mainmenu "Danisahne-Mod Configuration"
config DS_HAVE_DOT_CONFIG
bool
default y
choice
prompt "Source version"
default DS_AVM_VERSION_04_06
help
AVM's source package version
#config DS_AVM_VERSION_04_01
# bool "04.01"
config DS_AVM_VERSION_04_06
bool "04.06"
endchoice
config DS_AVM_VERSION_STRING
string
default "04.01" if DS_AVM_VERSION_04_01
default "04.06" if DS_AVM_VERSION_04_06
choice
prompt "Firmware type"
default DS_TYPE_FON_WLAN_7050
help
Select your box type here.
config DS_TYPE_300IP_AS_FON
depends on DS_AVM_VERSION_04_06
bool "300IP as Fon"
config DS_TYPE_FON
bool "Fon"
config DS_TYPE_FON_5010
bool "Fon 5010"
config DS_TYPE_FON_5012
bool "Fon 5012"
config DS_TYPE_FON_5050
bool "Fon 5050"
config DS_TYPE_FON_5140
bool "Fon 5140"
config DS_TYPE_FON_ATA
depends on DS_AVM_VERSION_04_01
bool "Fon ATA"
config DS_TYPE_FON_WLAN
bool "Fon WLAN"
config DS_TYPE_FON_WLAN_7050
bool "Fon WLAN 7050"
# config DS_TYPE_FON_WLAN_7140
# depends on DS_AVM_VERSION_04_06
# select DS_LIB_libm
# bool "Fon WLAN 7140"
# config DS_TYPE_FON_WLAN_7170
# bool "Fon WLAN 7170"
#config DS_TYPE_SL
# bool "SL (EXPERIMENTAL)"
config DS_TYPE_SL_WLAN
bool "SL WLAN"
config DS_TYPE_WLAN_3030
bool "WLAN 3030"
config DS_TYPE_WLAN_3050
bool "WLAN 3050"
config DS_TYPE_WLAN_3070
bool "WLAN 3070"
config DS_TYPE_WLAN_3131
bool "WLAN 3131"
config DS_TYPE_CUSTOM
bool "Custom"
select DS_DL_OVERRIDE
endchoice
choice
prompt "Firmware version"
default DS_TYPE_LANG_DE
config DS_TYPE_LANG_DE
bool "de - deutsch"
config DS_TYPE_LANG_A_CH
bool "a-ch - deutsch"
depends on DS_TYPE_FON || \
DS_TYPE_FON_ATA || \
DS_TYPE_FON_WLAN
config DS_TYPE_LANG_EN
bool "en - international"
DS_TYPE_FON_WLAN
endchoice
config DS_TYPE_LANG_STRING
string
default "de" if DS_TYPE_LANG_DE
default "a-ch" if DS_TYPE_LANG_A_CH
default "en" if DS_TYPE_LANG_EN
choice
prompt "Annex"
depends on DS_TYPE_FON && DS_TYPE_LANG_EN || \
DS_TYPE_FON_WLAN && DS_TYPE_LANG_A_CH || \
DS_TYPE_FON_WLAN && DS_TYPE_LANG_EN
default DS_TYPE_ANNEX_B
config DS_TYPE_ANNEX_A
bool "A"
config DS_TYPE_ANNEX_B
bool "B"
endchoice
config DS_TYPE_STRING
string
default "300ip_as_fon" if DS_TYPE_300IP_AS_FON
default "fon" if DS_TYPE_FON
default "fon_5010" if DS_TYPE_FON_5010
default "fon_5012" if DS_TYPE_FON_5012
default "fon_5050" if DS_TYPE_FON_5050
default "fon_5140" if DS_TYPE_FON_5140
default "fon_ata" if DS_TYPE_FON_ATA
