SpeedPort W701V Help
ludovic
14 Mai 2007
Hello to all ,
i am new member here , sorry i dont speak Germany
i have a SpeedPort W701 V i searched for a manual in english but i havent found anything just in germany
so the problem is when i enter speeport.ip or 192.168.2.1
i dont get the page to enter in configuration
what the solution
thanks
try to setup you network card to acquire IP address automatically, now check the acquired IP-addresses
e.g
IP-Adresse. . . . . . . . . . . . : 192.168.2.25
Subnetzmaske. . . . . . . . . . . : 255.255.255.0
Standardgateway . . . . . . . . . : 192.168.2.1
DHCP-Server . . . . . . . . . . . : 192.168.2.1
DNS-Server. . . . . . . . . . . . : 192.168.2.1
now you can send a ping to Speedport (ping 192.168.2.1)
try to open Web-configuration
type 192.168.2.1 in internet explorer
hi Ecki-No1 ,
thanks for the Replay
i tried what you have wrote but with no luck
i tested to ping 192.168.2.1 but dont work
tried to enter in open Web-configuration 192.168.2.1 no luck
do you have any other idea that can solve the problem
thanks
No, you made wrong.
I wrote
1.) try to setup you network card to acquire IP address automatically
2.) check the acquired IP address (go to command line and type ipconfig /all)
write the results here
here you m8 all the situation
thanks
I see
You must enter the right WLAN-password.
If you don't know the right password - connect you notebook with a LAN-cable to Speedport and make a new password
Klick to "Sicherheit" (more details I can't found in the manual)
but you can try to translate the german menu "Sicherheit"
check here for translator
hi Ecki-No1,
sorry m8 but i think i need a manual in English so i can go tape by tape
i think i am not in touch with this SpeedPort
i have connect with lan-Cable my laptop to SpeedPort
when i have donne ipconfig this is the result automatic Ip Not manual
adresse Ip : 192.168.10.20
Masque Reseaux : 255.255.255.0
Passerelle : 192.168.10.30
i dont know how to change WLAN password and Why ?
Thanks
1st success :-)
Passerelle = Gateway ???
try to type in your internet browser this IP 192.168.10.30 (I hope it's the Gateway)
Why change the WLAN password?
I think, you don't know the correct one -> your WLAN adaptor can't acquire an valid IP-address, gateway and DHCP-Server
Oh Yes 2 Success :)
i tape 192.168.2.1
I get the Page but there is a problem : that i get the page with a lan-cable ,but why not with Wireless Connection ?
Thanks
OK, you can access :-)
Klick to "Konfiguration starten" (commencer la configuration)
password default "0000"
klick to "Sicherheit" (Sécurité)
make screenshot, because my manual don't show detail menu
EDIT: additional questions to you:
Where is your location (country)?
Who is your DSL-Internet-provider ?
Do you have connect the Speedport direct to DSL-line ?
Hi Ecki-No1,
here You m8 The Pictures
i am waiting Your Instruction
Thanks
Yes
klick to "Sicherheit" (security)
klick to "Verschlüsselung" (encryption)
may be you can see the WLAN password
If you can see the WLAN password try to connect the Speedport by WLAN and type twice the right password.
Be sure, your WLAN adaptor is configured with detect IP address automatically by DHCP
But I see, your speedport have alert: "no ADSL signal detected" (pic. afterpassword.png)
EDIT: maybe the default WLAN security key (WPA-key) is typing at the backside of the speedport device
YES I Got The Password
Where ?
That the Problem that i talk you i dont get WLAN IP Automatic
but with Lan-Cable Yes
Yes ?
Yes i found it & its the same
Klick to start -> settings -> network card
klick right button to your wlan adaptor and select properties
protocol TCP/IP select properties (see my picture)
set both settings to automatic acquire
Yes its the same as in your Picture
look here
Thanks For Your Help m8 , much Appreciated
OK, now you try to connect to the WLAN of the Speedport. Enter the right password and check the aquired IP address (in command line type: ipconfig /all) and send the results.
double click at your icon WLAN
select: looking for presented wireless networks
klick to connect, enter password 2 times
hehe Yes it Work Now
i Got the WLAN IP Automatic
itseb
