Sipura 2000 + sipsnip = 2 versch. Freitöne aber nichts geht?
Bevor ich das einstelle erstmal hier der Syslog.. ich glaube da stimmt was nicht...
syslog server(port:514) started on Fri Jan 14 08:44:11 2005
syslog server(port:514) started on Fri Jan 14 08:49:31 2005
System started: [email protected], reboot reason:H0
subnet mask: 255.255.255.0
gateway ip: 192.168.2.1
dns servers: 192.168.2.1
[5061]STUN trying 0
[1:5061]<<217.160.220.106:10000
TP Parser error: 14
[5061]STUN trying 1
TP Parser error: 14
[5061]STUN trying 2
TP Parser error: 14
[5061]STUN trying 3
TP Parser error: 14
IDBG: st-0
[5061]STUN trying 4
TP Parser error: 14
[5061]STUN trying 5
TP Parser error: 14
[5061]STUN trying 6
TP Parser error: 14
[5061]STUN trying 7
TP Parser error: 14
[5061]STUN trying 8
TP Parser error: 14
RSE_DEBUG: reference domain:sipsnip.com
[1:5061]->212.227.22.145:5060
REGISTER sip:sipsnip.com SIP/2.0
Via: SIP/2.0/UDP 192.168.2.197:5061;branch=z9hG4bK-564c3e08
From: Lars Schäfer <sip:[email protected]>;tag=18b9f00b30f3a1a8o1
To: Lars Schäfer <sip:[email protected]>
Call-ID: [email protected]
CSeq: 1 REGISTER
Max-Forwards: 70
Contact: Lars Schäfer <sip:[email protected]:5061>;expires=3600
User-Agent: Sipura/SPA2000-2.0.10(e)
Content-Length: 0
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Supported: x-sipura
[1:5061]<<212.227.22.145:5060
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 192.168.2.197:5061;branch=z9hG4bK-564c3e08;rport=5061;received=80.171.30.185
To: Lars Schäfer <sip:[email protected]>;tag=3eab139ab56eb1eef058d4c1d4845bab.b822
CSeq: 1 REGISTER
WWW-Authenticate: Digest realm="sipsnip.com", nonce="41e77acae3a609e5a89db5a30dc1e062e7dda28f"
Server: Sip EXpress router (0.8.14-4 (i386/linux))
Content-Length: 0
Warning: 392 server5.sipsnip.com:5060 "Noisy feedback tells: pid=12183 req_src_ip=80.171.30.185 req_src_port=5061 in_uri=sip:sipsnip.com out_uri=sip:sipsnip.com via_cnt==1"
[5061]STUN trying 0
TP Parser error: 14
[5061]STUN trying 1
TP Parser error: 14
[5061]STUN trying 2
TP Parser error: 14
[5061]STUN trying 3
TP Parser error: 14
[5061]STUN trying 4
TP Parser error: 14
[5061]STUN trying 5
TP Parser error: 14
[5061]STUN trying 6
TP Parser error: 14
RSE_DEBUG: unref domain, sipsnip.com
RSE_DEBUG: last unref for domain sipsnip.com
NOTIFY sip:sipsnip.com SIP/2.0
Via: SIP/2.0/UDP 192.168.2.197:5061;branch=z9hG4bK-1ff761b6
To: <sip:sipsnip.com>
CSeq: 1 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
SIP/2.0 404 Not found
Via: SIP/2.0/UDP 192.168.2.197:5061;branch=z9hG4bK-1ff761b6;rport=5061;received=80.171.30.185
To: <sip:sipsnip.com>;tag=3eab139ab56eb1eef058d4c1d4845bab.331d
CSeq: 1 NOTIFY
Content-Length: 0
Warning: 392 server5.sipsnip.com:5060 "Noisy feedback tells: pid=12180 req_src_ip=80.171.30.185 req_src_port=5061 in_uri=sip:sipsnip.com out_uri=sip:sipsnip.com via_cnt==1"
[5061]STUN trying 7
TP Parser error: 14
fs:09239:09250:65536
fbr:1:0000:0000:13629:0002:0003:2.0.10(e)
fhs:01:0:0001:upg:app:0:2.0.10(e)
fhs:02:0:0002:upg:app:1:2.0.10(e)
fhs:03:0:0003:upg:app:2:2.0.10(e)
[5061]STUN trying 8
TP Parser error: 14
Via: SIP/2.0/UDP 192.168.2.197:5061;branch=z9hG4bK-bc8b6b74
CSeq: 2 REGISTER
Max-Forwards: 70
