7270 v2
argonx
24 Dez 2011
Grüße,
Ich bin neu bei fritz und Forum, auch, meine deutsche Sprache nicht so gut (mit Übersetzer jetzt)
Ich muss wissen, ist dies möglich, sich auf Anhang A der Arbeit:
HWRevision 139.1.0.6
ProductID Fritz_Box_7270_16
SerialNumber 0000000000000000
annex B
autoload yes
bootloaderVersion 1.455
bootserport tty0
country 99
cpufrequency 360000000
firstfreeaddress 0x946BD89C
firmware_version avme
Es ist fritzbox 7270 2000-2404
sn: w292 305.....
Welcome in the IP Phone Forum :)
Yes, it is possible to switch to Annex A. Your box is originally a german annex B version from provider 1&1 and was switched to english. The current international firmware versions will support multi-annex. Which firmware version do you have right now?
Thanks to all, I tought it was only German forum, but anyway, I just switched it to "FRITZ.Box_Fon_WLAN_7270_16.en-de-es-it-fr.54.05.06.image" using rukerneltool, and it's on english now, with A annex, but it seems I have some problems connecting.... anyway, thank You all for answer, and I will continue to try to connect :)
Ansh
