You can change the kernel of 7050?
l i n u s
15 Aug 2006
Given that:
1) There are more updates on the 7050;
2) The kernel is 2.4.17_mvl21-malta-mips_fp_le on the 7050;
3) The Memory Flash is 4 Mb on 7050 and 5040;
4) In 5140 the kernel is 2.6.13.1-ohio.
Is possible to change the kernel to malta in ohio on 7050?
Why:
I am interested in changing the form:
ubik2-dsl.bin
to:
microvoip-dsl.bin
Vielen Danken :groesste:
Linus
Hi.
The actual german firmware for the 7050 is 2.6.13. Can you use this kernel or did I misunderstood your question?
Hi! :) Mr.Olistudent
Certainly on vers. 33 is 2.6.13.1-ar7, but not Ohio, and uses the form ubik2-dsl.bin.
The problem is that I would like to use the form microvoip-dsl.bin which is more performant for my DSL.
Thanks :habenwol:
Linus
@RalfFriedl
Thank you, I verified that in fact the 7050 is fitted with a UBIK-2 marked AVM on plate.
I wondered if it was possible to circumvent the problem.:rolleyes:
Many Thanks!!
Linus
Protonator
