Toolchain für 29.04.15-ds0.2.9
Chatty
Aktives Mitglied
13 Mrz 2006
also ich könnte verzweifeln. Nach erfolgreichem "make toolchain" kommen bei "make kernel-precompiled" immer folgende Fehler:
test@1[ds-0.2.9]$ [B]make toolchain[/B]
[SIZE="1"]
FINISHED: toolchain/kernel/ - glibc compiler for the kernel
          toolchain/target/ - uClibc compiler for the userspace
[/SIZE]
test@1[ds-0.2.9]$ [B]make kernel-precompiled[/B]
[SIZE="1"]cp source/ref-ohio-8mb-04.06/kernel/kernel_ohio-8mb_build/kernel/linux-2.4.17_mvl21/ram_zimage.bin kernel/kernel-ohio-8mb-04.06.bin
mkdir -p kernel/modules-ohio-8mb-04.06
tar -cf - -C source/ref-ohio-8mb-04.06/kernel/kernel_ohio-8mb_build/modules \
                --exclude=lib/modules/2.4.17_mvl21-malta-mips_fp_le/build \
                --exclude=lib/modules/2.4.17_mvl21-malta-mips_fp_le/pcmcia \
                --exclude=lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/bluetooth \
                --exclude=lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/net/bluetooth \
                . | tar -xf - -C kernel/modules-ohio-8mb-04.06
source/depmod.pl -b kernel/modules-ohio-8mb-04.06/lib/modules/2.4.17_mvl21-malta-mips_fp_le \
                -F source/ref-ohio-8mb-04.06/kernel/kernel_ohio-8mb_build/kernel/linux-2.4.17_mvl21/System.map
[/SIZE]unresolved symbol register_isdn in file /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/isdn/avmb1/capidrv.o
unresolved symbol ip_ct_refresh in file /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/net/ipv4/netfilter/ip_conntrack_proto_esp.o
unresolved symbol ip_ct_refresh in file /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/net/ipv4/netfilter/ip_conntrack_proto_gre.o
unresolved symbol ip_ct_refresh in file /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/net/ipv4/netfilter/ip_conntrack_pptp.o
unresolved symbol __ip_conntrack_confirm in file /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/net/ipv4/netfilter/ipt_ROUTE.o
unresolved symbol ip_conntrack_in in file /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/net/ipv4/netfilter/ipt_ROUTE.o
echo "iln6" > kernel/.version-ohio-8mb-04.06
Ich hab schon gcc-4.1 und gcc-3.3 probiert. Ohne Erfolg :noidea:
Ich bekomme auch die selben Meldungen, wie es scheint fehlen für ein paar iptables Module externe Symbole, aber ansonsten geht doch alles glatt.
Mfg,
danisahne
holh-66