default "fon_wlan" if DS_TYPE_FON_WLAN
default "fon_wlan_7050" if DS_TYPE_FON_WLAN_7050
default "fon_wlan_7140" if DS_TYPE_FON_WLAN_7140
default "fon_wlan_7170" if DS_TYPE_FON_WLAN_7170
default "sl" if DS_TYPE_SL
default "sl_wlan" if DS_TYPE_SL_WLAN
default "wlan_3030" if DS_TYPE_WLAN_3030
default "wlan_3050" if DS_TYPE_WLAN_3050
default "wlan_3070" if DS_TYPE_WLAN_3070
default "wlan_3131" if DS_TYPE_WLAN_3131
default "custom" if DS_TYPE_CUSTOM
comment "Custom options"
depends on DS_TYPE_CUSTOM
config DS_INSTALL_BASE
bool
select DS_LIB_ld_uClibc
select DS_LIB_libcrypt
select DS_LIB_libdl
select DS_LIB_libpthread
select DS_LIB_libuClibc
default y
help
This is mandatory
config DS_REPLACE_BUSYBOX
bool
default y
help
This is mandatory
config DS_REPLACE_KERNEL
bool "Replace kernel" if DS_TYPE_CUSTOM
select DS_LIB_libnsl
default y
help
Saves a lot of space by utilizing unused space at
the end of the kernel image and by using lzma.
config DS_TARGET_REF
string "Target ref" if DS_TYPE_CUSTOM
default "2mb" if DS_TYPE_SL
default "4mb" if DS_TYPE_300IP_AS_FON || \
DS_TYPE_FON || \
DS_TYPE_FON_5010 || \
DS_TYPE_FON_5012 || \
DS_TYPE_FON_5050 || \
DS_TYPE_FON_5140 || \
DS_TYPE_FON_WLAN || \
DS_TYPE_FON_WLAN_7050 || \
DS_TYPE_SL_WLAN || \
DS_TYPE_WLAN_3030 || \
DS_TYPE_WLAN_3050 || \
DS_TYPE_WLAN_3070 || \
DS_TYPE_WLAN_3131 || \
DS_TYPE_CUSTOM
default "8mb" if DS_TYPE_FON_WLAN_7140 || \
config DS_KERNEL_REF
string "Kernel ref" if DS_TYPE_CUSTOM
DS_TYPE_FON || \
DS_TYPE_CUSTOM
default "ohio-8mb" if DS_TYPE_FON_WLAN_7140 || \
config DS_HIDDEN_ROOT
bool "Hidden root" if DS_TYPE_CUSTOM
default y if DS_TYPE_FON_5010 || \
DS_TYPE_SL || \
default n if DS_TYPE_300IP_AS_FON || \
DS_TYPE_FON || \
DS_TYPE_CUSTOM
help
Some boxes do not have the root filesystem in the
mtd table, it begins just after the kernel.
config DS_CONTIGUOUS_HIDDEN_ROOT
bool "Contiguous" if DS_TYPE_CUSTOM
depends on DS_HIDDEN_ROOT
default y if DS_TYPE_SL || \
default n if DS_TYPE_FON_5010 || \
help
A contiguous hidden squashfs starts where all
hidden root filesystems start (just after the
kernel), but is continued in filesystem mtd.
config DS_SQUASHFS_LZMA
bool "Lzma squashfs" if DS_TYPE_CUSTOM
default y if DS_TYPE_300IP_AS_FON || \
DS_TYPE_FON || \
DS_TYPE_FON_WLAN_7170 || \
DS_TYPE_WLAN_3131
default n if DS_TYPE_FON_ATA || \
DS_TYPE_SL || \
DS_TYPE_CUSTOM
help
Is the squashfs compressed with lzma?