Authorization: Digest username="valiant",realm="sipsnip.com",nonce="41e77acae3a609e5a89db5a30dc1e062e7dda28f",uri="sip:[email protected]",algorithm=MD5,response="b648f0324c2d74dcf0114b1f32ed07a1"
Content-Length: 0
Supported: x-sipura
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.2.197:5061;branch=z9hG4bK-bc8b6b74;rport=5061;received=80.171.30.185
To: Lars Schäfer <sip:[email protected]>;tag=3eab139ab56eb1eef058d4c1d4845bab.6ed5
CSeq: 2 REGISTER
Contact: <sip:[email protected]:5061>;q=0.00;expires=3600
Content-Length: 0
Warning: 392 server5.sipsnip.com:5060 "Noisy feedback tells: pid=12177 req_src_ip=80.171.30.185 req_src_port=5061 in_uri=sip:sipsnip.com out_uri=sip:sipsnip.com via_cnt==1"
[1]RegOK. NextReg in 3599 (1)
Via: SIP/2.0/UDP 192.168.2.197:5061;branch=z9hG4bK-6ab9c115
CSeq: 2 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
Via: SIP/2.0/UDP 192.168.2.197:5061;branch=z9hG4bK-6ab9c115;rport=5061;received=80.171.30.185
To: <sip:sipsnip.com>;tag=3eab139ab56eb1eef058d4c1d4845bab.47b8
CSeq: 2 NOTIFY
Content-Length: 0
Warning: 392 server5.sipsnip.com:5060 "Noisy feedback tells: pid=12178 req_src_ip=80.171.30.185 req_src_port=5061 in_uri=sip:sipsnip.com out_uri=sip:sipsnip.com via_cnt==1"
Via: SIP/2.0/UDP 192.168.2.197:5061;branch=z9hG4bK-aac205ca
CSeq: 3 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
Via: SIP/2.0/UDP 192.168.2.197:5061;branch=z9hG4bK-aac205ca;rport=5061;received=80.171.30.185
To: <sip:sipsnip.com>;tag=3eab139ab56eb1eef058d4c1d4845bab.86d0
CSeq: 3 NOTIFY
Content-Length: 0
Via: SIP/2.0/UDP 192.168.2.197:5061;branch=z9hG4bK-d709067e
CSeq: 4 NOTIFY
Max-Forwards: 70
Event: keep-alive
Content-Length: 0
Via: SIP/2.0/UDP 192.168.2.197:5061;branch=z9hG4bK-d709067e;rport=5061;received=80.171.30.185
To: <sip:sipsnip.com>;tag=3eab139ab56eb1eef058d4c1d4845bab.c26a
CSeq: 4 NOTIFY
Content-Length: 0
Warning: 392 server5.sipsnip.com:5060 "Noisy feedback tells: pid=12179 req_src_ip=80.171.30.185 req_src_port=5061 in_uri=sip:sipsnip.com out_uri=sip:sipsnip.com via_cnt==1"
Die vielen Meldungen wie:
kommen vom nat keepalive (setze das auf No)
ansonsten ist das Ganze nicht ungewöhnlich
Sipura/SPA2000-2.0.10(e)?
Lade dir doch bitte mal die neueste Firmware auf den spa unter: http://www.sipura.com/Documents/spa2k-2.0.11g.zip
Die Einstellungen bleiben erhalten!
Also halten wir mal den status-quo fest!
Du kannst wählen aber du hörst deinen Gesprächspartner nicht?
Dies deutet immer noch darauf hin, dass es Probleme beim port-forwarding mit den rtp-ports gibt!
Deshalb meine frage nach dem Routermodell!
nach dem log dürft es auch irgendwie mit dem STUN nicht klappen - versuch mal einen anderen STUN Server (von einem anderen Provider). Letztendlich dient ja das STUN nur dazu, das der SPA mitkriegt, unter welcher Öffentlichen IP er erreichbar ist
@Transalpler
Auszug aus dem Trace:
[5061]STUN trying 0
und hier mein ping:
C:\>ping stun.sipsnip.com
Ping stun.sipsnip.com [217.160.220.106] mit 32 Bytes Daten:
Was kann man daran erkennen?
genau - er hat den stun gefunden!
Also, ich konnte bisher nicht raustelefonieren = Freizeichen, gewählt und dann nur Rauschen bzw. 1 "Knacks" und sonst nichts.
Nach Nat keepalive auf NO und Update der FW habe ich nach dem Wählen nach paar Sekunden ein Besetztzeichen (immerhin :lol: ) aber egal wo ich anrufe.
