren und dann als Attachment anhängen.
Zweitens: Das Syslog würde Dir die Gewissheit geben, dass tatsächlich nichts am SPA ankommt, wenn Du angerufen wirst. Oder es kommen entsprechende Meldungen und dann muss man mal sehen, warum's nicht klingelt, obwohl der Anruf beim SPA registriert wird.
Fehlersuche ist manchmal mühselig. :-(
Öfter mal was NEUES! Nachdem ider SPA sich zumindest zeitweise registrierte und ich dann auch phasenweise über meine Freenetnummer angerufen werden konnte, habe ich seit heute nachmittag erneut die Meldung, dass diese Rufnummer nicht vergeben sei. Gehe ich nun zu Freenet und logge mich dort ein, dann wird meine Telefonnummer dort als registriert angezeigt. Bin mir so langsam nicht mehr sicher, ob es an meinen Einstellungen oder am Provider liegt. Auf jeden Fall ist unter dieser Meldung ein Syslog sinnlos, da freenet offensichtlich ankommende Gespräche erst gar nicht durchstellt.
Ich versuche jetzt mal meine SPA Konfiguration als Attachment einzufügen!
Okay, ich werde es heute abend mit einem anderen Programm erneut packen und einstellen.
So, nun der zweite Versuch,- Datei müsste sich jetzt öffnen lassen.
Habe übrigens wieder die Meldung, dass meine iphone-Nummer nicht vergeben ist. Die Registrierung steht erstaunlicherweise seit gestern 17:00 Uhr!
Die Einstellung auf YES lief noch schlechter als jetzt. Im Moment ist die Registreirung immer noch ok, d.h. seit immerhin 2 Tagen. Nur wenn ich angerufen werde erfolgt immer noch die Meldung: Diese Rufnummer ist nicht vergeben.
Dann weiß ich auch nicht weiter.
Wenn ich NAT Keep Alive abschalte, bin ich auch nach ca. 1 Min. von außen nicht mehr errichbar, weil die Firewall dann den Port sperrt.
Bekommt der Anrufer dann auch die Meldung: "Diese Nummer ist nicht vergeben!"
apujadas
