SpeedPort W701V Help
I promised to solve the problem :-)
Thanks m8
so What are The Next Tape
hi Ecki-No1,
What Should I Do Now in this Page
Thanks
the Speedport can only connect to ADSL Annex B
Are you sure your ADSL have Annex B standard ?
At this page you can see:
"Kein DSL verfügbar" -> no DSL signal detected :(
How Can I Know its a ADSL Annex B standard ?
or Should I Call Him ?
by the way the phone line it connected on The ADSL Modem Not In SpeedPort in the place where writing T-DSL
Thanks
The Speedport have an integrated DSL-modem (Annex B)
May be you can use the speedport for all your solutions (WLAN, ADSL, router etc.)
i have removed the phone line from the ADSL Modem
and connected to SpeedPort in the Place T-DSL
But i dont get Connection Internet
Thanks
check the "Startseite" for message "Kein DSL verfügbar"
When message "DSL verfügbar" you must input your account parameters e.g. username and password (you get it from your internet provider)
the easiest way is to use the "Assistent" "Schritt für Schritt" - step by step assistance
Sorry m8 but i dont get the message "DSL verfügbar"
to enter into configuration and put username password ....
i have tried but i get the message "kein DSL verfügbar"
i dont know what to do now :rolleyes:
a Question for Justification ?
in the back of SpeedPort i put the Phone Line int the T-DSL
what Is The role of the T-Net/T-ISDN ?
and in this Picture Where The Number is 1 & 2 ?
What are The Role
Thanks ,much appreciated Your Help
hi Ecki-No1 ,
Do You Have Any Idea m8 !
You are the only one that can help me
plz any suggestion
Thanks
Bonsoir ludovic,
ou tu employes le/la Speedport? France,Allemagne ou dans un autre pays? Le/la Speedort fonctionne seulment au Allemagne ou avec des connexions DSL Annex B. En Allemagne tous le connexions DSL sont Annex B mais en France ou autre pays sont des connexions DSL Annex A et Annex B.
Les 1 et 2 sont pour les apparailes telephone.
Je explique que tu dois installer le/la Speedport au Allemange:
T-Net/T-ISDN est pour connecter le/la Speeport avec la connexion du telephone au centre de la Splitter (le petit box, regarde l'image a la fin)
T-DSL est pour connecter le/la Speedport avec le connexion DSL en bas de la Splitter.
Connecte la Splitter avec le connexion telephone au mur. Regarde l'image dans l'instruction de la/du Speedport a la page 15, 16 et 17.
Instruction Speedport en Allemande
Qui est ton service du internet? T-Online ou un autre service?
Clic Netzwerk, clic Internetzugang (en haut), clic T-Online si ton service internet es T-Online ou clic Anderer Anbieter si T-Online n'est pas ton service Internet. Pour connecter avec l'Internet tu mets ton nom d'utilisateur et ton mot de passe mais si ton service Internet es T-Online tu mets plus.
J'espére mon francais est correct.
Christoph
bonsoir caspritz78 ,
Excuse moi pour le retard a cause des examens
oui je suis dehors de L allemagne et je suis en Morocco
J Utilise ADSL
Je Pense C Ca Le Problem pourquoi il n a pas marche
est ce qu il y un moyen de faire une mise a jour ou qq chose pour faire marcher en Morocco
Merci
BeFoe