config DS_ROOTFS_VARTAR
bool "RootFS contains var.tar" if DS_TYPE_CUSTOM
(DS_TYPE_CUSTOM && DS_HIDDEN_ROOT)
DS_TYPE_FON || \
DS_TYPE_SL || \
(DS_TYPE_CUSTOM && ! DS_HIDDEN_ROOT)
help
var.tar can be placed in the hidden squashfs
or in the root filesystem at /var.tar
config DS_KERNEL_MTD_SIZE
int "Kernel (64K blocks)" if DS_TYPE_CUSTOM
default 10 if DS_TYPE_SL
default 11 if DS_TYPE_300IP_AS_FON || \
DS_TYPE_FON || \
(DS_TYPE_CUSTOM && (! DS_HIDDEN_ROOT || DS_CONTIGUOUS_HIDDEN_ROOT))
default 59 if DS_TYPE_FON_5010 || \
(DS_TYPE_CUSTOM && (DS_HIDDEN_ROOT && ! DS_CONTIGUOUS_HIDDEN_ROOT))
default 119 if DS_TYPE_FON_WLAN_7140 || \
help
Number of 64K blocks in the kernel mtd device.
config DS_FILESYSTEM_MTD_SIZE
int "Filesystem (64K blocks)" if DS_TYPE_CUSTOM
depends on ! DS_HIDDEN_ROOT || \
default 20 if DS_TYPE_SL
default 48 if DS_TYPE_300IP_AS_FON || \
DS_TYPE_FON || \
DS_TYPE_CUSTOM
help
Number of 64K blocks in the filesystem mtd device.
config DS_HAS_PHONE
bool "Has Phone" if DS_TYPE_CUSTOM
DS_TYPE_FON || \
default n if DS_TYPE_SL || \
DS_TYPE_CUSTOM
help
Select this if you have a box with phone support.
config DS_HAS_WLAN
bool "Has WLAN" if DS_TYPE_CUSTOM
default y if DS_TYPE_FON_WLAN || \
DS_TYPE_WLAN_3131
DS_TYPE_FON || \
DS_TYPE_SL || \
DS_TYPE_CUSTOM
help
Select this if you have a box with WLAN.
config DS_HAS_USB
bool "Has USB" if DS_TYPE_CUSTOM
DS_TYPE_FON || \
DS_TYPE_SL || \
DS_TYPE_WLAN_3131
DS_TYPE_CUSTOM
help
Select this if you have a box with USB.
config DS_HAS_USB_HOST
bool "USB host" if DS_TYPE_CUSTOM
depends on DS_HAS_USB
default y if DS_TYPE_FON_WLAN_7140 || \
DS_TYPE_WLAN_3131
DS_TYPE_FON || \
DS_TYPE_SL || \
DS_TYPE_WLAN_3050
help
Select this if your USB port is a host adapter
comment "Brandings"
depends on ! DS_TYPE_300IP_AS_FON && ! DS_TYPE_CUSTOM
comment "Brandings (if exist)"
config DS_BRANDING_1und1
bool "1und1"
depends on DS_TYPE_FON && DS_TYPE_LANG_DE || \
DS_TYPE_FON_WLAN && DS_TYPE_LANG_DE || \
DS_TYPE_SL || \
DS_TYPE_CUSTOM
default y
config DS_BRANDING_avm
bool "avm"
DS_TYPE_FON_ATA && DS_TYPE_LANG_DE || \
DS_TYPE_SL || \
DS_TYPE_CUSTOM
default y
config DS_BRANDING_avme
bool "avme"
depends on DS_TYPE_FON && DS_TYPE_LANG_A_CH || \
DS_TYPE_FON_ATA && DS_TYPE_LANG_A_CH || \
DS_TYPE_FON_ATA && DS_TYPE_LANG_EN || \
DS_TYPE_FON_WLAN && DS_TYPE_LANG_EN || \
DS_TYPE_CUSTOM
default y
config DS_BRANDING_aol
bool "aol"
DS_TYPE_CUSTOM
default y
config DS_BRANDING_arcor
bool "arcor"
DS_TYPE_CUSTOM
default y
config DS_BRANDING_freenet
bool "freenet"
DS_TYPE_CUSTOM
default y
comment "Patches"
config DS_REMOVE_HELP
bool "Remove help"
default y
help
Removes the help pages from the webmenu.