Kannst du nochmal die screens: system, sip, line1, line2 posten
ich denke unter user1/user2 hast du nichts eingetragen (bitte vorher unter admin/advanced einloggen)
Hmm also bei mir sieht die registrierung ein wenig anders aus..
syslog server(port:514) started on Fri Jan 14 19:06:42 2005
System started: [email protected], reboot reason:W4
[0]Off Hook
fu:1:385a, 0038 03e4 0001
System started: [email protected], reboot reason:H30300010
	gateway ip:	192.168.0.100
	dns servers:	192.202.128.2 192.168.0.100
IDBG: st-0
[5060]STUN trying 0
[0]REG: STUN c0a80069->52da0530, 5060->5060
RSE_DEBUG: reference domain:sipgate.at
[0:5060]->212.236.252.3:5060
REGISTER sip:sipgate.at SIP/2.0
Via: SIP/2.0/UDP 82.218.5.48:5060;branch=z9hG4bK-43a9f1dc
was mich bei dem Problem hier wundert ist, das die lokale IP bei der Regstrierung mitgegeben wurde
soweit ich das verstehe, versucht sipsnip ihn unter 192.168.2.197 (bzw. regstriert sich sein Adapter unter dieser IP) zu erreichen - was nicht gehen kann. Klingt nach dem non "sipaware" Problem...
Router = SMC Barricade SMC2804WBR V.2
Hier die Bildschirmausdrucke, in den Usern steht nichts drin bzw. habe ich nichts eingetragen.
Bei meinem SPA 2000 habe ich auf beiden Lines NAT Mapping enable und NAT Keep alive enable auf YES gesetzt.
Als STUN habe ich stun.sipgate.net:10000 eingetragen.
Dieser scheint wohl sehr stabil zu sein.
Seither klappt alles.
hmmm, wie geht das jetzt weiter? Kann keiner helfen??
Hast Du NAT mapping enable und NAT keep alive enable beide auf "YES" gesetzt?
In Deinem Screenshot stehen sie noch auf "NO"
*g* erst ja, dann nein, jetzt wieder ja... ich probiere alles.. ;-)
den stunserver ändere ich auch
Den stunserver habe ich auf stun.sipgate.net:10000 gesetzt. Nimm besser diesen als sipsnip.
Wenn Du den Stunserver eingetragen hast, brauchst Du portforwardingstechnisch am Router nichts zu aendern.
Als Dialplan kannst Du am besten exakt folgenden verwenden:
(<**:>[2-9]|<:0221>[1-9]xx.|0[0-9]xxxx.|<#,:>x.)
ACHTUNG: die Nummer 0221 solltest Du in Deine eigene Ortsvorwahl abaendern.
Wenn am Dialplan etwas fehlerhaft ist, kann der Verbindungsaufbau ebenfalls scheitern.
Ok, den sipgate stunservier habe ich hinterlegt. Die Portsfreigabe laße ich jetzt erstmal im Router... schade ja nichts oder?
Meine Dialplan habe ich mit Deinem überschrieben bzw. meine Vorwahl 04101 statt 0221 gesetzt. Muß man eigentlich innerhalb des Vorwahlbereiches die Vorwahl mitwählen oder braucht man das nicht wie beim normalen Telefon?
Geht leider immer noch nicht... = nach Eingabe der Nummer nur Rauschen in der Leitung und nichts = kein Freizeichen
Nein die Ortsvorwahl musst Du dann kuenftig nicht mehr mitwaehlen.
Sobald Du eine Nummer ohne "0" also ohne Vorwahl waehlst, setzt er dann automatisch immer die 04101 davor.
Die Portforwardsettings im Router kannst Du erstmal so lassen.
Kannst Du ueber andere VoIP Anbieter telefonieren, oder gehts nur bei SipSnip nicht?
Lasse mal die IP settings weg und lasse mal eine IP durch den Router automatisch per DHCP zuweisen.
Wenn alles scheitert, schick mir ne Privat message mit Deiner Nummer. Koennen dann mal Schritt fuer Schritt alle Einstellungen durchgehen und mit meinem SPA vergleichen.
Ich weiß nicht ob ich es hier jetzt irgendwie überlesen habe, aber hast du die aktuelle Firmware des Routers aufgespielt?
Hatte ähnliche Probleme mit meiner Konstellation SPA 1001 und meinem Zyxel Router.
Ich habe die aktuellste Firmware aufgespielt und zumindest dieses Problem war ab diesem Zeitpunkt nicht mehr vorhanden!
Akt. FW ist jetzt drauf, geht aber leider immer noch nicht :-(
Bei mir sind die vollen Funktionen erst nach dem aufspielen der aktuellen Firmware und einem anschließendem Reset des Routers verfügbar.
Siehe auch hier.
Ich weiß zwar nicht ob das auch für deinen Router zutrifft, aber hast du das schonmal versucht?
Aktuelle FW ist jetzt auf dem Router = keine Veränderung!
ähm.. Hallo? Kann mir denn keiner helfen???
Factory22
