FRITZ!Box Fon WLAN 7170 (AnnexA international) Firmware Version 58.04.76 online
leibezem
23 Dez 2006
The firmware controls the ADSL modem and router functions. Start by downloading the firmware to a disk drive on your computer, then load it into the device.
New Features:
System: Improved security for the web-interface
Telephony: SIP-proxy added (IP-telephones can now directly connect to the FRITZ!Box)
Telephony: multiple fax numbers can forward the recieved faxes to different email-adresses
USB: Spindown for USB harddrives to reduce energy consumption
____________________________________________________________________________
Changes in 58.04.76:
- DSL: improved DSL-driver for better interoperability
- DSL: possiblity to send feedback about the DSL-line directly from within the FRITZ!Box
- Internet: Child protection improved
- Internet: improved compatibility for SetTopBoxes (RTSP)
- System: Improved security for the web-interface
- System: Improved UPnP-communication
- Telephony: added supported Codecs (clearmode)
- Telephony: SIP-proxy added (IP-telephones can now directly connect to the FRITZ!Box)
- Telephony: block incoming anonymous calls depending on the number that is beeing called
- Telephony: multiple fax numbers can forward the recieved faxes to different email-adresses
- USB: Spindown for USB harddrives to reduce energy consumption
DSL-Version: 1.35.61.10
Download Link: Click
hallo I am living in morocco and using FRITZ!Box Fon WLAN 7170, if i try to upgrade firmware i get this message: The firmware update failed: The specified file does not contain any valid firmware for your device.
but the box detected the file !
this box is a original Annex B ! but i bought it already changed into Annex A - what i can do to upgrade ? best regards Danny PS: Antworten natürlich auch auf deutsch
Läuft seit knappe 24 Stunden sehr gut auf einer org. 7140 AT, DSL Syncs. (Fehler) sind von AT/CH gesehen einen Tick besser als die vorherige 7170 Firmware und natürlich auch der alten 7140 AT/CH Firmware.
Getestet ca. 24 Stunden, Daten übertragen 15000 MB
@targanit: if your actual firmware is already english, you have to set environment variable "annex" to A before firmware update.
echo "annex A" > proc/sys/urlader/environment
As this parameter is only changed temporarily, you have to do this every time you want do update the firmware.
To install the internaltional AnnexA firmware to original AnnexB boxes, you have to change some more environment variables
connect to the box via telnet:
# set hardware revision to 7170 international Annex A
echo "HWRevision 127" > proc/sys/urlader/environment
# set firmware language to 7170 english
# ATTENTION: after changing language, WebIF is no more accessible -> firmware recovery is necessary.
# Download latest [URL="ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7170/x_misc/english/annex_a/FRITZ.Box_Fon_WLAN_7170.AnnexA.en.04.76.recover-image.exe"]AnnexA recovery[/URL] form AVM before executing following command
echo "firmware_version avme" > proc/sys/urlader/environment
After firmware recovery is done, check if firmware runs in AnnexA (DSL-Info page). If Annex is still B:
# set modem Annex to A
echo "kernel_args_annex=A" > /proc/sys/urlader/environment
There is a (very lengthy) thread describing some more methods of conversion: Converting a German targeted Fritz!Box Fon Wlan to an International version
SUPER !!!! it worked !! it was my first operation with telnet, i used hyperterminal and had to find out a few things first, but so far so good !!
thank you very much leibezem, greatings from morocco - TARGANIT
Für die, die es interessiert:
Inzwischen gibt es auch die deutschsprachige Austria/Schweiz Edition (Annex A) in der 76er Version.
gruß
the.gangster
Firmware upgrade auf Schweizer Version
ich versuche schon seit gestern mit Hilfe dieses Threads meine originale Fritzbox 7170 (Version 29.04.80) auf die Schweizer Annex A Firmware (Version 58.04.76) zu patchen. Wie oben beschrieben habe ich via telnet die Änderungen vorgenommen danach starte ich via WebIF ein Firmware upgrade mit dem File FRITZ.Box_Fon_WLAN_7170.AnnexA.58.04.76.image.
Leider bekomme ich immer wieder die Meldung dass die Firmware nicht für diese Fritzbox ist und das Update wird abgebrochen.
Kann jemand helfen bzw mir sagen was ich falsch mache?
Ich habe das zwar noch nie gemacht, aber Du könntest einmal das ruKernelTool aus dem Forum probieren.
Wie @3949354 schon geschrieben mit den ruKernelTool geht es!!!
Habe ich letzte Woche erst gemacht.
So, geschafft. Hier ein kleiner Erfahrungsbericht der letzten Stunde.
- Erstmaliges ausführen des ruKernelTool
- genaues vorgehen nach der Anleitung
- upgrade der Box auf 58.04.76
- Misserfolg -> Box hängt in einer Rebootschleife
- Ausführung der Fritzbox Recovery für 29.04.80
- nächster Versuch
- ruKernelTool -> Anleitung lesen -> erneutes upgrade auf 58.04.76
- Erfolg Jippppiiiiiiiii
Box läuft bisher ohne Probleme! Mal schauen ob das auch heute Abend so ist wenn ich die Box ans DSL hänge und meine Zugangsdaten rein schiebe.
Danke sagt der Don
Duggy