config DS_REMOVE_ASSISTANT
bool "Remove assistant"
default y
help
Removes the network assistant from the
webmenu.
config DS_REMOVE_CDROM_ISO
bool "Remove cdrom.iso"
depends on DS_HAS_USB && ! DS_TYPE_WLAN_3131 && ! DS_TYPE_FON_WLAN_7140 && ! DS_TYPE_FON_WLAN_7170 && ! DS_TYPE_SL
default n
help
Removes the file /lib/modules/cdrom.iso.
config DS_PATCH_ATA
bool "Patch ata"
depends on DS_TYPE_FON_WLAN_7140 || \
default y
help
Patches the ATA mode configuration pages
into the webmenu.
config DS_PATCH_ENUM
bool "Patch enum"
depends on DS_HAS_PHONE
default y
help
Patches the enum configuration pages into
the webmenu.
config DS_PATCH_INTERNATIONAL
bool "Patch international"
depends on DS_HAS_PHONE && DS_TYPE_LANG_DE
default y
help
Reveals some options from the international
firmware in the webmenu.
config DS_PATCH_WDS
bool "Patch wds"
depends on DS_HAS_WLAN && DS_AVM_VERSION_04_01
default y
help
Patches the wds configuration pages into
the webmenu.
comment "Mod"
choice
prompt "Language"
default DS_LANG_DE if DS_TYPE_LANG_DE || \
DS_TYPE_LANG_A_CH
default DS_LANG_EN if DS_TYPE_LANG_EN
config DS_LANG_DE
bool "de - deutsch"
config DS_LANG_EN
bool "en - english"
endchoice
config DS_LANG_STRING
string
default "de" if DS_LANG_DE
default "en" if DS_LANG_EN
menu "Package selection"
#config DS_BUILD_DYNAMIC_PACKAGES
# bool "Build dynamic packages (NOT SUPPORTED YET)"
# default n
# help
# If this is selected, all packages, which are not
# selected, will be build as dynamic packages.
source make/Config.in
endmenu
menu "Advanced options"
config DS_DL_OVERRIDE
bool "Override firmware source"
default n
help
Enable this to override automatically generated
entries.
config DS_DL_SITE
string "Firmware site" if DS_DL_OVERRIDE
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon/firmware/deutsch" if DS_TYPE_300IP_AS_FON && DS_TYPE_LANG_DE || \
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon/firmware/deutsch_a-ch" if DS_TYPE_FON && DS_TYPE_LANG_A_CH
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon/firmware/english/annex_a" if DS_TYPE_FON && DS_TYPE_LANG_EN && DS_TYPE_ANNEX_A
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon/firmware/english/annex_b" if DS_TYPE_FON && DS_TYPE_LANG_EN && DS_TYPE_ANNEX_B
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_5010/firmware" if DS_TYPE_FON_5010
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_5012/firmware" if DS_TYPE_FON_5012
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_5050/firmware" if DS_TYPE_FON_5050
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_5140/firmware" if DS_TYPE_FON_5140
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_ata/firmware/deutsch" if DS_TYPE_FON_ATA && DS_TYPE_LANG_DE
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_ata/firmware/deutsch_a-ch" if DS_TYPE_FON_ATA && DS_TYPE_LANG_A_CH
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_ata/firmware/english" if DS_TYPE_FON_ATA && DS_TYPE_LANG_EN
