[Solved] FB7340 new international firmware 99.05.22
Michael999
24 Dez 2008
International firmware 05.22 is available for the 7340. Could you integrate it with freetz?
You can watch the status of the integration here. As always: It's done when it's done... ;-)
Thank you. :)
Please test r9025 and - if possible - with replace kernel. We use the kernel sources of 7390, because this box is almost identical to the 7340.
I tried with and without replace kernel. I did not use external. With both it boots, but the WLAN led isn't lighting up. With both, I can access the freetz WebIf, but not the avm interface. After about a minute it automatically reboots. I've attached the syslog, don't know if that's enough though. :confused:
Anhang anzeigen syslog.txt
There is the problem
Jan  1 01:01:13 fritz kern.emerg kernel: AVM_WATCHDOG_ungraceful_release: handle 3 (ctlmgr) still registered!
Means ctlmgr (the AVM Webinterface) crashes which causes the Watchdog to reboot the box. Post the content of the /var/flash/crash.log file
Does the box work with replace kernel, too?
Oliver
Yes, without problems. :)
fusionK
