I use the fritz!box 5050 (12.04.26 firmware) for about a week with voipdiscount and the quality of the calls ismuch better compared to the simple fritz!box fon device (06.04.27 firmware).
Einstellungen -> Telefonie -> Sprachübertragung:
You can find the active phone calls there
By activating "Detailinformationen beendeter Internettelefonate anzeigen und mit Push Service versenden" and a click on "Übernehmen" the ended phone calls also appear.
I hope your Fritzbox and your Firmware version does also have this menu entry.