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan/firmware/deutsch" if DS_TYPE_FON_WLAN && DS_TYPE_LANG_DE
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan/firmware/deutsch_a-ch/annex_a" if DS_TYPE_FON_WLAN && DS_TYPE_LANG_A_CH && DS_TYPE_ANNEX_A
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan/firmware/deutsch_a-ch/annex_b" if DS_TYPE_FON_WLAN && DS_TYPE_LANG_A_CH && DS_TYPE_ANNEX_B
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan/firmware/english/annex_a" if DS_TYPE_FON_WLAN && DS_TYPE_LANG_EN && DS_TYPE_ANNEX_A
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan/firmware/english/annex_b" if DS_TYPE_FON_WLAN && DS_TYPE_LANG_EN && DS_TYPE_ANNEX_B
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7050/firmware" if DS_TYPE_FON_WLAN_7050
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7140/firmware/deutsch" if DS_TYPE_FON_WLAN_7140
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7170/firmware/deutsch" if DS_TYPE_FON_WLAN_7170
default "ftp://ftp.avm.de/fritz.box/fritzbox.sl/firmware/" if DS_TYPE_SL
default "ftp://ftp.avm.de/fritz.box/fritzbox.sl_wlan/firmware" if DS_TYPE_SL_WLAN
default "ftp://ftp.avm.de/fritz.box/fritzbox.wlan_3030/firmware" if DS_TYPE_WLAN_3030
default "ftp://ftp.avm.de/fritz.box/fritzbox.wlan_3050/firmware" if DS_TYPE_WLAN_3050
default "ftp://ftp.avm.de/fritz.box/fritzbox.wlan_3070/firmware" if DS_TYPE_WLAN_3070
default "ftp://ftp.avm.de/fritz.box/fritzbox.wlan_3131/firmware" if DS_TYPE_WLAN_3131
default "ftp://ftp.avm.de/fritz.box/..." if DS_TYPE_CUSTOM
config DS_DL_SOURCE
string "Firmware source" if DS_DL_OVERRIDE
default "fritz.box_fon.06.04.27.image" if DS_TYPE_300IP_AS_FON && DS_TYPE_LANG_DE || \
default "fritz.box_fon.de.06.04.01.image" if DS_TYPE_FON && DS_TYPE_LANG_A_CH
default "fritz.box_fon.annexa.en.06.04.24.image" if DS_TYPE_FON && DS_TYPE_LANG_EN && DS_TYPE_ANNEX_A
default "fritz.box_fon.en.06.04.24.image" if DS_TYPE_FON && DS_TYPE_LANG_EN && DS_TYPE_ANNEX_B
default "fritz.box_fon_5010.23.04.27.image" if DS_TYPE_FON_5010
default "fritz.box_fon_5012.25.04.27.image" if DS_TYPE_FON_5012
default "fritz.box_fon_5050.12.04.26.image" if DS_TYPE_FON_5050
default "fritz.box_fon_5140.43.04.27.image" if DS_TYPE_FON_5140
default "fritz.box_fon_ata.11.04.01.image" if DS_TYPE_FON_ATA && DS_TYPE_LANG_DE
default "fritz.box_fon_ata.de.11.04.01.image" if DS_TYPE_FON_ATA && DS_TYPE_LANG_A_CH
default "fritz.box_fon_ata.en.11.04.01.image" if DS_TYPE_FON_ATA && DS_TYPE_LANG_EN
default "fritz.box_fon_wlan.08.04.27.image" if DS_TYPE_FON_WLAN && DS_TYPE_LANG_DE
default "fritz.box_fon_wlan.annexa.de.08.04.15.image" if DS_TYPE_FON_WLAN && DS_TYPE_LANG_A_CH && DS_TYPE_ANNEX_A
default "fritz.box_fon_wlan.de.08.04.01.image" if DS_TYPE_FON_WLAN && DS_TYPE_LANG_A_CH && DS_TYPE_ANNEX_B
default "fritz.box_fon_wlan.annexa.en.08.04.21.image" if DS_TYPE_FON_WLAN && DS_TYPE_LANG_EN && DS_TYPE_ANNEX_A
