bash-3.2$ sudo ssh -vvv -i ~/.ssh/id_rsa root@xxx
OpenSSH_5.1p1, OpenSSL 0.9.7l 28 Sep 2006
debug1: Reading configuration data /etc/ssh_config
debug2: ssh_connect: needpriv 0
debug1: Connecting to xxx [xxx.xxx.xxx.xxx] port 22.
debug1: Connection established.
debug1: permanently_set_uid: 0/0
debug3: Not a RSA1 key file /Users/xxx/.ssh/id_rsa.
debug1: identity file /Users/xxx/.ssh/id_rsa type 1
debug1: Remote protocol version 2.0, remote software version dropbear_0.52
debug1: no match: dropbear_0.52
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_5.1
debug2: fd 3 setting O_NONBLOCK
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: [EMAIL="aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,arcfour128,arcfour256,arcfour,aes192-cbc,aes256-cbc,[email protected],aes128-ctr,aes192-ctr,aes256-ctr"]aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,arcfour128,arcfour256,arcfour,aes192-cbc,aes256-cbc,[email protected],aes128-ctr,aes192-ctr,aes256-ctr[/EMAIL]
debug2: kex_parse_kexinit: [EMAIL="hmac-md5,hmac-sha1,[email protected],hmac-ripemd160,[email protected],hmac-sha1-96,hmac-md5-96"]hmac-md5,hmac-sha1,[email protected],hmac-ripemd160,[email protected],hmac-sha1-96,hmac-md5-96[/EMAIL]
debug2: kex_parse_kexinit: [EMAIL="none,[email protected],zlib"]none,[email protected],zlib[/EMAIL]
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: aes128-ctr,3des-ctr,aes256-ctr,aes128-cbc,3des-cbc,aes256-cbc,twofish256-cbc,twofish-cbc,twofish128-cbc,blowfish-cbc
debug2: kex_parse_kexinit: hmac-sha1-96,hmac-sha1,hmac-md5
debug2: kex_parse_kexinit: [EMAIL="zlib,[email protected],none"]zlib,[email protected],none[/EMAIL]
debug2: mac_setup: found hmac-md5
debug1: kex: server->client aes128-cbc hmac-md5 none
debug1: kex: client->server aes128-cbc hmac-md5 none
debug2: dh_gen_key: priv key bits set: 131/256
debug2: bits set: 516/1024
debug1: sending SSH2_MSG_KEXDH_INIT
debug1: expecting SSH2_MSG_KEXDH_REPLY
debug3: check_host_in_hostfile: filename /var/root/.ssh/known_hosts
debug3: check_host_in_hostfile: match line 1
debug1: Host 'xxx' is known and matches the RSA host key.
debug1: Found key in /var/root/.ssh/known_hosts:1
debug2: bits set: 529/1024
debug1: ssh_rsa_verify: signature correct
debug2: kex_derive_keys
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: /Users/xxx/.ssh/id_rsa (0xxxxxxxx)
debug1: Authentications that can continue: publickey
debug3: start over, passed a different list publickey
debug3: preferred publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Offering public key: /Users/xxx/.ssh/id_rsa
debug3: send_pubkey_test
debug2: we sent a publickey packet, wait for reply
debug1: Server accepts key: pkalg ssh-rsa blen 148
debug2: input_userauth_pk_ok: fp xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx
debug3: sign_and_send_pubkey
debug1: PEM_read_PrivateKey failed
debug1: read PEM private key done: type <unknown>
debug2: bad passphrase given, try again...
debug2: we did not send a packet, disable method
debug1: No more authentication methods to try.
Permission denied (publickey).
bash-3.2$