default "fritz.box_fon_wlan.en.08.04.21.image" if DS_TYPE_FON_WLAN && DS_TYPE_LANG_EN && DS_TYPE_ANNEX_B
default "fritz.box_fon_wlan_7050.14.04.26.image" if DS_TYPE_FON_WLAN_7050
default "fritz.box_fon_wlan_7140.30.04.12.image" if DS_TYPE_FON_WLAN_7140
default "fritz.box_fon_wlan_7170.29.04.25.image" if DS_TYPE_FON_WLAN_7170
default "fritz.box_sl.10.03.93.image" if DS_TYPE_SL
default "fritz.box_sl_wlan.09.04.15.image" if DS_TYPE_SL_WLAN
default "fritz.box_wlan_3030.21.04.15.image" if DS_TYPE_WLAN_3030
default "fritz.box_wlan_3050.16.04.07.image" if DS_TYPE_WLAN_3050
default "fritz.box_wlan_3070.19.04.15.image" if DS_TYPE_WLAN_3070
default "fritz.box_wlan_3131.50.04.21.image" if DS_TYPE_WLAN_3131
default "fritz.box..." if DS_TYPE_CUSTOM
config DS_DL_SITE2
string "Original 300IP firmware site" if DS_DL_OVERRIDE
depends on DS_TYPE_300IP_AS_FON
default "http://www.t-com.de/dlp/eki/downloads/a"
config DS_DL_SOURCE2
string "Original 300IP firmware source" if DS_DL_OVERRIDE
default "a300ip_v150405.image"
config DS_VERBOSITY_LEVEL
int "Verbosity level (0-2)"
default 0
help
Verbosity level of the fwmod script and tar.
0 is the least and 2 the most information.
choice
prompt "Favicon"
default DS_FAVICON_NONE
help
Adds small favicons to the document root.
config DS_FAVICON_NONE
bool "none"
config DS_FAVICON_DSL123
bool "dsl123's favicons"
config DS_FAVICON_HDELLER
bool "hdeller's favicons"
endchoice
config DS_FAVICON_STRING
string
default "none" if DS_FAVICON_NONE
default "dsl123" if DS_FAVICON_DSL123
default "hdeller" if DS_FAVICON_HDELLER
choice
prompt "Squashfs blocksize"
default DS_SQUASHFS_BLOCKSIZE_65536
help
Blocksize of the root filesystem (and hidden squashfs)
config DS_SQUASHFS_BLOCKSIZE_ORIG
bool "original"
config DS_SQUASHFS_BLOCKSIZE_16384
bool "16384"
config DS_SQUASHFS_BLOCKSIZE_65536
bool "65536"
endchoice
menu "Kernel modules"
depends on DS_REPLACE_KERNEL
source kernel/Config.in
endmenu
menu "Shared libraries"
source make/libs/Config.in
endmenu
menu "Compiler options"
comment "*** only needed for the 'precompiled' target ***"
config DS_EXTERNAL_COMPILER
bool "Use external compiler"
default n
config DS_TARGET_CROSS
string "Target cross (appropriate mipsel-linux-uclibc-gcc)" if DS_EXTERNAL_COMPILER
default "mipsel-linux-uclibc-"
config DS_TARGET_MAKE_PATH
string "Target make path" if DS_EXTERNAL_COMPILER
default "/path/to/target-cross/bin" if DS_EXTERNAL_COMPILER
default "toolchain/target/bin" if ! DS_EXTERNAL_COMPILER
config DS_TARGET_CFLAGS
string "Target compiler flags"
default "-Os -W -Wall -pipe -march=4kc -Wa,--trap"
config DS_KERNEL_CROSS
string "Kernel cross (mipsel-glibc-linux-gcc 3.3.2)" if DS_EXTERNAL_COMPILER
default "mipsel-unknown-linux-gnu-"
config DS_KERNEL_MAKE_PATH
string "Kernel make path" if DS_EXTERNAL_COMPILER
default "/path/to/kernel-cross/bin" if DS_EXTERNAL_COMPILER
default "toolchain/kernel/bin" if ! DS_EXTERNAL_COMPILER
source toolchain/Config.in
endmenu
endmenu
